path: root/board
2009-03-20boards: get mac address from env and move load_sernum_ethaddr() to board initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have common ppc code call a board-specific function like load_sernum_ethaddr(), have each board call it in its own board-specific misc_init_r() function. The boards that get converted here are: - kup4k/kup4x - pcs440ep - tqm8xx Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Stefan Roese <sr@denx.de>
2009-03-20cmc_pu2: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Also rename load_sernum_ethaddr() to misc_init_r() so we don't need to handle this board specially in common ARM code. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20boards: move board_get_enetaddr() into board-specific initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have the common ppc code have board-specific hooks, move the board_get_enetaddr() function into the board-specific init functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20nx823: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. For the nx823, the serial number is moved out of load_sernum_ethaddr() and into misc_init_r() as is the env setup. This lets us kill off the former function in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20boards: get mac address from environmentMike Frysinger
The boards that get converted here to use the environment for the mac address rather than global data: debris mgcoge mgsuvd muas3001 netstal pn62 sixnet vcma9 xilinx (the ones that use xilinx_enet) Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Sangmoon Kim <dogoil@etinsys.com> CC: Heiko Schocher <hs@denx.de> CC: David Mueller <d.mueller@elsoft.ch> CC: Niklaus Giger <niklaus.giger@netstal.com> CC: Wolfgang Grandegger <wg@denx.de> CC: Dave Ellis <DGE@sixnetio.com> CC: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-03-20AmigaOneG3SE/enet: get mac address from environmentMike Frysinger
Always use the MAC address that is stored in the environment first before falling back to the ROM. This also cuts out any comparison steps: if the mac in the env is sane, the ROM is never consulted. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Thomas Frieden <ThomasF@hyperion-entertainment.com> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-188xx: add support for new keymile kmsupx4 board.Heiko Schocher
This patch adds support for the kmsupx4 board from Keymile, based on a Freescale MPC852T CPU - serial console on SMC1 - 32 MB SDRAM - 32 MB NOR Flash - Ethernet over SCC3 - I2C Bitbang Signed-off-by: Heiko Schocher <hs@denx.de>
2009-03-188xx, mgsuvd: rename board to a more generic nameHeiko Schocher
renaming the "mgsuvd" board port into "km8xx", because there come more similar boards from keymile. Compiling the mgsuvd board with "make mgsuvd_config" remains. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-03-18Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2009-03-17ColdFire: Fix M5329EVB and M5373EVB nand issueTsiChung Liew
The Nand flash was unable to read and write properly due to Nand Chip Select (nCE) setup was in reverse order. Also, increase the Nand time out value to 60. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2009-03-17ppc4xx: lwmon5: Only use one CS (rank) in DDR2 configurationStefan Roese
This patch fixes a problem spotted by Mikhail Zolotaryov on Sequoia with the DDR2 configuration to only use one CS (rank). As this code is most likely copied from the original Sequoia version, this error was copied as well. This patch also removes some dead code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-17ppc4xx: PMC440: Only use one CS (rank) in DDR2 configurationStefan Roese
This patch fixes a problem spotted by Mikhail Zolotaryov on Sequoia with the DDR2 configuration to only use one CS (rank). As this code is most likely copied from the original Sequoia version, this error was copied as well. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-17Fix AMCC Sequoia board DDR memory configurationMikhail Zolotaryov
Sequoia board schematics (DES0211_11_SCH_11.pdf, page 5, unit U1D) specifies that BankSel#1 is not connected, while bootloader memory configuration is (board/amcc/sequoia/sdram.c): mtsdram(DDR0_10, 0x00000300); i.e. both Chip Selects used - not correct. If we change to correct value here: mtsdram(DDR0_10, 0x00000100); memory is accessible OK also. Signed-off-by: Mikhail Zolotaryov <lebon@lebon.org.ua> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-15Prepare 2009.03-rc2v2009.03-rc2Wolfgang Denk
Update CHANEGLOG, fix minor coding style issue. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-15Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2009-03-13OMAP3: Add support for OMAP3 die IDDirk Behme
Read and store OMAP3 die ID in U-Boot environment. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-03-13sh: ap325rxa: Change the wait cycle in the area 5Yusuke.Goda
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-12sh: Add support 32-Bit Extended Address Mode to sh7785lcrYoshihiro Shimoda
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb" for this mode. This command changes PMB for using 512MB system memory. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-12sh: use write{8,16,32} in ms7720se lowlevel_initNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-09fsl: Remove unnecessary debug printfsAndy Fleming
These were left in accidentally, and are not really useful unless the code is as broken as it was when it was being developed. Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-03-09Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
Conflicts: lib_ppc/board.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-0583xx, kmeter: QE_ENET10 errata for Silicon Revision 2.1Heiko Schocher
old code implemented the QE_ENET10 errata only for Silicon Revision 2.0. New code reads now the Silicon Revision register and sets dependend on the Silicon Revision the values as advised in the QE_ENET10 errata. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx, kmeter1: autodetect size of DDR II RAMHeiko Schocher
it is possible that some board variants have different DDR II RAM sizes. So we autodetect the size of the assembled RAM. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx, kmeter1: add I2C, dtt, eeprom supportHeiko Schocher
This patch adds I2C support for the Keymile kmeter1 board. It uses the First I2C Controller from the CPU, for accessing 4 temperature sensors, an eeprom with IVM data and the booteeprom over a pca9547 mux. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-05mpc83xx: MPC837XEMDS: Initialize SerDes before negating PCIE reset signalAnton Vorontsov
The SerDes initialization should be finished before negating the reset signal according to the reference manual. This isn't an issue on real hardware, but we'd better stick to the specifications anyway. Suggested-by: Liu Dave <DaveLiu@freescale.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-24Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2009-02-24Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-02-24ARM: add an "eet" variant of the imx31_phycore boardGuennadi Liakhovetski
The "eet" variant of the imx31_phycore board has an OLED display, using a s6e63d6 display controller on the first SPI interface, using GPIO57 as a chip-select for it. With this configuration you can display 256 colour BMP images in 16-bit RGB (RGB565) LCD mode. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-23mpc83xx: MPC837XERDB: Add PCIe supportAnton Vorontsov
On MPC8377E-RDB and MPC8378E-RDB boards we have PCIe and mini-PCIe slots. Let's support them. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-23mpc8641hpcn: Indicate 36-bit addr map in boot messagesBecky Bruce
If 36-bit addressing is enabled, print a message on the console when we boot. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-22OMAP3: Pandora: Update pin muxDirk Behme
Clock pin must have input enabled for MMC3 to work. Also enable pull-ups for cmd/data lines to be consistent with remaining MMC host pin setup. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2009-02-22OMAP3: Add OMAP3 auto detectionDirk Behme
This patch adds OMAP3 cpu type auto detection based on OMAP3 register and removes hardcoded values. Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-02-22OMAP3: Beagle: Add board revision detectionDirk Behme
With BeagleBoard revision C some HW changes are introduced (e.g. PinMUX) which might need different software handling. For this, GPIO pin 171 (GPIO module 6, offset 11) can be used to check for board revision. If this pin is low, we have a rev C board. Else it must be a revision Ax or Bx board. To handle board differences you can call function beagle_get_revision(). E.g.: if (beagle_get_revision()) { /* do special revision C stuff here */ } Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-02-22OMAP3: Overo: Clean up pin mux and GPIO configurationDirk Behme
* Make Overo GPIO114 an input for touchscreen PENDOWN * Make Overo GPIO144-147 readable * Make Overo EHCI pinmux match beagle rev c setup * Adjust pinmux for SMSC911X network chip support * Remove unnecessary GPIO setup * Fix merge error in Makefile Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-02-22davinci: fix implicit declaration of function 'davinci_errata_workarounds'Jean-Christophe PLAGNIOL-VILLARD
2009-02-22ARM DaVinci: Add common peripherals and modules enable functions.Hugo Villeneuve
Taken all the duplicated code for enabling common modules and apply software workarounds from the board specific code into common functions. Also added comments explaining the workarounds (from TI errata documents) and replaced some numerical bit numbers with more meaningful defines. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2009-02-22Enable Ethernet for Nomadik 8815 Evaluation KitAlessandro Rubini
This trivially enables Ethernet support in the debug board by setting up the proper chip select. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com>
2009-02-22Coding Style cleanup; update CHANGELOGWolfgang Denk
2009-02-1982xx, mgcoge: updates for 2009.03Heiko Schocher
- activate CS4 for accessing the FPGA - activate Rx buf len > 1 on SMC - pram activated - MTDPARTS_DEFAULT defined - update the size of the flashes in the DTS before booting Linux - MONITOR_LEN updated to 384k - added CONFIG_HOSTNAME - added CONFIG_ENV_BUFFER_PRINT - Environment size reduced to 16k Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-198xx, mgsuvd: updates for 2009.03Heiko Schocher
- activate Rx buf len > 1 on SMC - pram activated - MTDPARTS_DEFAULT defined - update the size of the flash in the DTS before booting Linux - MONITOR_LEN updated to 384k - added CONFIG_HOSTNAME - added CONFIG_ENV_BUFFER_PRINT - Environment size reduced to 16k Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-19TQM8xxL: make some room in low memory for future needsWolfgang Denk
THe TQM8xxL use a ahnd-optimized linker script to efficiently use the small boot sectors in the flash. This patch makes some room in the first sector to prepare for a size increase of lib_generic/vsprintf.o by a future patch. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-19Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-02-19Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-02-18Fix build errors after making flash_get_info() non-staticWolfgang Denk
Fix for these build problems: error: static declaration of 'flash_get_info' follows non-static declaration Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-18ppc4xx: Some more PMC405 coding-style cleanupStefan Roese
2009-02-18ppc4xx: Update PMC405 board supportMatthias Fuchs
This patch prepares the good old PMC405 board support for upcoming PMC405V2 patches. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-18ppc4xx: Cleanup PMC405 board supportMatthias Fuchs
This patch fixes coding style for PMC405 board support. Also some unneeded features/code is removed. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-1683xx: Add eSDHC support on 8379 EMDS boardAndy Fleming
2009-02-1685xx: Add eSDHC support for 8536 DSAndy Fleming
2009-02-16TQM85xx: Fix a couple warnings in TQM8548 buildAndy Fleming
The ecm variable in sdram.c was being declared for all 8548, but only used by specific 8548 boards, so we make that variable require those specific boards, too The nand code was using an index "i" into a table, and then re-using "i" to set addresses for each upm. However, then it relied on the old value of i still being there to enable things. Changed the second "i" to "j" Signed-off-by: Andy Fleming <afleming@freescale.com>
