This has not been converted to Generic Board, so should be removed.
(See doc/README.generic-board for details.)
Cc: Stefan Roese <sr@denx.de>
Remove CONFIG_LWMON5 references.
(Also, remove undefined CONFIG_WD_MAX_RATE while I am here.)
These have not been converted to Generic Board, so should be removed.
Cc: Tolunay Orkun <torkun@nextio.com>
Print board revision for cm-fx6.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
On some CM-FX6 modules U-Boot attempts to configure the usb0 controller in
device mode, which renders it unavailable:
USB0: Port not available.
and also causes usb stop to report an error
EHCI failed to shut down host controller.
This happens mostly on MX6 Dual based modules, and is caused by the USBPHY_CTRL
register reporting USBPHY_CTRL_OTG_ID to be 1, even when it is pulled down.
Since we do not support device mode in cm-fx6 u-boot, force all controllers to
be configured as hosts.
there is a 2b board version of the aristainetos2
board. Differences to the v2:
- spi cs for the nor flash and display controller
changed
- some pinmux changes
- LED gpio settings changed
Add SPL boot support for mx6slevk board.
1. Introduce a configuration file mx6slevk_spl_defconfig.
2. i.MX6SL has same DRAM space with i.MX6SX, need to change SPL DRAM SPACE.
3. Include imx6_spl.h and related SPL macro in mx6slevk.h.
4. select SUPPORT_SPL for TARGET_MX6SLEVK.
5. Add SPL board code to do related initialization.
Boot Log:
U-Boot SPL 2015.07-00544-g1594a76 (Aug 17 2015 - 01:56:59)
reading u-boot.img
reading u-boot.img
U-Boot 2015.07-00544-g1594a76 (Aug 17 2015 - 01:56:59 +0000)
CPU: Freescale i.MX6SL rev1.2 996 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C) at 50C
Reset cause: POR
Board: MX6SLEVK
I2C: ready
DRAM: 1 GiB
PMIC: PFUZE100 ID=0x10
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
To i.MX6, DDR3 and LPDDR2 is supported, so rename function mx6_dram_cfg
to mx6_ddr3_cfg and the original mx6_dram_cfg function only is a wrapper.
The new reimplemented function mx6_dram_cfg only invokes mx6_ddr3_cfg
when ddr_type is for DDR3. Later we can use ddr_type to initialize
MMDC for LPDDR2.
Initialize ddr_type for different boards which enable SPL.
Cc: Tim Harvey <tharvey@gateworks.com>
SYS_SOC is already defined in arch/arm/cpu/armv7/mx6/Kconfig, no need to
define it again
Signed-off-by: Soeren Moch <smoch@web.de>
move options from CONFIG_SYS_EXTRA_OPTIONS to board specific Kconfig
some small updates for the aristainetos boards:
- fix display timings for the aristainetos board
- fix pinmux for the aristainetos board
- fix pinmux for the aristainetos2 board
- fix default environment
Add enet support for mx6ul_14x14_evk board:
1. add pinmux settings
2. implement board_eth_init
3. implement board_phy_config
To i.MX6SX/UL, two ethernet interfaces are supported.
Add ENET2 clock support:
1. Introduce a new input parameter "fec_id", only 0 and 1 are allowed.
To value 1, only i.MX6SX/UL can pass the check.
2. Modify board code who use this api to follow new api prototype.
Cc: Nikolaos Pasaloukos <Nikolaos.Pasaloukos@imgtec.com>
This commit adds ethernet support to the TS4800. Note that the
MAC address is not fused on this board and have to be read from
FEC PALR PAUR registers (this is how the kernel provided by
Technologic Systems does it).
signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com>
This commit adds basic support including:
MMC, Serial console, TS4800 watchdog
The config use CONFIG_SKIP_LOWLEVEL_INIT as U-boot is used as a second
stage bootloader.
Signed-off-by: Lucile Quirion <lucile.quirion@savoirfairelinux.com>
Troy Kisky will be maintaining the Nitrogen6x board going forward.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
cgtqmx6eval can be populated with a AR8035 or KSZ9031 depending on the
board revision.
Add Ethernet support.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
This patch removes the SPI support from the WRU-IV baseboard as its
not used at all.
Cc: Clemens Gruber <clemens.gruber@pqgruber.com>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Tested-by: Clemens Gruber <clemens.gruber@pqgruber.com>
Reviewed-by: Jagan Teki <jteki@openedev.com>
Currently we need to build one U-boot image for each of the udoo
variants: quad and dual-lite.
By switching to SPL we can support all two variants with a single binary.
Based on the SPL for wandboard.
Tested with OpenELEC (Open Embedded Linux Entertainment Center)
on both boards.
Signed-off-by: Peter Vicman <peter.vicman@gmail.com>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
DEVDISRn registers provides a mechanism for gating clocks of IP blocks
that are not used. Here we implement hwconfig option to allow users
to disable unused peripherals on the board.
For ex. If eSDHC/qDMA/eDMA are unused and with disabled status in dts,
User can enable CONFIG_FSL_DEVICE_DISABLE and set "devdis:esdhc,qdma,edma"
in hwconfig, thus ESDHC controller & eDMA/qDMA will be clock gated to
save more power.
Signed-off-by: Zhuoyu Zhang <Zhuoyu.Zhang@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
The emulator with DDR3 model was used during model bringup. DDR4
controllers are used with ls2085a. Drop the DDR4 target defconfig
and enable DDR4 in ls2085a_emu_defconfig.
Signed-off-by: York Sun <yorksun@freescale.com>
Replace the DMACTRL[LE] hack with recommended settings
for ETSECDMAMCR to get the same end effect - obtaining
big-endian buffer descriptors and frame data for eTSEC.
The reset / default value for ETSECDMAMCR is preserved,
excepting the BD and FR bits which are cleared to enable
the BE mode in accordance with the H/W specifications.
Fixes: 52d00a8 "ls102xa: etsec: Add etsec support for LS102xA"
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
Acked-by: Alison Wang <alison.wang@freescale.com>
Tested-by: Alison Wang <alison.wang@freescale.com>
The X-QSGMII-16PORT is a 4xQSGMII/8xSGMII riser card with eighth SerDes
interfaces implemented in PCIe form factor board.
It supports followings
- Card can operate with up to 4 QSGMII lane simultaneously
- Card can operate with up to 8 SGMII lane simultaneously
Add support of X-QSGMII-16PORT riser card.
This patch also take care of back-ward compatiblity with old SGMII rise cards
used on LS2085QDS Platform.
Signed-off-by: King Chung Lo@freescale.com <KingChungLo@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Per new requirement, change default core frequency
from previous 1400MHz to 1200MHz to save power.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Previously the DDR4 targets were named with _D4. Rename them with
_DDR4 for easy identification.
If board uses downstream Chrome OS U-Boot as first stage
bootloader and upstream version is chained second stage,
1.1V is minimum voltage borderline.
Signed-off-by: Misha Komarovskiy <zombah@gmail.com>
The boards are sorted by SoC, move the Mele_A1000G_quad entry to the list
of sun6i boards where it belongs.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
The inet98v_rev2 is a pcb used in generic A13 based tablets. It features
volume buttons, a power barrel, micro-usb otg, headphone connector and
a power button.
The dts file is identical to the one submitted to the upstream kernel.
The inet97fv2 is a board found in the first generation of cheap allwinner
A10 based 7" tablets.
Note that this patch does not add a dts file as we already have one from
our dts syncs with the kernel.
We eventually want to add full nand support, since it makes no sense
to build SPL with nand support and u-boot without, or the other way
around, a single option will suffice.
Renaming the Kconfig option now makes things easier when we add full
nand support in the future.
The "obj-$(CONFIG_NAND_SUNXI) += sunxi_nand_spl.o" is moved to an
"ifdef CONFIG_SPL_BUILD" block in the Makefile.
Other then having a few less chip-select lines the nand controller
on sun4i, sun5i and sun7i is identical.
Note this patch also muxes GPC7 to the NAND on sun7i where as before
it was not muxed this way. GPC7 is a standard NAND pin, so it should
always be muxed to the NAND when in use.
We use DMA for nand data transfers in the SPL, so make sure the DMA
controller is enabled.
Use SYS_NAND_SELF_INIT and only setup the pinmux and clocks when we are
actually using the nand.
With the unified / cleaned up default display output selection changes,
which were done as part of adding composite video out support, our
example LCD_MODE line in the A13-OLinuxIno defconfigs causes the display
code to setup a LCD console by default, rather then a VGA console.
Given that the LCD console is only useful for people who have hooked up
the exact lcd-panel from the config, while most people will not have any
lcd panel connected to these boards, this is not a good default.
Dropping the LCD_MODE line which was intended as an example fixes this,
instead add a link to the LCD_MODE help text pointing to
http://linux-sunxi.org/LCD which contains the removed and other example
modes.
The gt90h is a pcb found in generic 9" tablets with an A23 soc, 1G RAM
and 8G nand, rtl8723as usb wifi, 1 micro usb port and 1 micro sd slot.
The pmic setup on this board is somewhat special, dcdc2 MUST be set
to 1.1V instead of the usual 1.2V otherwise the board is very unstable.
aldo1 is used to power the micro sd slot, dldo1 is used for wifi.
This commit adds a defconfig + dts (as submitted to the kernel) for
the gt90h-v4 pcb.
Allow specifying the axp221 dcdc2 voltage via Kconfig, this is necessary
because on some boards the 1.2V default does not work reliable.
invoke enable_usb_clocks during board_usb_init and disable_usb_clocks
during board_usb_exit to enable and disable clocks respectively.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Implemented board_usb_init(), board_usb_cleanup() and
usb_gadget_handle_interrupts() in omap5 board file that
can be invoked by various gadget drivers.
usb_gadget_handle_interrupts() in beagle_x15 board file that
vbus_id_status is initialized in board_usb_init. So remove it
while creating dwc3_device objects.
