path: root/board
2009-01-24Renamed cpu/i386/reset.S to resetvec.SGraeme Russ
Brings i386 in line with other CPUs with a reset vector and frees up reset.c for CPU reset functions Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Added initial eNET board supportGraeme Russ
2009-01-24powerpc: keymile: Add a check for the PIGGY debug boardHeiko Schocher
Check the presence of the PIGGY on the keymile boards mgcoge, mgsuvd and kmeter1. If the PIGGY is not present, dont register this Ethernet device. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-24powerpc: 83xx: add support for the kmeter1 boardHeiko Schocher
This patch adds support for the kmeter1 board from Keymile, based on a Freescale MPC8360 CPU. - serial console on UART 1 - 256 MB DDR2 RAM - 64 MB NOR Flash - Ethernet RMII Mode over UCC4 - PHY SMSC LAN8700 Signed-off-by: Heiko Schocher <hs@denx.de>
2009-01-23microblaze: Change microblaze-generic config fileMichal Simek
2009-01-23microblaze: Rename ml401 to microblaze-genericMichal Simek
2009-01-16Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2009-01-16sh: Fix compile error on lowlevel_init fileNobuhiro Iwamatsu
lowlevel_init of SH was corrected to use the write/readXX macro. However, there was a problem that was not able to be compiled partially. This patch corrected this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: Fix up rsk7203 target for out of tree buildKieran Bingham
Fix up rsk7203 target to build successfully using out-of-tree build. Signed-off-by: Kieran Bingham <kbingham@mpc-data.co.uk> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: use write{8,16,32} in all lowlevel_initJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: lowlevel_init coding style cleanupJean-Christophe PLAGNIOL-VILLARD
2009-01-14ppc4xx: Add loadpci command to esd's CPCI4052 and CPCI405AB boardsMatthias Fuchs
This patch adds esd's loadpci BSP command to CPCI4052 and CPCI405AB board. This requires CONFIG_CMD_BSP and CONFIG_PRAM. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-14ppc4xx: Disable pci node in device tree on CPCI405 pci adaptersMatthias Fuchs
2009-01-14ppc4xx: Cleanup CPCI405 board codeMatthias Fuchs
This patch cleans up CPCI405 board support: - wrap long lines - unification of spaces in function calls - remove dead code Use correct io accessors on peripherals. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-14ppc4xx: Enable auto RS485 mode on PLU405 boardsMatthias Fuchs
This patch turns on the auto RS485 mode in the 2nd external uart on PLU405 boards. This is a special mode of the used Exar XR16C2850 uart. Because these boards only have a 485 physical layer connected it's a good idea to turn it on by default. Signed-off-by: Matthias Fuchs <mf@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-14Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-01-13Some changes of TLB entry setting for MPC8572DSHaiying Wang
- Move the TLB entry of PIXIS_BASE from TLB0 to TLB1[8], because in CAMP mode, all the TLB0 entries will be invalidated after cpu1 brings up kernel, thus cpu0 can not access PIXIS_BASE anymore (any access will cause DataTLBError exception) - Set CONFIG_SYS_DDR_TLB_START to 9 for MPC8572DS board. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2009-01-13Change PCIE1&2 deciide logic on MPC8544DS board more readableRoy Zang
The IO port selection for MPC8544DS board: Port cfg_io_ports PCIE1 0x2, 0x3, 0x4, 0x5, 0x6, 0x7 PCIE2 0x4, 0x5, 0x6, 0x7 PCIE3 0x6, 0x7 This patch changes the PCIE12 and PCIE2 logic more readable. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2009-01-13PCIE2 and PCIE3 are decided by corresponing bit in devdisr instead of PCIE1 bitRoy Zang
PCIE2 and PCIE3 should be decided by corresponing bit in devdisr instead of PCIE1 bit. On MPC8572DS board, PCIE refers to PCIE1. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2009-01-13Fix IO port selection issue on MPC8544DS and MPC8572DS boardsRoy Zang
The IO port selection is not correct on MPC8572DS and MPC8544DS board. This patch fixes this issue. For MPC8572 Port cfg_io_ports PCIE1 0x2, 0x3, 0x7, 0xb, 0xc, 0xf PCIE2 0x3, 0x7 PCIE3 0x7 For MPC8544 Port cfg_io_ports PCIE1 0x2, 0x3, 0x4, 0x5, 0x6, 0x7 PCIE2 0x4, 0x5, 0x6, 0x7 PCIE3 0x6, 0x7 Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2009-01-13mpc8610hpcd: Fix PCI mapping conceptsBecky Bruce
Rename _BASE to _BUS, as it's actually a PCI bus address, separate virtual and physical addresses into _VIRT and _PHYS, and use each appopriately. This makes the code easier to read and understand, and facilitates mapping changes going forward. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-01-13sbc8641d: Fix PCI mapping conceptsBecky Bruce
2009-01-10Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2009-01-07bf537-stamp/nand: fix board_nand_init prototypeMike Frysinger
The board_nand_init() function should return an int, not void. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix out-of-tree building with ldscriptsMike Frysinger
Many of the Blackfin board linker scripts are preprocessed, so make sure we output the linker script into the build tree rather than the source tree. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix linker scripts to work with --gc-sectionsMike Frysinger
Make sure all .text sections get pulled in and the entry point is properly referenced so they don't get discarded when linking with --gc-sections. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: set proper LDRFLAGS for parallel booting LDRsMike Frysinger
In order to boot an LDR out of parallel flash, the ldr utility needs a few flags to tell it to generate the right header. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-06m501sk: move to the common memory setupJean-Christophe PLAGNIOL-VILLARD
2009-01-06at91rm9200: rename lowlevel init value to CONFIG_SYS_Jean-Christophe PLAGNIOL-VILLARD
2008-12-2985xx: Enable inbound PCI config cycles for X-ES boards cleanupPeter Tyser
2008-12-29XPedite5200 board support cleanupPeter Tyser
2008-12-19mpc8xxx: LCRR[CLKDIV] is sometimes five bitsTrent Piepho
On newer CPUs, 8536, 8572, and 8610, the CLKDIV field of LCRR is five bits instead of four. In order to avoid an ifdef, LCRR_CLKDIV is set to 0x1f on all systems. It should be safe as the fifth bit was defined as reserved and set to 0. Code that was using a hard coded 0x0f is changed to use LCRR_CLKDIV. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-12-19XPedite5200 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5200 - a MPC8548-based PMC single board computer. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-1985xx: Enable inbound PCI config cycles for X-ES boardsPeter Tyser
Update X-ES Freescale boards to allow inbound PCI configuration cycles when configured as agent/endpoint. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-19XPedite5370 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5370 - a MPC8572-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-16board/trab/memory.c: Fix compile problems.Wolfgang Denk
Apply changes from commit 44b4dbed to board/trab/memory.c, too. Actually we'd need a major cleanup here - as it turns out, board/trab/memory.c is more or less a verbatim copy of post/drivers/memory.c ... but then, trab is EOL anyway,r so this is not worth the effort. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-16Merge branch 'master' of ssh://gemini/home/wd/git/u-boot/masterWolfgang Denk
2008-12-16trab: make trab_fkt standalone code independent of libgccWolfgang Denk
Use our own local functions in lib_arm/ instead. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-16Coding style cleanup, update CHANGELOG.Wolfgang Denk
2008-12-14Fix new found CFG_Jean-Christophe PLAGNIOL-VILLARD
Also fix some minor typos. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-13Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2008-12-13Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2008-12-10ppc4xx: Disable EEPROM write access on PMC440 boardsMatthias Fuchs
This patch disables EEPROM wrtie access by default on PMC440 board. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-12-10ppc4xx: Fix Ethernet PHY LED configuration on PMC440 boardsMatthias Fuchs
2008-12-10sh: r2dplus fix register accessJean-Christophe PLAGNIOL-VILLARD
2008-12-10sh: r2dplus/lowlevel_init: coding style fixJean-Christophe PLAGNIOL-VILLARD
2008-12-10sh: Migo-R: Update BSC valueNobuhiro Iwamatsu
A value of BSC CS4 was wrong, Fixed it. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-12-10ppc4xx: Update TEXT_BASE for CPCI405 boardsMatthias Fuchs
This patch fixes building U-Boot for CPCI405 boards. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-12-10microblaze: Remove XUPV2P boardMichal Simek
--- Microblaze platforms use generic settings and to have many platforms is confusing that's why I decided to remove this platform from U-BOOT. ml401 tree is sufficient for covering all Microblaze platforms. This change will go through microblaze custodian tree.
2008-12-09evb64260: fix "cast to pointer from integer of different size" warningsWolfgang Denk
