PRU ethernet MAC address range is present in the
board EEPROM. Parse it and setup eth?addr
environment variables.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
In stead of defining the board EEPROM address in the board headers
let's define them in the board config files and make them
configurable by Kconfig.
AM571x IDK and AM572x IDK have optional LCD Kits that can be purchased.
These can be one of OSD101T2045 or the newer OSD101T2587. The LCD panel
itself has no registers that can be used to identify the panel, however,
the touchscreen controllers on the panels are different.
Hence to ease user experience, we can use the touch screen controller's
ID information to detect what kind of panel we use and select the
appropriate kernel dtb for the platform configuration.
NOTE: AM572x IDK default configuration is for LCD Connectivity, however
the AM571x IDK has a jumper (J51) that needs to be mounted for the IDK
to operate with LCD (Vs two PRUSS ethernet port option).
Touchscreen ID information is documented in:
http://www.osddisplays.com/TI/OSD101T2587-53TS_A.1.pdf
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Use the same convention that was used for ICSS1 Ethernet
- If pin is output, set as PIN_OUTPUT
- If pin is input and external pull resistor present set as PIN_INPUT
- If pin is input and external pull resistor absent, set pull to same
as that of the external PHY's internall pull.
The board can support either ICSS1 Ethernet ports or LCD
based on J51 jumper. Factory default is ICSS1 Ethernet ports
(i.e. Jumper not populated).
Use the GPIO to detect the jumper setting and configure the
pinmux accordingly. Also select the right DT blob based on
the chosen configuration.
J51 absent -> ICSS1 Ethernet, no LCD on VOUT -> am571x-idk.dtb
J51 present -> LCD on VOUT, no ICSS1 Ethernet -> am571x-idk-lcd-osd.dtb
At present we only support the assume it is the Legacy LCD.
LCD detection mechanism needs to be added later to differentiate
between legacy vs new LCD.
For ICSS1 Ethernet pins use the following convention to set the pinmux
as PMT data is not yet finalized.
- Do not use SLEW_CONTROLon any pin.
Cc: Nishanth Menon <nm@ti.com>
Keystone and OMAP platforms will need this to set ethernet
MAC addresses from board EEPROM.
Non OMAP platforms i.e. Keystone will also need to use the board
EEPROM helpers so let's make the macro platform independent.
To keep a consistent MMC device mapping in SPL and in u-boot, let's
register the MMC controllers the same way in u-boot and in the SPL.
In terms of boot time, it doesn't hurt to register more controllers than
needed because the MMC device is initialized only prior being accessed for
the first time.
Having the same device mapping in SPL and u-boot allows us to use the
environment in SPL whatever the MMC boot device.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
configs/bk4r1_defconfig
configs/colibri_vf_defconfig
configs/pcm052_defconfig
include/configs/colibri_vf.h
include/configs/pcm052.h
Prepare for boards with EMMC instead of NAND flash
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Move Freescale/NXP Vybrid to a standard arch/board approach, similar
to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM:
mx6: move to a standard arch/board approach").
Reviewed-by: Stefano Babic <sbabic@denx.de>
- 64bit 8gB density (4GiB) IMX6DQ
- 64bit 4gB density (2GiB) IMX6SDL
Use device-tree fixup to communicate the MTD partitions to the
kernel. Remove mtdparts from the kernel command line.
Disable 3.3V Ethernet and ARM rail when entering sleep mode.
Implement board level USB PHY mode callback. On USB OTG Port 1
the Colibri standard foresees GPIO USBC_DET to decide whether the
port should run in Host or Device mode.
OPOS6UL is an i.MX6UL based SoM with 256MB RAM, 4GB eMMC and an ethernet
phy. OPOS6ULDev is carrier board for the OPOS6UL.
U-Boot SPL 2017.03-rc3-00002-g5085c26 (Mar 07 2017 - 09:48:09)
Trying to boot from MMC1
U-Boot 2017.03-rc3-00002-g5085c26 (Mar 07 2017 - 09:48:09 +0100)
CPU: Freescale i.MX6UL rev1.0 528 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 40C
Reset cause: POR
Model: Armadeus Systems OPOS6UL SoM on OPOS6ULDev board
DRAM: 256 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Video: 800x480x18
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
This includes support for rk3188 from Heiko Stübner and and rk3328 from
Kever Yang. Also included is SPL support for rk3399 and a fix for
rk3288 to get it booting again (spl_early_init()).
It also removes the qspi pin configuration done during the
board initialization.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
It also removes the ethernet pin configuration done during the board
initialization.
And remove the uart pin configuration from board initialization.
Before clock driver availability it was required to enable usart1 clock
for serial init but now with clock driver is taking care of usart1 clock.
This patch adds device tree support for stm32f7 serial driver & removes serial
platform data structure.
This adds support for TQMa6DL using i.MX6DL and 1GiB DRAM
Since The module will use the same devicetree, we patch
the ram size in ft_board_setup.
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
We have a Kconfig name for the module types. Let's Use it.
Some feature selections and configurations are based on the
module. Module selection selects the CPU type.
Add board_mmc_get_env_dev
Switch the mmc env based on the mmc devno, instead of separately
defining a config item in include/configs using board_mmc_get_env_dev
- devno 0: sd/esd
- devno 1: mmc/emmc
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Let the runtime code can set the mmcdev and mmcroot based
on the devno using mmc_get_env_dev instead of defining
separately in build-time configs using mmc_late_init func.
Add runtime, modeboot env which is setting mmcboot based
on the bootdevice so-that conditional macros for MMC via
CONFIG_BOOTCOMMAND should be avoided in config files.
Boot from eMMC:
U-Boot SPL 2017.01-00318-g8e243f8 (Jan 26 2017 - 11:53:21)
Trying to boot from MMC2
U-Boot 2017.01-00318-g8e243f8 (Jan 26 2017 - 11:53:21 +0100)
CPU: Freescale i.MX6D rev1.2 at 792 MHz
Reset cause: POR
Model: Engicam i.CoreM6 Quad/Dual RQS Starter Kit
DRAM: 512 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1(part 0) is current device
Net: No ethernet found.
Booting from mmc ...
we have external ref clock from phy.
fix the reset delay which was to short
Since the CS are not in use, do not map them. User of starterkit
mainboard is free to use them otherwise. When using these pins later
in the OS for instance as GPIO IRQ pin, they need to be input.
The current driver stength is too high, leading to spec violations
on the falling edge. Fix it with values from HW
PMIC implements proper I2C bus switching,
implement power_init_board instead handling in
board_late_init.
SPL mmc device index is get based on the boot device, like
- BOOT_DEVICE_MMC1 for mmc device 0
- BOOT_DEVICE_MMC2 for mmc device 1
Currently BOOT_DEVICE_MMC1 is setting both SD/eSD and MMC/eMMC
boot devices in i.MX, So u-boot is loading from mmc device 0 even
"if the board booting from SD/eSD or MMC/eMMC"
So, this patch set BOOT_DEVICE_MMC2 for MMC/eMMC so for MMC/eMMC
the u-boot is loading from mmc device 1 and the board file need to
take care if the board have different mmc device order intialization.
Reviewed by: Stefano Babic <sbabic@denx.de>
- devno 0: sd/esd
- devno 1: mmc/emmc
Add runtime, modeboot env which is setting mmcboot, or
nandboot based on the bootdevice so-that conditional
macros b/w MMC and NAND for CONFIG_BOOTCOMMAND should
Boot from eMMC:
U-Boot SPL 2017.01-00314-gd0cd9cd-dirty (Jan 25 2017 - 13:25:27)
U-Boot 2017.01-00314-gd0cd9cd-dirty (Jan 25 2017 - 13:25:27 +0100)
CPU: Freescale i.MX6UL rev1.1 528 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 36C
Reset cause: POR
Model: Engicam Is.IoT MX6UL eMMC Starterkit
DRAM: 512 MiB
In: serial
Out: serial
Err: serial
dts files related to i.MX6 engicam boards are maintined
under board, so include them under board/engicam/*/MAINTAINERS
Add NAND support for Engicam Is.IoT MX6UL board.
Boot from MMC:
U-Boot SPL 2017.01-rc2-gba3c151-dirty (Jan 02 2017 - 16:59:33)
U-Boot 2017.01-rc2-gba3c151-dirty (Jan 02 2017 - 16:59:33 +0100)
CPU: Industrial temperature grade (-40C to 105C) at 33C
Reset cause: POR
Model: Engicam Is.IoT MX6UL Starterkit
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
isiotmx6ul>
Add EVK board support.
Add the evk dts file.
LOG:
U-Boot 2017.03-rc2-00038-gab86c1d (Feb 22 2017 - 15:59:58 +0800)
CPU: Freescale i.MX7ULP rev1.0 at 500 MHz
Reset cause: POR
Boot mode: Dual boot
Model: NXP i.MX7ULP EVK
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial@402D0000
Out: serial@402D0000
Err: serial@402D0000
Net: Net Initialization Skipped
No ethernet found.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
evb-rk3328 is an evb from Rockchip based on rk3328 SoC:
- 2 USB2.0 Host port;
- 1 USB3.0 Host port;
- 1 HDMI port;
- 2 10/100M eth port;
- 2GB ddr;
- 16GB eMMC;
- UART to USB debug port;
Signed-off-by: William Zhang <william.zhang@rock-chips.com>
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
