Unlike Linux Kernel, U-Boot historically had *.dts files under
board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/.
I think arch/$(ARCH)/dts dicretory is a better location
to store both *.dts and *.dtsi files.
For example, before this commit, board/xilinx/dts directory
had both Microblaze dts (microblaze-generic.dts) and
ARM dts (zynq-*.dts), which are totally unrelated.
This commit moves *.dts to arch/$(ARCH)/dts/ directories,
allowing us to describe nicely mutiple DTBs generation in the next commit.
We had switched to Kbuild, so we do not need to
delete sandburst board files at every build.
U-Boot conventional build system did not check the
update of command line option, -DBUILDUSER.
Kbuild can handle it nicely and re-builds object files
when command line options are changed.
(The file ".*.cmd" stores the information how the file
was generated at the previous build.)
This commit refactors cleaning targets such as
clean, clobber, mrpropper, distclean
with scripts/Makefile.clean.
By using scripts/Makefile.clean, we can recursively descend
into subdirectories and delete generated files there.
We do not need add a big list of generated files
to the "clean" target.
Now we are ready to switch over to real Kbuild.
This commit disables temporary scripts:
scripts/{Makefile.build.tmp, Makefile.host.tmp}
and enables real Kbuild scripts:
scripts/{Makefile.build,Makefile.host,Makefile.lib}.
This switch is triggered by the line in scripts/Kbuild.include
-build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj
+build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj
We need to adjust some build scripts for U-Boot.
But smaller amount of modification is preferable.
Additionally, we need to fix compiler flags which are
locally added or removed.
In Kbuild, it is not allowed to change CFLAGS locally.
Instead, ccflags-y, asflags-y, cppflags-y,
CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o
are prepared for that purpose.
Tested-by: Gerhard Sittig <gsi@denx.de>
We are going to switch over to Kbuild in upcoming commits.
Each makefile must have non-empty obj- or obj-y
to generate built-in.o on Kbuild.
This commit changes the working directory
where the build process occurs.
Before this commit, build process occurred under the source
tree for both in-tree and out-of-tree build.
That's why we needed to add $(obj) prefix to all generated
files in makefiles like follows:
$(obj)u-boot.bin: $(obj)u-boot
Here, $(obj) is empty for in-tree build, whereas it points
to the output directory for out-of-tree build.
And our old build system changes the current working directory
with "make -C <sub-dir>" syntax when descending into the
sub-directories.
On the other hand, Kbuild uses a different idea
to handle out-of-tree build and directory descending.
The build process of Kbuild always occurs under the output tree.
When "O=dir/to/store/output/files" is given, the build system
changes the current working directory to that directory and
restarts the make.
Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>"
syntax for descending into sub-directories.
(We can write it like "make $(obj)=<sub-dir>" with a shorthand.)
This means the current working directory is always the top
of the output directory.
Some Samsung boards have their own tools under board/samsung/<board>/tools/.
This commit refactor more makefiles with "hostprogs-y".
Add the SATA boot support for OMAP5 and dra7xx.
Renamed the omap_sata_init to the common init_sata(int dev)
for commonality in with sata stack.
Added the ROM boot device ID for SATA.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Reviewed-by: Roger Quadros <rogerq@ti.com>
This commit removes platform CONFIG_SYS_HZ definition for the
remainders of part1 (commit cdb23792) and part2 (commit f232950f).
Cc: Rob Herring <rob.herring@calxeda.com>
KMSUGP1 is from a u-boot perspective (almost) identical to KMNUSA.
The only difference is that the PCIe reset is connected to Kirkwood pin
MPP7_PEX_RST_OUTn, we use a dedicated config flag KM_PCIE_RESET_MPP7.
Such pin should theoretically be handled by the PCIe subsystem
automatically, but this turned out not to be the case.
So simply configure this PIN as a GPIO and issue a pulse manually.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Cc: Karlheinz Jerg <karlheinz.jerg@keymile.com>
Cc: Valentin Longchamp <valenting.longchamp@keymile.com>
Cc: Holger Brunck <holger.brunck@keymile.com>
Acked-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Add set_fdthigh subcommand to "subbootcmds" (release) so to set "fdt_high"
This is necessary on Kirkwood so that the FDT does not get relocated
above the memory limit that the kernel cannot access
(that is the memory part reserved for the switch).
This was tested on NUSA1, where it is necessary, and on ETER1, where it
doesn't seem to hurt.
We want the scripts to also work with older versions of u-boot, where:
a) set_fdthigh is not defined (will be default env for newer u-boots)
b) the fdt will not be available
For this reason, we use "set_fdthigh" to tell whether we are running
a newer (FDT-aware) u-boot or not.
So if "set_fdthigh" runs successfully or arch != arm we try loading
the fdt; otherwise we proceed normally.
Notice how, contrary to release mode, set_fdthigh will _not_ be part of
subbootcmds for develop and ramfs, but will be executed as part of
"tftpfdt".
Since this is only needed for kirkwood cards, and it prevents the kernel
from booting on QorIQ (though it seemed to work on ETER1), we change
its definition in the default env for powerpc so that the value is only
set on ARM.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This consists of:
a) Defining the addresses, enabling fdtsupport [arm]
b) Defining "cramfsloadfdt" [arm,powerpc => common]
c) Adding the FDT address to bootm [arm,powerpc => common]
d) Defining "tftpfdt" in ramfs-,develop- [arm,powerpc >= common]
This should work with 3.10 kernels, whether loaded through TFTP
(with rootfs either through NFS or TFTP-ramfs) or from the NAND.
The machid was left unchanged, this should keep compatibility with both
older and newer kernels.
miiphy_read and miiphy_write are returning 0 on success.
CONFIG_BOOTCOUNT_LIMIT is used on all boards from this board series. So
remove this unneeded define.
Add a README to the board which lists the commands required to enable
booting from the eMMC boot partitions found on the board.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
With this change driver will benefit from existing phylib and thus
custom phy functionality implemented in the driver will go away:
* Instantiation of the driver is now much shorter - 2 parameters
instead of 4.
* Simplified phy management/functoinality in driver is replaced with
rich functionality of phylib.
* Support of custom phy initialization is now done with existing
"board_phy_config".
Note that after this change some previously used config options
(driver-specific PHY configuration) will be obsolete and they are simply
substituted with similar options of phylib.
For example:
* CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled
by default.
* CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy
explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise
automatically the first discovered on MDIO bus phy will be used
I believe there's no need now in "doc/README.designware_eth" because
user only needs to instantiate the driver with "designware_initialize"
whose prototype exists in "include/netdev.h".
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Mischa Jonker <mjonker@synopsys.com>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
AXS101 is a new generation of devlopment boards from Synopsys that houses
ASIC with ARC700 and lots of DesignWare peripherals:
* DW APB UART
* DW Mobile Storage (MMC/SD)
* DW I2C
* DW GMAC
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Francois Bedard <fbedard@synopsys.com>
Arcangel4 is a FPGA-based development board that is used for prototyping and
verificationof of both ARC hardware (CPUs) and software running upon CPU.
This board avaialble in 2 flavours:
* Little-endian (arcangel4)
* Big-endian (arcangel4-be)
This patch adds variables describing platform (soc, board, vendor)
to default environment.
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: Przemyslaw Marczak <p.marczak@samsung.com>
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Mateusz Zalega <m.zalega@samsung.com>
This patch sets envs that describe board information.
The following envs are set: soc_id, soc_rev, board_rev.
Based on this information, if CONFIG_OF_LIBFDT is enabled,
the 'fdtfile' env is set as:
fdtfile=${soc_family}${soc_id}-${board}.dtb
The generated envs are intenionally not saved to persistent storage.
Just extend tables with this new device.
The mv_udc is not marvell-specific anymore. The mv_udc is used to drive
generic ChipIdea CI13xxx series OTG cores, so rename the driver to ci_udc
instead.
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
These are the board files for Venice2 (Tegra124), plus the AS3722 PMIC
files. PMIC init will be moved to pmic_common_init later.
This builds/boots on Venice2, SPI/MMC/USB/I2C all work. Audio, display
and WB/LP0 are not supported yet.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Tested-by: Thierry Reding <treding@nvidia.com>
These are fairly complete, and near-clones of Tegra114 Venice, with an
additional I2C port, and MMC address changes for Tegra124.
__pinmux_nand() won't compile if PERIPH_ID_NDFLASH isn't defined.
Prevent this from causing build problems on newer SoCs without NAND
support (or without SW support for NAND yet), but preventing
compilation unless the function will actually be used, i.e. when
CONFIG_TEGRA_NAND is defined.
[swarren, rewrote commit description, moved ifdef around whole function
rather than just body]
The PEXHC PCIe configuration mechanism ensures that the FPGA get
configured at power-up. Since all the PCIe devices should be configured
when the kernel start, u-boot has to take care that the FPGA gets
configured also in other reset scenarios, mostly because of possible
configuration change.
The used mechanism is taken from the km_kirkwood design and adapted to
the kmp204x case (slightly different HW and PCIe configuration).
Reviewed-by: York Sun <yorksun@freescale.com>
On the previous HW revision (now unsupported), there was a need for
external DMA signals and thus the I2C3/4 signals were used
DMA1_DONE/ACK/REQ.
These signals now are configured as GPIO[16:19].
According to the errata, some bits of an undocumented register in the
DCSR must be set for every core in order to avoid a possible data or
instruction corruption.
This is required for the 2.0 revision of the P2041 that should be used
as soon as available in our design.
This patch adds support for using some GPIOs that are connected to the
I2C bus to force the bus lines state and perform some bus deblocking
sequences.
The KM common deblocking algorithm from board/keymile/common/common.c is
used. The GPIO lines used for deblocking the I2C bus are some external
GPIOs provided by the QRIO CPLD:
- SCL = GPIOA_20
- SDA = GPIOA_21
The QRIO GPIOs act in an open-drain-like manner, for 0 the line is
driven low and for 1 the GPIO is set as input and the line gets
pulled-up.
Signed-off-by: Rainer Boschung <rainer.boschung@keymile.com>
The QRIO GPIO functions can be of general interest. They are thus added
to a qrio.c and their prototype are available from kmp204x.h. The QRIO
prst function are also included in this file, as well as the functions
required for the I2C deblocking support (open-drain).
[York Sun: Remove extra blank line in board/keymile/kmp204x/qrio.c]
Signed-off-by: York Sun <yorksun@freescale.com>
Make use of the QRIO1 32bit register at 0x20 as bootcounter register
Check for BOOTCOUNT_MAGIC pattern when before bootcounter value is read
[York Sun: Minor change to commit message]
This covers only non-L2 switch ethernet interfaces i.e.
RGMII and SGMII interface for both T1040RDB and T1042RDB_PI
T1040RDB is configured as serdes protocol 0x66 which can
support following interfaces
2 RGMIIS on DTSEC4, DTSEC5
1 SGMII on DTSEC3
T1042RDB_PI is configured as serdes protocol 0x06 which can
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
[York Sun: Minor change in commit message]
Enable entherent for T1040QDS. It enables FM1@DTSEC3, FM1@DTSEC4, FM1@DTSEC5
Define MDIO related configs
Added eth.c file
Update t1040.c to support RGMII and SGMII
Update t1040qds.c to support ethernet
Define the PHY address
Signed-off-by: Arpit Goel <B44344@freescale.com>
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
[York Sun: remove dash from commit message]
Due to increased size of u-boot, FMAN ucode start address has been shifted
by 256KB causing a overlap with rootfs start address.
Update rootfs start address to reflect correct memory map.
Also fix minor typo in README
This change allows updating environment stored on MMC by dfu or thor.
New setting:
- "params.bin mmc 0x38 0x8"
File params.bin can be generated by: tools/mkenvimage.
e.g. ./mkenvimage -s 4096 -o params.bin <env_text_file>
Every new env variable in text file should start with a new line.
Sample env text file:
- board/samsung/common/dfu_sample_env.txt
Requirements:
- file name: "params.bin"
- file size: 4096 Bytes - the same as CONFIG_ENV_SIZE.
Other size will cause CRC miscalculation at boot.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
CC: Piotr Wilczek <p.wilczek@samsung.com>
CC: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
This simple LCD menu allows run one of download mode on device
without writing on console or for fast and easy upgrade.
This feature check user keys combination at boot:
- power key + volume up - download menu
- power key + volume down - thor mode (without menu)
New configs:
- CONFIG_LCD_MENU
- CONFIG_LCD_MENU_BOARD
For proper effect this feature needs following definitions:
Power key:
- KEY_PWR_PMIC_NAME - (string) pmic which supports power key check
Register address:
- KEY_PWR_STATUS_REG
- KEY_PWR_INTERRUPT_REG
Register power key mask:
- KEY_PWR_STATUS_MASK
- KEY_PWR_INTERRUPT_MASK
Gpio numbers:
- KEY_VOL_DOWN_GPIO
Functions needs to be called:
- keys_init() - for set proper gpio direction
- check_boot_mode() - menu - main function
16 bpp mode is required by LCD console mode.
This change updates exynos board files.
Changes:
- check image bpp instead of resolution when returns logo address
- remove 32bpp logo
- add 16bpp logo in two formats: bmp and gzipped bmp
- init logo address with "0" for unsupported bpp mode
- update boards configs with proper image size for gunzip
- extend structure vidinfo by two fields: logo_x_offset and logo_y_offset.
Tested-by: Hyungwon Hwang <human.hwang@samsung.com>
