commit b689cd5 OMAP3: use a single board file for IGEP devices
introduced the following build warning:
igep00x0.h:168:24: warning: backslash-newline at end of file [enabled
by default]
This patch fixes the issue.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
AM335x EVM 1.5A uses Micron MT41J512M8RH-125 SDRAM 4Gb (512Mx8) as the
DDR3 chip.
[Hebbar Gururaja <gururaja.hebbar@ti.com>]
- Resolve merge conflict while rebasing. File structure is
changed in the mainline. So re-arrange the code accordingly.
- Update commit message to reflect the DDR3 part number
Signed-off-by: Jeff Lance <j-lance1@ti.com>
Signed-off-by: Hebbar Gururaja <gururaja.hebbar@ti.com>
When ethaddr is not set in environment the MAC address is read
from efuse. The message was only printed in debug case, but this
message could be of interest for the ordinary user, so printf it.
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
The board is named pcm051 and has this hardware:
SOC: TI AM3359
DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB
ETH 1: LAN8710AI
SPI-Flash: W25Q64BVSSIG
RTC: RV-4162-C7
I2C-EEPROM: CAT32WC32
NAND: MT29F4G08_VFPGA63
PMIC: TPS65910A3
LCD
Supported:
UART 1
MMC/SD
ETH 1
USB
I2C
SPI
Not yet supported:
NAND
RTC
LCD
[trini: Add #define CONFIG_PHY_ADDR 0 to config]
This patch adds an GPIO LED boot status for IGEP boards.
The GPIO LED used is the red LED0 while the Linux kernel
uses the green LED0 as the boot status.
By using different GPIO LEDs, the user can know in which
step of the boot process the board currently is.
Even when the IGEPv2 board and the IGEP Computer-on-Module
are different from a form factor point of view, they are
very similar in the fact that share many components and how
they are wired.
So, it is possible (and better) to have a single board file
for both devices and just use the CONFIG_MACH_TYPE to make
a differentiation between each board when needed.
This change avoids code duplication by removing 298 lines of
code and makes future maintenance easier.
Older compilers don't recognize v7 wfi instruction, so use wfi macro to
fix builds on old compilers.
Set ETM TRCLK down to 78MHz to get clear wave form.
This patch makes difference only when you use ETM trace connecting JTAG debugger.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
After stress test, I found some of kzm9g board occures memory failure.
This patch adust SDRAM setting.
- Enlarge drivability on both SDRAM controller and SDRAM itself
- Raise core voltage
The following features are supported:
* 128 MB DDR1 SDRAM
* DUART
* SD/MMC Card Socket
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Add support for the MMC attached to SSP1.
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Some MXS based boards do not implement the card-detect signal. Allow
user to specify alternate card-detect implementation.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
The memory power supply on MX23 didn't pump out enough juice into
the DRAM chip, thus caused occasional memory corruption. Fix this.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
The '#' used as comments in the files cause the preprocessor
trouble, so change to /* */.
The mkimage command which uses this preprocessor output
was moved to arch/arm/imx-common/Makefile
.gitignore was updated to ignore .cfgtmp files.
Set Write Protection GPIO as input.
This patch adds support for MX23-based Olinuxino board.
Sort nodes in dts files according the the following rules:
1) Any nodes that already exist in any /include/d file, in the order
they appear in the /include/d file.
2) Any nodes with a reg property, in order of their address.
3) Any nodes without a reg property, alphabetically by node name.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
These nodes are unused.
IRDA is a synonym for UARTB in tegra pinmux, remove all usage of this
synonym and replace with UARTB to disambiguate.
Note that T30 does not have a separate/different DVC (power I2C)
controller like T20 - all 5 I2C controllers are identical, but
DVC_I2C is still used to designate the controller intended for
power control (PWR_I2C in the schematics). On Cardhu, it's used
to access the PMU and EEPROM, as well as the audio codec, temp
sensor, and fuel gauge devices from the OS.
This build is stripped down. It boots to the command prompt.
GPIO is the only peripheral supported. Others TBD.
include/configs/tegra-common.h now holds common config options
for Tegra SoCs.
This patch adds basic Tegra30 (T30) build support - no specific
board is targeted.
These are stripped down for bringup, They'll be filled out later
to match-up with the kernel DT contents, and/or as devices are
brought up (mmc, usb, spi, etc.).
This adds LCD panel descriptions to the device tree of PAZ00 and
enables LCD support in the configuration.
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Boards may require a different pinmux setup for DISPALY than the default one.
Add a way to call into board specific code to set this up.
The TEC ships with a 7" LCD panel that provides a resolution of 800x480
pixels. Add a corresponding panel description to the device tree and
enable LCD support in the configuration.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
The Medcom-Wide has a 15" LCD panel with a resolution of 1366x768
Add DVI output support and make it the default video output.
Currently the CLAA WVGA panel is supported, but this panel has to be purchased
separately, so using the DVI output as the default would allow more people to
try the splash screen feature on a mx51evk.
If someone still wants to use the CLAA WVGA, just set the panel variable as:
set panel claa
Use a common watchdog driver for all these cpus.
u-boot compilation fails for smdk5250 when we deselect CONFIG_LCD
from the main config file.
Following error was observed:
drivers/video/libvideo.o: In function `exynos_lcd_init':
/home/ajay/u-boot-samsung/drivers/video/exynos_fb.c:68: undefined reference to `lcd_set_flush_dcache'
This is because exynos video drivers have dependency on CONFIG_LCD.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Add panel_info structure required by LCD driver
and DP panel platdata for SMDK5250.
Add GPIO configuration for LCD.
Enable FIMD and DP support on SMDK5250.
DP Panel size: 2560x1600.
We use 16BPP resolution to get LCD console.
Acked-by: Simon Glass <sjg@chomium.org>
Add device node for MAX77686
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Add support for the Seiko 4.3'' WVGA panel on mx53loco.
By default, the CLAA WVGA panel is selected.
In order to support the Seiko panel, the enviroment variable 'panel' must be
set to 'seiko'.
Instead of using the serverip we get from the DHCP server, implicitly use
the broadcast address, which is automatically set when no ncip environment
variable is set. That way it isn't necessary to use a special DHCP
configuration to set the netconsole peer.
Signed-off-by: Michael Walle <michael@walle.cc>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This saves stack and code memory for local copy, and
consumes initialized data memory. For 22 of the 29
kirkwood-based boards, this results in a global saving
of about 30 bytes. For 7 of them, it results in an
increase of 6 to 14 bytes.
This patch removes 2 small portions of board specific code that are
duplicated with common ARM code and thus unnecessary. These 2 portions
of code concern the mach id that is given by u-boot to the Linux kernel
to identify the system's MACH.
The first one was the possibility to change the MACH thanks to the
'mach_id' enviroment variable. This is possible thanks to the 'machid'
env variable (see arch/arm/lib/bootm.c:boot_jump_linux()).
The seconde one is the setting of the bi_arch_number. This is already
done in arch/arm/lib/board.c:board_init_f() since km_arm.h does #define
CONFIG_MACH_TYPE.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Prafulla Wadaskar <Prafulla@marvell.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
On kmcoge5un we faced some serious problems with the memory during
temperature tests. Reason was that we overwrite some registers for
memory settings which have to leave untouched. These where registers
0x20148 , 0x2014c and 0x20154.
So writing these registers is prohibited and this patch removes them
from all km related config files. Even if the problem was only
seen on kmcoge5un.
This required manual merging drivers/mtd/nand/Makefile
and adding am335x_evm support for CONFIG_SPL_NAND_DRIVERS
This patch enables Vbus required for USB 2.0 controller.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
