Removed initialization of the driver from net/eth.c
AT91_BASE_EMAC is never used outside the board specific files,
so replace its usage by the board specific AT91xxx_BASE_EMAC.
Signed-off-by: Stelian Pop <stelian@popies.net>
AT91_ID_US0 / AT91_ID_US1 / AT91_ID_US2 were used but never defined.
Since they are never used outside the board specific files, they can
be replaced by the board specific AT91xxx_ID_US0 / AT91xxx_ID_US1 /
AT91xxx_ID_US2.
Bug spotted by Jesus Alvarez <jalvarez@micromint.com>.
This patch provides support for AFEB9260 board, a product of
OpenSource hardware and software. Some commertial projects
are made with this design. A board is basically AT91SAM9260-EK
with some modifications and different peripherals and different
parts used. Main purpose of this project is to gain experience in
hardware design.
More info: http://groups.google.com/group/arm9fpga-evolution-board
(In Russian only, sorry).
Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
Removal of never used functions.
Signed-off-by: Roman Mashak <romez777@gmail.com>
Fix compilation issue caused by a few mismatches.
Provide proper nand chip select enable/disable in
nand_hwcontrol() rather than in board_nand_init()
just enable once. Remove redundant local nand driver
functions - nand_read_byte(), nand_write_byte() and
nand_dev_ready() to use common nand driver.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Add serial boot support
Will use mcfmii.c driver in drivers/net rather than
keep creating new mii.c for each future platform.
Remove EB+MCF-EV123, cobra5272, idmr, M5235EVB,
M5271EVB, M5272C3, M5275EVB, M5282EVB, M5329EVB,
M5373EVB, M54451EVB, M54455EVB, M547xEVB, and M548xEVB's
mii.c
Each different build for M54455EVB and M5235EVB will
create a u-boot.lds linker file. It is redundant to
keep the u-boot.lds
There were several, now there is one (two if you count the lower-case
versions).
Signed-off-by: Andy Fleming <afleming@freescale.com>
This patch defines 1M TLB&LAW size for NAND on MPC8536DS, assigns 0xffa00000
for CONFIG_SYS_NAND_BASE and adds other NAND supports in config file.
It also moves environment(CONFIG_ENV_ADDR) outside of u-boot image.
Singed-off-by: Jason Jin <Jason.Jin@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
This patch brings PMC440 board support up to date:
- fix GPIO configuration
- add misc_init_f()
- use better values for usbact variable
- fix USB 2.0 phy reset sequence
- shrink BAR2 to save PCI address space
- add FDT support
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch fixes the PMC440 BSP commands painit and selfreset
This patch fixes esd's loadpci command when not all
memory on adapter boards is accessable via PCI.
-Codingstyle cleanup
-Remove unused GPIO define
Xilinx ppc440 and ppc405 have many similarities. This patch merge the
config files of both infrastuctures
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
The DDR1 LAW will precedence the DDR2 LAW, so remove
the second DDR LAW.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Acked-by: Becky Bruce <becky.bruce@freescale.com>
The DDR controller of 86xx processors have the ECC data init
feature, and the new DDR code is using the feature, we don't
need the way with DMA to init memory again.
Acked-by: Kumar Gala <kumar.gala@freescale.com>
This patch defines 1M TLB&LAW size for NAND on MPC8572DS, assigns
0xffa00000 for CONFIG_SYS_NAND_BASE and adds other NAND supports in
config file.
It also moves environment(CONFIG_ENV_ADDR) outside of u-boot image, to
make room for the increased code size with NAND enabled.
Signed-off-by: Jason Jin <Jason.Jin@freescale.com>
- Rename lbus83xx_t to fsl_lbus_t and move it to asm/fsl_lbc.h so that it
can be shared by both 83xx and 85xx
- Remove lbus83xx_t and replace it with fsl_lbus_t in all 83xx boards
files which use lbus83xx_t.
- Move FMR, FIR, FCR, FPAR, LTESR from mpc83xx.h to asm/fsl_lbc.h so that
85xx can share them.
Renamed show_boot_progress in assembler init phase to
show_boot_progress_asm to avoid link conflicts with C version
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
The information displayed when CONFIG_LCD_INFO is set is inherently
board-specific, so it should be done by the board code. The current code
dealing with this only handles two cases, and is already a horrible mess
of #ifdeffery.
Yes, this duplicates some code, but it also allows boards to print more
board-specific information; this used to be very difficult.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Converted MPC8610HCPD, MPC8641HPCN, and SBC8641D to use
fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup().
With these changes the board code is a bit smaller and we get dma-ranges
set in the device tree for these boards.
Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
Acked-by: Jon Loeliger <jdl@freescale.com>
Converted ATUM8548, MPC8536DS, MPC8544DS, MPC8548CDS, MPC8568MDS,
MPC8572DS, TQM85xx, and SBC8548 to use fsl_pci_setup_inbound_windows()
This patch adds support for the avnet fx12 minimodul.
It needs the "ppc4xx: Generic architecture for xilinx ppc405"
patch from Ricardo.
Signed-off-by: Georg Schardt <schardt@team-ctech.de>
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx
ppc440 boards, this patch presents a common architecture for all the
xilinx ppc405 boards.
Any custom xilinx ppc405 board can be added very easily with no code
duplicity.
This patch also adds a simple generic board, that can be used on almost
any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h
This patch is prepared to work with the latest version of EDK (10.1)
Common Blackfin code already announces CPU information.
The USB/LAN register settings are not actually used/needed in order to
drive things from U-Boot, so drop the code.
