Fix problem with only partially cleared .bss segment
* Patch by Rune Torgersen, 12 May 2003:
get PCI to work on a MPC8266ADS board; incorporate change to
cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
allow to pass boot bitmap addresses in environment variables;
allow for zero boot delay
* Patch by Christian Geißinger, 19 May 2002:
On TRAB: wait until the dummy byte has been completely sent
update for CrayL1 board
* Patch by Pantelis Antoniou, 21 Apr 2003:
add boot support for ARTOS (a proprietary OS)
* Patch by Steven Scholz, 11 Apr 2003:
Add support for RTC DS1338
* Patch by Rod Boyce, 24 Jan 2003:
Fix counting of extended partitions in diskboot command
(includes support for Intel 82365 and compatible PC Card controllers,
and Yenta-compatible PCI-to-CardBus controllers)
* Patch by Keith Outwater, 28 Apr 2003:
- Miscellaneous corrections and additions to GEN860T board specific code.
- Added GEN860_SC variant to GEN860T.
- Miscellaneous corrections to GEN860T documentation.
- Correct duplicate entry in U-Boot CREDITS file.
- Add GEN860T_SC entry in MAINTAINERS file.
- Update CREDITS file with GEN860T_SC info.
* Update Smiths Aerospace addresses in MAINTAINERS file
* Fix error handling in hush's version of "run" command
- Splashscreen support
- modem support
- sysmon support
- temperature dependend enabling of LCD
* Allow booting from old "PPCBoot" disk partitions
* Add support for TQM8255 Board / MPC8255 CPU
* MPC823 LCD driver: Fill color map backwards, to allow for steady
display when Linux takes over
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS (this time for real).
* Add support for "bmp info" and "bmp display" commands to load
bitmap images; this can be used (for example in a "preboot"
command) to display a splash screen very quickly after poweron.
* Add support for 133 MHz clock on INCA-IP board
Update for R360MPI board
* Add new meaning to "autostart" environment variable:
If set to "no", a standalone image passed to the
"bootm" command will be copied to the load address
(and eventually uncompressed), but NOT be started.
This can be used to load and uncompress arbitrary
data.
* Set max brightness for MN11236 displays on TRAB board
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
Add IDMA example code (tested on 8260 only)
* Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS
* Patch by Denis Peter, 04 Apr 2003:
- update MIP405-4 board
* Patches by Denis Peter, 03 April 2003:
- fix PCI IRQs on MPL boards
- fix two more un-relocated pointer problems
* Fix behaviour of "run" command:
- print error message iv variable does not exist
- terminate processing of arguments in case of error
* Patches by Peter Figuli, 10 Mar 2003
- Add support for BTUART on PXA platform
- Add support for WEP EP250 (PXA) board
* Fix flash problems on INCA-IP; add tool to allow bruning images to
flash using a BDI2000
* Implement fix for I2C Edge Conditions problem for all boards that
use the bit-banging driver (common/soft_i2c.c)
* Add patches by Robert Schwebel, 31 Mar 2003:
- csb226 board: bring in sync with innokom/memsetup.S
- csb226 board: fix MDREFR handling
- misc doc fixes / extensions
- innokom board: cleanup, MDREFR fix in memsetup.S, config update
- add BOOT_PROGRESS to armlinux.c
- Add port to MPC555/556 microcontrollers
- Add support for cmi customer board with
Intel 28F128J3A, 28F320J3A or 28F640J3A flash.
* Patch by Rick Bronson, 28 Mar 2003:
- fix common/cmd_nand.c
- add threads / scheduler example code
- add ctrl-c support for kermit download
- align bdinfo output on ARM
* Add CPU ID, version, and clock speed for INCA-IP
- fix SRAM and SDRAM memory sizing
- add status LED support
- add MAC address for second (SCC1) ethernet port
Update default environment for TQM8260 board
* Add support for INCA-IP Board
Add support for Atmel AT91RM9200DK w/NAND
* Patches by Robert Schwebel, 19 Mar 2003:
- use arm-linux-gcc as default compiler for ARM
- fix i2c fixup code
- fix missing baudrate setting
- added $loadaddr / CFG_LOAD_ADDR support to loadb
- moved "ignoring trailing characters" _before_ u-boot wants to
print out diagnostics messages; removes bogus characters at the
end of transmission
* Patch by John Zhan, 18 Mar 2003:
Add support for SinoVee Microsystems SC8xx boards
* Patch by Rolf Offermanns, 21 Mar 2003:
ported the dnp1110 related changes from the current armboot cvs to
current u-boot cvs. smc91111 does not work. problem marked in
smc91111.c, grep for "FIXME".
* Patch by Brian Auld, 25 Mar 2003:
Add support for STM flash chips on ebony board
* Add PCI support for MPC8250 Boards (PM825 module)
* Patch by Stefan Roese, 25 Mar 2003:
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100
boards, version 153 for Rev. 200 boards).
* Patch by Vladimir Gurevich, 12 Mar 2003:
Fix relocation problem of statically initialized string pointers
in common/cmd_pci.c
* Patch by Kai-Uwe Blöm, 12 Mar 2003:
Cleanup & bug fixes for JFFS2 code:
- the memory mangement was broken. It caused havoc on malloc by
writing beyond the block boundaries.
- the length calculation for files was wrong, sometimes resulting
in short file reads.
- data copying now optionally takes fragment version numbers into
account, to avoid copying from older data.
See doc/README.JFFS2 for details.
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
- minimal setup for CardBus bridges
- add EEPROM read/write support in the CS8900 driver
- add support for the builtin I2C controller in the Samsung s3c24x0 chips
- add support for MPL's VCMA9 (Samsung s3c2410 based) board
* Patch by Steven Scholz, 04 Feb 2003:
add support for RTC DS1307
* Patch by Reinhard Meyer, 5 Feb 2003:
fix PLPRCR/SCCR init sequence on 8xx to allow for
changes of EBDF by software
* Patch by Vladimir Gurevich, 07 Feb 2003:
"API-compatibility patch" for 4xx I2C driver
- fix bug in BOOTP code (must use NetCopyIP)
- update of CSB226 port
- clear BSS segment on XScale
- added support for i2c_init_board() function
- update to the Innokom plattform
* Extend support for redundand environments for configurations where
environment size < sector size
Add support for Motorola MPC8266ADS board
* Patch by Kyle Harris, 19 Feb 2003:
patches for the Intel lubbock board:
memsetup.S - general cleanup (based on Robert's csb226 code)
flash.c - overhaul, actually works now
lubbock.c - fix init funcs to return proper value
* Patch by Kenneth Johansson, 26 Feb 2003:
- Fixed off by one in RFTA calculation.
- No need to abort when LDF is lower than we can program it's only
minimum timing so clamp it to what we can do.
- Takes function pointer to function for reading the spd_nvram. Usefull
for faking data or hardcode a module without the nvram.
- fix other user for above change
- fix some comments.
* Patches by Brian Waite, 26 Feb 2003:
- fix port for evb64260 board
- fix PCI for evb64260 board
- fix PCI scan
* Patch by Reinhard Meyer, 1 Mar 2003:
Add support for EMK TOP860 Module
* Patch by Yuli Barcohen, 02 Mar 2003:
Add SPD EEPROM support for MPC8260ADS board
- Add support for Innokom board
- Don't complain if "install" fails
- README cleanup (remove duplicated lines)
- Update PXA header files
* Add documentation for existing POST code (doc/README.POST)
* Patch by Laudney Ren, 15 Jan 2003:
Fix handling of redundand environment in "tools/envcrc.c"
* Patch by Detlev Zundel, 28 Feb 2003:
Add bedbug support for 824x systems
* Add support for 16 MB flash configuration of TRAB board
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
slot populated)
* Start adding MIPS support files
* Add support for LXT971 PHY on PM826
* Patch by Tord Andersson, 16 Jan 2003:
Fix flash sector count for TQM8xxL
* Fix I2C EEPROM problem on ICU862 board (would only write the first
16 bytes out of each 32 byte block)
(patch by Jón Benediktsson, 11 Dec 2002)
when watchdog is on
* Update baudrate in bd_info when it gets changed
* Add watchdog trigger points while waiting for serial port
(so far only 8xx -- needed on LWMON with 100ms watchdog)
* Improve command line tool to access the U-Boot's environment
(figuration of the utility, using a config file)
Fix misc problems with AmigaOne support
* Patch by Chris Hallinan, 3 Dec 2002:
minor cleanup to the MPC8245 EPIC driver
* Patch by Pierre Aubert , 28 Nov 2002
Add support for external (SIU) interrupts on MPC8xx
Fix nested syscalls bug in standalone applications
* Patch by David Müller, 27 Nov 2002:
fix output of "pciinfo" command for CardBus bridge devices.
* Fix bug in TQM8260 board detection - boards got stuck when board ID
was not readable
* Patch by Pierre Aubert, 20 Nov 2002
Add driver for Epson SED13806 graphic controller.
Add support for BMP logos in cfb_console driver.
* Patch by Rod Boyce, 21 Nov 2002:
fix PCMCIA on MBX8xx board
* Patch by Pierre Aubert , 21 Nov 2002
Add CFG_CPM_POST_WORD_ADDR to make the offset of the
bootmode word in DPRAM configurable
Fixes for x86 port (mostly strings issues)
* Patch by Ken Chou, 18 Nov 2002:
Fix for natsemi NIC cards (DP83815)
* Patch by Pierre Aubert, 19 Nov 2002:
fix a bug for the MII configuration, and some warnings
