path: root/board
2012-03-18bootstage: Convert progress numbers 1-9 into enumsSimon Glass
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-18CPCI750: Add CPCI-HD/2 supportReinhard Arlt
This patch adds support for the esd CPCI-HD/2 board to u-boot for CPCI-CPU/750. As the primary devices on the CPCI-HD/2 board are connected to device 1 and 3, the device must be swapped. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
2012-03-12sandbox: add get_{tbclk,ticks}Mike Frysinger
Fixes building after recent readline updates with timeouts. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06PPC: Drop mv6446x_eth_initialize() from net/eth.cMarek Vasut
This function was defined as an extern in net/eth.c, drop that and use standard means of calling it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-03-06PPC: Drop mv6436x_eth_initialize() from net/eth.cMarek Vasut
This function was defined as an extern in net/eth.c, drop that and use standard means of calling it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2012-03-06Stop using builtin_run_command()Simon Glass
Boards can select either the 'built-in' parser or the hush parser. We should not call builtin_run_command() if we are using the hush parser. We use run_command() instead, since it knows how to call the correct parser. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06Rename run_command() to builtin_run_command()Simon Glass
The current run_command() is only one of the parsing options - the other is hush. We should not call run_command() when the hush parser is being used. So we rename this function to better explain its purpose. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-04integrator: remove fragile delay loop from PCI codeLinus Walleij
The reference implementation of the PCI initialization code almost everywhere contain this fragile loop of "a few usecs", and its use of volatile variables to delay a number of bus cycles is indeed uncertain. Reading the manual "Integrator/AP Users Guide", page 5-15 it is clearly stated: "Wait until 230ms after the end of the reset period before accessing V360EPC internal registers. The V360EPC supports the use of a serial configuration PROM and the software must wait for the device to detect the absence of this PROM before accessing any registers. The required delay is a function of the PCI Clock, but at the lower frequency (25MHz) is 230ms". So let's simply wait 230ms per the spec. This solves the compilation error that looked like this: pci.c: In function ‘pci_init_board’: pci.c:286:18: warning: variable ‘j’ set but not used Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-04pci: move pciauto_config_init() to pci.hLinus Walleij
Fixing build regressions for the Integrator I get find that a few boards try to work around the missing declaration of pciauto_config_init() by declaring it in the local scope. This does not make sense when the sibling functions are in <pci.h> so move the function to the header, ridding the build error in the Integrator and getting rid of the local declarations here and there. Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-29Ethernut 5: fix build errorprabhakar.csengg@gmail.com
Fix build error for ethernut5 board due to prototype change for function board_mmc_getcd(). ethernut5.c:238: error: conflicting types for 'board_mmc_getcd' u-boot/include/mmc.h:318: note: previous declaration of 'board_mmc_getcd' was here make[2]: *** [ethernut5.o] Error 1 Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tim Schendekehl <tim.schendekehl@egnite.de> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: egnite GmbH <info@egnite.de>
2012-02-27at91: modified NAND flash timing on otc570 boardDaniel Gorsulowski
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2012-02-27at91: modified NAND flash timing on meesc boardDaniel Gorsulowski
2012-02-27tt01: add video supportHelmut Raiger
The video setup for the Epson display is provided. Addtionally some extra info is displayed next to the Linux logo. Make get_cpu_rev() publicly available (added to sys_proto.h). Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-27i.mx6q: mx6qsabrelite: Update the network configurationTroy Kisky
Define CONFIG_PHY_MICREL, and minimize the tx clock delay. There is an issue with 1000 baseTx mode on early revs of the SabreLite boards. The center tap pin 9 of the mag RJ45 USB combo was connected to the 3.3 filtered supply. Letting this pin float solved the problem. Symptoms of the problem were packets with many extra zeroes tacked on the end, and random bit flips causing a high rate of CRC errors. 10/100 baseTx worked fine on all revs. To disable 1000 baseTx for these boards, simply define the environment variable disable_giga. ie. setenv disable_giga 1 Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-02-27net: phy: make board_phy_config responsible for calling drv->configTroy Kisky
Boards may have things they want done before or after normal phy config. Letting the boards call drv->config allows them more flexibilty. Boards affected by this change are corenet_ds and mpc8544ds. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-02-27integrator: rewrite the AP PCI driverLinus Walleij
The PCI support for the Integrator AP has apparently never been finished and I strongly suspect that it has never worked, so let's fix it. This is a list of the more or less un-splittable changes done in this driver rewrite: - Replace the register definitions stashed into the config file (!) with a copy if the register file from the Linux kernels arch/arm/include/asm/hardware/pci_v3.h - Delete the unreadable gigantic macros that perform the config accesses and replace them with copyedited code from Linux arch/arm/mach-integrator/pci_v3.c - Rewrite the rest of the setup code to use the v3_[read|write][lwb]() accessors. - Enable PCI by default in the AP board configuration. - Fix checkpatch warnings and make code more conformant. Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-27integrator: stop calling pci_init() twiceLinus Walleij
The U-Boot startup infrastructure already makes sure pci_init() is called at a proper time, calling it again from within the board setup code will not make things better. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-27dm6467Tevm: Use a common configuration file for davinci_dm6467evm and ↵prabhakar.csengg@gmail.com
davinci_dm6467Tevm In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h. The substantial difference between the davinci_dm6467evm and the davinci_dm6467Tevm configuration is a single bit in the hardware revision that is passed to the Linux kernel and davinci_dm6467evm has REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a REFCLK_FREQ = 33000000. This patch removes include/configs/davinci_dm6467Tevm.h. Instead the include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined in boards.cfg. Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-02-27da850evm: read mac address from I2C EEPROM on AM18x EVMHadli, Manjunath
add support to read mac address for AM18x EVM manufactured from Spectrum digital which have mac address stored in I2C EEPROM manufactured by WINBOND. This patch reads mac address from I2C EEPROM and sets the environment variable if not set, If mac address is already present in environment compare it with the mac address in EEPROM and warn on mismatch.Introduced a config option CONFIG_MAC_ADDR_IN_EEPROM to where to look for the mac address. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2012-02-27da850evm: add support to read mac address from SPI flashHadli, Manjunath
add support to read mac address for da850/L138 evm manufactured by Logic PD which store mac address in SPI flash manufactured by ST Microelectronics. This patch adds support to read mac address from SPI flash and set the mac address if it hasn't been set in environment, If it has been set in the environment it compares the value one with SPI flash and warns on mismatch. Introduced a config option CONFIG_MAC_ADDR_IN_SPIFLASH indicating where to look mac address for. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2012-02-27beagle: enable DVI_PUPPeter Meerwald
this patch addresses the issue that there is no DVI output on beagleboard-xm in u-boot; the TFP410 is not powered on, DVI_PUP needs to be set high this is done differently on beagleboard-xm rev. B/C versus earlier boards: beagleboard-xm B/C need to set GPIO2 of the TWL4030 earlier boards need to set GPIO170 note that the change occured somewhere inbetween beagleboard-xm rev. A2 and A3 note that beagleboard-xm rev. A and rev. B cannot be distinguished using get_board_revision(), REVISION_XM_A/REVISION_XM_B is bogus due to this glitch, the patch cannot work correctly on some beagleboard-xm rev A/B boards tested on beagleboard-xm rev. C (you should see orange color on a monitor) note that the framebuffer is NOT yet set up, this could be done along the lines below (for 800x480 resolution and RGB24) before calling omap3_dss_enable() static void configure_frame_buffer() { writel(0x80500000, (uint *) 0x48050480); // address writel(0x80500000, (uint *) 0x48050484); writel(0x01df031f, (uint *) 0x4805048c); // size writel(0x00000091, (uint *) 0x480504a0); // RGB24 } Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
2012-02-27mx35pdk: Remove duplicate CPU revision and reset cause informationFabio Estevam
MX35PDK board does not need to print CPU revision and reset cause in board file because this is printed by common code when CONFIG_DISPLAY_CPUINFO is selected Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx51evk: Use gpio_direction_input prior to gpio_get_valueFabio Estevam
Use gpio_direction_input prior to gpio_get_value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx53smd: Use gpio_direction_input prior to gpio_get_valueFabio Estevam
2012-02-27mx53evk: Use gpio_direction_input prior to gpio_get_valueFabio Estevam
Use gpio_direction_input prior to gpio_get_value. Cc: Jason Liu <r64343@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2012-02-27mx53ard: Use gpio_direction_input prior to gpio_get_valueFabio Estevam
2012-02-27mx53loco: Use gpio_direction_input prior to gpio_get_valueFabio Estevam
Use gpio_direction_input prior to gpio_get_value. Cc: Jason Liu <r64343@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <r64343@freescale.com>
2012-02-27mx6q: mx6qsabrelite: Provide default serial flash bus and chip-selectEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org> Tested-by: Jason Liu <jason.hui@linaro.org>
2012-02-27mx6q: mx6qsabrelite: Add ECSPI support to the Sabrelite platformEric Nelson
2012-02-27mx28evk: add SPI supportMatthias Fuchs
This patch adds SPI support for the MX28EVK. Support for an optionally installed SPI flash is also added. An example configuration for redundant envrionment from SPI flash is also added but disabled by default. This patch has been tested on a MX28EVK Rev. D with an installed SST25VF032B 32Mbit SPI flash. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx28evk: add USB supportMatthias Fuchs
This patch enables USB host support on the MX28EVK board. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-13Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: pata_bfin: fix printf warning Blackfin: bfin_nand: mark local func static linkage.h: move from blackfin to common includes Blackfin: br4: new board port Blackfin: add in/out le32 variants post: add blackfin to the post_time_ms list Blackfin: bf537-stamp: drop board reset workaround Blackfin: pr1: new board port
2012-02-12Blackfin: br4: new board portDimitar Penev
This adds support for the BR4 Appliance. It is a quad channel ISDN BRI board based on Blackfin BF537 CPU. Signed-off-by: Dimitar Penev <dpn@switchfin.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12Blackfin: bf537-stamp: drop board reset workaroundMike Frysinger
The bf537-stamp shouldn't need this SPI flash workaround. It was added by accident a long time ago through a convoluted series of steps which originated from a customer board (not the bf537-stamp). So drop it to keep people from incorrectly adding it to their own boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12Blackfin: pr1: new board portDimitar Penev
This add support for the PR1 Appliance - Asterisk based ISDN PRI PBX. This board is Blackfin BF537 based. The schematics are not fully opened. Signed-off-by: Dimitar Penev <dpn@switchfin.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12arm, davinci: Add support for the Calimain board from OMICRON electronicsChristian Riesch
This patch adds support for the Calimain board from OMICRON electronics GmbH. The board features a Texas Instruments AM1808 SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and CS3. Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12omap3logic: Add missing GPMC pinmux for LAN92xx accessPeter Barada
The initial checkin dropped pinmux setup for GPMC pins A6-A10, D0-D7 and NCS1/2 necessary to access LAN92xx on Logic OMAP35x/DM37x modules. Signed-off-by: Peter Barada <peter.barada@logicpd.com>
2012-02-12beagle: fix typosPeter Meerwald
2012-02-12mcx: support for HTKW mcx boardIlya Yanok
This patch adds support for the HTKW mcx AM3517-based board. Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both NAND and MMC SPLs are supported. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12ARM: omap3: Added Teejet mt_ventouxStefano Babic
The mt_ventoux board is a custom board using the Technexion TAM3517 module. The patch fixes also the mtdparts variable in the TAM3517 common configuration file. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Igor Grinberg <grinberg@compulab.co.il> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12OMAP3: TAM3517: update ehci interfaceStefano Babic
Changed the EHCI interface using the ulpi framework. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12OMAP4: ehci-omap: enable ehci-omap for panda boardsGovindraj.R
For panda initialise the mux pins for ehci usage and enable ehci in omap4_panda config file. Signed-off-by: Govindraj.R <govindraj.raja@ti.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12ehci-omap: Clean up added ehci-omap.cGovindraj.R
Clean up added ehci-omap.c and make it generic for re-use across omap-soc having same ehci ip block. Also pass the modes to be configured from board file and configure the ports accordingly. All usb layers are not cache aligned, till then keep cache off for usb ops as ehci will use internally dma for all usb ops. * Add a generic common header ehci-omap.h having common ip block data and reg shifts. * Rename and modify ehci-omap3 to ehci.h retain only conflicting sysc reg shifts remove others and move to common header file. * pass the board data for beagle/panda accordinly to use ehci ports. Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2012-02-12ehci-omap: driver for EHCI host on OMAP3Ilya Yanok
Taken from Beagle code. Tested on mcx board (AM3517-based). Signed-off-by: Ilya Yanok <yanok@emcraft.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12usb: ulpi: Extend the existing ulpi framework.Govindraj.R
Extend the existing ulpi viewport framework to pass the port number information for any ulpi ops. Fix the usage of ulpi api's accordingly. Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2012-02-12SMDK5250: Add ethernet supportChander Kashyap
This patch enable support for SMC911X based ethernet device. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12EXYNOS: SMDK5250: Add MMC SPL supportChander Kashyap
This patch adds support for MMC SPL booting. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
