this is an atempt to make the export of functions typesafe.
I replaced the jumptable void ** by a struct (jt_funcs) with function pointers.
The EXPORT_FUNC macro now has 3 fixed parameters and one
variadic parameter
The first is the name of the exported function,
the rest of the parameters are used to format a functionpointer
in the jumptable,
the EXPORT_FUNC macros are expanded three times,
1. to declare the members of the struct
2. to initialize the structmember pointers
3. to call the functions in stubs.c
Signed-off-by: Martin Dorwig <dorwig@tetronik.com>
(resending to the list since my tweaks are not quite trivial)
Rather than assuming that the chip offset length is 1, allow it to be
provided. This allows chips that don't use the default offset length to
be used (at present they are only supported by the command line 'i2c'
command which sets the offset length explicitly).
Acked-by: Heiko Schocher <hs@denx.de>
Add a dm_ prefix to driver model I2C functions so that we can keep the old
ones around.
This is a little unfortunate, but on reflection it is too difficult to
change the API. We can undo this rename when most boards and drivers are
converted to use driver model for I2C.
Dont send always emio value as zero for zynq_gem_initialize
send it based on config.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Show board information in bootlog and enable it by default.
When diffing through the changes only the relevant changes
should be displayed.
Signed-off-by: Luka Perkov <luka@openwrt.org>
Add deep sleep support on Freescale LS1021QDS platform.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
[York Sun: Fix conflict in fdt.c]
Reviewed-by: York Sun <yorksun@freescale.com>
This patch adds LPUART support for LS1021ATWR board.
For ls1021atwr_nor_lpuart_defconfig, LPUART is used as the console.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
This patch adds LPUART support for LS1021AQDS board.
For ls1021aqds_nor_lpuart_defconfig, LPUART is used as the console.
CAAM is connected to CCI-400 S0 slave interface. Disable snooping for
S0 will cause CAAM self test failure. This patch is to enable snooping
for S0 slave interface. These CCI-400 operations are moved to
board_early_init_f() to be initialized earlier. For S4 slave interface,
issuing of snoop requests and DVM message requests are enabled.
This patch adds the CH7301 HDMI options and the common configuration
for DCU on LS1021AQDS board.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Cc: Jason Jin <Jason.Jin@freescale.com>
This patch reverts to use ge0_clk125 for eTSEC clock muxing. For SAI and
CAN which are pin multiplexed with RGMII1 in EC1 of RCW, ge2_clk125 will
be used via hwconfig.
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
These boards are still non-generic boards.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
This board is still a non-generic board.
Cc: Josef Wagner <Wagner@Microsys.de>
It is a good thing that we can drop board-specific hack code
from drivers/mtd/nand/nand_base.c
Cc: Andrea "llandre" Marson <andrea.marson@dave-tech.it>
Cc: Ira W. Snyder <iws@ovro.caltech.edu>
These boards are still non-generic boards:
P1011RDB, P1022RDB, P2010RDB, P2020RDB
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Dave Liu <daveliu@freescale.com>
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
The Hyundai A7HD is a 7" 16:9 A10 powered tablet featuring 1G RAM, 8G
nand, 1024x600 IPS screen, a mini hdmi port, mini usb receptacle and a
headphones port for details see: http://linux-sunxi.org/Hyundai_A7HD
Cc: Mark Janssen <maniac@maniac.nl>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
It turns out that there are some panels where the pwm input is not active low,
so make it configurable.
HDMI, SATA, USB and Ethernet appear functional, I've not done extensive tests
of all peripherals though.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Currently we've separate detailed dram settings for all sun7i boards, this
moves them over to using auto dram configuration so that we can get rid of
all the per board dram_foo.c files.
This has been tested on a A20-Olinuxino-Lime, A20-Olinuxino_MICRO, Bananapi,
Bananapro, Cubieboard2, Cubietruck, Mele_M3 and a Linksprite_pcDuino3.
The qt840a is one of the many tv-boxes using the "i12" A20 pcb, but it
populates only one of the 2 places for a 16 bit dram ic, thus reducing
the buswidth to 16 bits, and the amount of ram to 512M, which is why we
had a separate config for it.
This commit switches the generic i12-tvbox_defconfig over to DRAM
autoconfiguration, so that it will work with the qt840a too, and drops the
qt840a specific config, like we've done with other memory-amount specific
configs before.
Tested on a generic i12-tvbox with 32 bit bus-width / 1G RAM, and on a
qt840a with 16 bit bus-width / 512M RAM.
The Chuwi V7 is an A10 (sun4i) based tablet with 1G of RAM, 16G of nand flash,
microsd slot, 7" 1024x768 lvds ips panel, mini hdmi out, headphones out,
stereo speakers, front & back camera and usb wifi.
It is clearly marked "CHUWI", "V7" and "Model: CW0825" on the back of the
tablet.
Add support for Hitachi tx18d42vm LVDS LCD panels, these panels have a
lcd controller which needs to be initialized over SPI, once that is
done they work like a regular LVDS panel.
Acked-by: Anatolij Gustschin <agust@denx.de>
Hookup OTG USB controller support and enable the otg controller + USB-keyb
on various tablets.
This allows tablet owners to interact with u-boot without needing to solder
a serial console onto their tablet PCB.
Gemei G9 is an A10 based tablet, with 1G RAM, 16G NAND, 1024x768
IPS LCD display, stereo speakers, 1.3MP front camera and 5 MP
rear camera, 8000mAh battery, GT901 2+1 touchscreen, Bosch BMA250
accelerometer and RTL8188CUS USB wifi. It also has MicroSD slot,
miniHDMI, 1 x MicroUSB OTG port and 1 x MicroUSB host port and
3.5mm headphone jack.
More details are available at: http://linux-sunxi.org/Gemei_G9
Signed-off-by: Priit Laes <plaes@plaes.org>
This patch add support for Marsboard A10 board.
The Marsboard A10 is a A10 based development board with 1G RAM, 1G NAND,
micro SD card slot, SATA 2.0 socket, 10/100 ethernet, mini HDMI port,
1 USB OTG port and 2 USB 2.0 ports. Board does not use the AXP209 pmic,
it does not have a pmic at all.
Board also have 2 expansion 70 pin headers.
Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com>
Convert GPIO names from Kconfig strings into pin numbers for
the 'ssd2828_config' struct. Add SSD2828 initialization between
enabling the parallel LCD interface and turning on the backlight.
Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
And also add Kconfig option for selecting ELDO3 voltage. The reason
for having this option is that the Android kernel sets ELDO3 to
1.2V when powering up LCD in the case if 'lcd_if' configuration
variable is set to 6 (LCD_IF_EXT_DSI) in the FEX file. Most likely
to supply power for a SSD2828 chip.
However on the MSI Primo81 tablet, which is using this particular
'lcd_if = 6' setup for LCD, setting the ELDO3 voltage appears to
be unnecessary and it works regardless. Having no schematics of
this tablet, I can only guess that 1.2V is supplied to SSD2828
in some other way.
The mk802_a10s re-uses is the "classic" mk802 case and functionality, but has
an A10s SoC inside rather then the A10, it features 512M or 1G RAM, 4G nand,
a mini-hdmi female connector, USB-A receptacle, mini-usb receptacle (OTG)
and a sdio realtek wifi chip. Unlike the original mk802 it does have a pmic,
the axp152.
For more details see: http://linux-sunxi.org/Semitime_g2
The mk802ii is a revised version of the mk802 A10 based hdmi tv-stick, it
features 1G RAM, 4G nand, a hdmi male connector, USB-A receptacle, 2 micro
usb receptacles (OTG & power) and USB-wifi, and does come with an axp209 pmic.
For more details see: http://linux-sunxi.org/Rikomagic_mk802ii
The mk802 is the "classic" Allwinner A10 based hdmi tv-stick, it features
512M or 1G RAM, 4G nand, a mini-hdmi female connector, USB-A receptacle,
mini-usb receptacle (OTG) and USB-wifi. Somewhat unique the mk802 does not
use the AXP209 pmic, it does not have a pmic at all.
CONFIG_TARGET_FOO is only used in board/sunxi/Makefile to select the
dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some
special handling of the bananapi/bananapro (both sun7i), iow it is not used
at all on any sun4i, sun6i and sun8i boards so lets get rid of it there.
Currently we've separate detailed dram settings for all sun4i boards, this
Tested-by: Hans de Goede <hdegoede@redhat.com> on a A10-OLinuXino-Lime,
Chuwi_V7_CW0825 and ba10_tv_box
Tested-by: Zoltan HERPAI <wigyori@uid0.hu> on a pcduino
While working on adding more boards I noticed that we lack a config for
the 512M cubieboard, and that some of the new boards which I want to add also
have 512M and 1G variants, rather then adding 2 defconfig's for all of these,
lets switch the exising boards which have both a 512M and 1024M variant over
to the sun4i dram autoconfig code.
This also drops the foo_RAMSIZE_defconfig variants of boards where we currently
have 2 separate configs already.
Note:
1) The newly introduced CONFIG_DRAM_EMR1 kconfig value is not used with
a value other then its default for now, but we need this to be configurable
to support some new boards with auto dram config.
2) We always set all CONFIG_DRAM_foo values in defconfigs, even if they match
the defaults, this is done to make it more clear what values are used for a
certain board.
This has been tested on a Mele A1000, Mini-X and a Cubieboard, all 1G
variants, the dram autoconfig code has also been tested on a 512M mk802
(a defconfig for the mk802 is added in a later patch).
While running some tests with an Olinuxino-A13-Micro + a 7" Olimex LCD module
I noticed that the screen flickered. This is caused by the lcd display clk
phase reg value being set to 0, where it should be 1 in this setup.
This commit adds a Kconfig option for the lcd display clk phase, so that we
can set it per board. This defaults to 1, because looking at all the fex
files in sunxi-boards, that is by far the most used value.
This commit updated the Ippo and MSI Primo73 tablet defconfigs to override the
default of 1 with 0, as that is the correct value for those tablets, this
keeps the register settings the same as before this commit.
The Olinuxino-A13 defconfigs are not updated, changing the register setting
for these boards from 0 to 1, this is intentional.
This patch configures and initializes the L2 switch on T1040rdb board.
The external L2 switch ports may be connected to PHYs only over
QSGMII, for T1040rdb.
Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com>
This patch configures and initializes the L2 switch on T1040QDS board.
The L2 switch ports must be initialized according to the SerDes
protocols.
Freescale's T1040qds board may be configured to have up to
5 FMAN ports (FM1@DTSEC1 to FM1@DTSEC5). From these 5 ports,
2 of them may be fixed-links (FM1@DTSEC1 annd FM1@DTSEC2),
connected to other two ports from an intergrated
VSC9953 L2 Switch (switch ports 8 and 9). These fixed-link
ports have no PHYs attatched, so they don't have a
corresponding MDIO.
corresponding MDIO.
