path: root/board
2016-02-02Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-02-02board: atmel: sama5d2_xplained: add SPL supportWenyou Yang
The sama5d2 Xplained SPL supports the boot medias: spi flash and SD Card. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02arm: at91/spl: mpddrc: add struct atmel_mpddrc_configWenyou Yang
Add struct atmel_mpddrc_config to accommodate the mpddrc register configurations, not using the mpddrc register map structure, struct atmel_mpddrc, in order to increase readability and reduce run-time memory use. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-01board: Add Microchip PIC32MZ[DA]-Starter-Kit board.Purna Chandra Mandal
This adds support for Microchip PIC32MZ[DA] StarterKit board based on a PIC32MZ[DA] family of microcontroller. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-02-01malta: Use I/O accessors for SuperI/O controllerPaul Burton
Rather than passing the I/O port base address to the Super I/O code, switch it to using outb such that it makes use of the I/O port base address automatically. Drop the extern keyword to satisfy checkpatch whilst here. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-02-01malta: Set I/O port base earlyPaul Burton
Set the I/O port base earlier, from board_early_init_f, in preparation for it being used by the serial driver. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-01-28Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2016-01-28Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2016-01-28arm: ls1021atwr: Do not wrap pci_eth_init() with CONFIG_TSEC_ENETBin Meng
The call to pci_eth_init() should not be wrapped with CONFIG_TSEC_ENET. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-28powerpc: p1010rdb: Do not wrap pci_eth_init() with CONFIG_TSEC_ENETBin Meng
2016-01-28powerpc: mpc8548cds: Do not wrap pci_eth_init() with CONFIG_TSEC_ENETBin Meng
2016-01-28powerpc: mpc8572ds: Do not wrap pci_eth_init() with CONFIG_TSEC_ENETBin Meng
2016-01-28powerpc: c29xpcie: Do not wrap pci_eth_init() with CONFIG_TSEC_ENETBin Meng
2016-01-28powerpc: bsc9132qds: Do not wrap pci_eth_init() with CONFIG_TSEC_ENETBin Meng
2016-01-28ARM: tegra: rm Jetson TK1 PMIC GPIO programmingStephen Warren
The PMIC is configured such that its GPIOs have the correct configuration at power-up, so no programming is required. In fact, the current programming is actively wrong, since: (a) the AS3722 driver configures the GPIO to be an output before setting its output value, which causes a 0v glitch on the output. (b) the AS3722 driver configures the GPIO to drive a high voltage from its VSUP_GPIO power source rather than its VDD_GPIO_LV power source, so the pin drives 5V not 1.8V as desired. Solve these problems by removing the code which configures the PMIC GPIOs. Note that this patch was tested directly on top of v2016.01; since then, commit 96350f729c42 "dm: tegra: net: Convert tegra boards to driver model for Ethernet" prevents PCIe from being initialized. Alternatively, simply revert that commit to get PCIe Ethernet working again, then apply this patch to test. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-01-27Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-01-27Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2016-01-27armv8/ls1043aqds: add QSPI boot supportQianyu Gong
Enable the U-Boot Driver Model(DM) to use the Freescale QSPI driver. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: add QSPI support in SD bootGong Qianyu
QSPI and IFC are pin-multiplexed on LS1043A. So we use ls1043aqds_sdcard_ifc_defconfig to support IFC in SD boot and ls1043aqds_sdcard_qspi_defconfig to support QSPI in SD boot. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: Select lpuart pins of various muxesShaohui Xie
Set Board Configuration Register to select the lpuart pins of various muxes. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27secure_boot: change error handler for esbc_validateAneesh Bansal
In case of error while executing esbc_validate command, SNVS transition and issue of reset is required only for secure-boot. If boot mode is non-secure, this is not required. Similarly, esbc_halt command which puts the core in Spin Loop is applicable only for Secure Boot. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27secure_boot: enable chain of trust for ARM platformsAneesh Bansal
Chain of Trust is enabled for ARM platforms (LS1021 and LS1043). In board_late_init(), fsl_setenv_chain_of_trust() is called which will perform the following: - If boot mode is non-secure, return (No Change) - If boot mode is secure, set the following environmet variables: bootdelay = 0 (To disable Boot Prompt) bootcmd = CONFIG_CHAIN_BOOT_CMD (Validate and execute Boot script) Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27secure_boot: create function to determine boot modeAneesh Bansal
A function is created to detrmine if the boot mode is secure or non-secure for differnt SoC's. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27ppc: xilinx-ppc440-generic: Wire LL_TEMAC driverRicardo Ribalda Delgado
If the xparameters file contains a LL_TEMAC definition compile its driver and the net commands. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx_ppc440_generic: Remove uncalled functionsRicardo Ribalda Delgado
board_pre_init was not called because CONFIG_BOARD_EARLY_INIT_F was not set. Remove unused function. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx_ppc405_generic: Remove uncalled functionsRicardo Ribalda Delgado
2016-01-27ppc: xilinx_ppc440_generic: Remove weak attributesRicardo Ribalda Delgado
Now that the specific boards have been removed there is no need to maintain the weak functions. Fix also CamelCase to make checkpatch happy Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx_ppc405_generic: Remove weak attributesRicardo Ribalda Delgado
2016-01-27ppc: xilinx-ppc4xx: Port to DM serialRicardo Ribalda Delgado
xilinx_uartlite has been ported to DM, this patch makes the xilinx-ppc405-generic and the xilinx-ppc440-generic boards use the new DM driver. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: zynqmp: Line up checkboard messageMichal Simek
Use space instead of tab in checkboard print to aligned it with others boards. Reported-by: David Glessner <david.glessner@rockwellcollins.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Moritz Fischer <moritz.fischer@ettus.com>
2016-01-27ARM64: zynqmp: Remove unneeded timer_init functionMichal Simek
Empty weak function is used instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Fix bootmode SD_MODE1Michal Simek
When only sdhci1 IP is enabled and SD_MODE1 bootmode is selected U-Boot using sdboot1 variable which refers to mmc dev 1. But this device doesn't exist because only one controller is available. This patch fix logic around sdboot mode with using sdbootdev internal variable. Reported-by: Chris Kohn <ckohn@xilinx.com> Acked-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Differentiate EMMC boot modeMichal Simek
Show also EMMC bootmode if selected. There is difference compare to SD bootmode. Use the same bootcommand till better boot command is created. Reported-by: Sai Pavan Boddu <saipava@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Show information about bootmodeMichal Simek
Showing information about bootmode is very useful to make sure that correct bootmode is selected. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Add support for SD1 boot modeMichal Simek
SD1 boot mode is using different bootmode values. Add support for this mode used on DC1. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Modify the SD and QSPI bootmode valuesSiva Durga Prasad Paladugu
Modify the SD bootmode value to 0x3 as per latest spec. Also add new boot mode QSPI 32 bit boot mode Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Use the same U-Boot version with/without ATFMichal Simek
Remove SECURE_IOU option which is not needed. U-Boot itself can detect which EL level it is on and based on that use do platform setup. It also simplify usage because one Kconfig entry is gone. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Fix board_init calling sequenceMichal Simek
board_init() is in final elf file but it is not called at all. Use board_init_late() instead and call gpio_init() from it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Read information about RAM from DTMichal Simek
Do not setup ram start/size in board file. Read it from DT instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Remove systemace from board fileMichal Simek
Systemace is ancient IP which is not tested. Remove it from default configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: emaclite: Move emaclite to KconfigMichal Simek
Add PHYLIB and MII dependencies and enable it by default for Microblaze. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: emaclite: Move driver to DMMichal Simek
Move driver to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Move driver to DMMichal Simek
2016-01-27microblaze: Remove unused I2C macrosMichal Simek
There is no i2c driver in the current u-boot. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27serial: uartlite: Add uartlite to KconfigMichal Simek
- Move config option out of board file. - Remove uartlite address from config file Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-27ppc: xilinx-ppc4xx-generic: Update xparameters.hRicardo Ribalda Delgado
-Remove UART address (It is now part of the dts). -Include dummy ns16550 clock -Fix address to last test Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: pp440-generic: Simplify MakefileRicardo Ribalda Delgado
As a result of the specific board removal, the Makefiles can be simplified. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: pp405-generic: Simplify MakefileRicardo Ribalda Delgado
2016-01-27mailaddr: Update mail addressRicardo Ribalda Delgado
The old mail address will stop working soon. Update it all the files Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27xilinx-ppc440: Remove support for v5fx30tevalRicardo Ribalda Delgado
It is just a specialized version of xilinx-ppc440 Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
