path: root/board
2015-08-23Merge git://git.denx.de/u-boot-socfpgaTom Rini
Conflicts: configs/socfpga_arria5_defconfig configs/socfpga_cyclone5_defconfig configs/socfpga_socrates_defconfig Merged these by hand and re-ran savedefconfig on them. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-23arm: socfpga: Fix ArriaV SoCDK PLL configMarek Vasut
Pull out the ArriaV SoCDK clock config from ancient Altera U-Boot "rel_socfpga_v2013.01.01_15.05.01_pr" and implant those values into mainline to get a booting ArriaV SoCDK. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-23arm: socfpga: Fix MAINTAINERS entry for CV/AV SoCDKMarek Vasut
Repair the maintainer entries so they match the current state of code. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-23arm: socfpga: Make the pinmux table const u8Marek Vasut
Now that we're actually converting the QTS-generated header files, we can even adjust their data types. A good candidate for this is the pinmux table, where each entry can have value in the range of 0..3, but each element is declared as unsigned long. By changing the type to u8, we can save over 600 Bytes from the SPL, so do it. This patch also constifies the array. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-23arm: socfpga: Switch to filtered QTS filesMarek Vasut
2015-08-23arm: socfpga: Remove AV-specific parts from CV-SoCDKMarek Vasut
Just remove the ArriaV specific parts from the CycloneV SoCDK board and they are no longer needed now. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-23arm: socfpga: Remove CV-specific parts from AV-SoCDKMarek Vasut
Just remove the CycloneV specific parts from the ArriaV SoCDK board and they are no longer needed now. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-23arm: socfpga: Split Altera socfpga into AV and CV SoCDKMarek Vasut
The board/altera/socfpga directory is not a generic SoCFPGA machine anymore, but instead it represents the Altera SoCDK board. To make matters more complicated, it represents both CycloneV and ArriaV variant. On the other hand, nowadays, the content of this board directory is mostly comprised of QTS-generated header files, while all the generic code is in arch/arm/mach-socfpga already. Thus, this patch splits the board/altera/socfpga into a separate board directory for ArriaV SoCDK and CycloneV SoCDK, so that each can be populated with the correct QTS-generated header files for that particular board. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-23arm: socfpga: Move wrappers into platform directoryMarek Vasut
Move the wrappers for QTS-generated files into platform directory out of the board directory. The trick here is to add -I to CFLAGS such that it points to the board directory in source tree and thus the qts/ directory there is still reachable. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-21ARM: at91: sama5d3xek: use a $dtb_name to load dtbWu, Josh
Since sama5d3xek boards has different type of dtb blobs, so we need to detect the cpu type in runtime. So we add a new variable $dtb_name. if $dtb_name is not defined, we just use at91-${board_name}.dtb as the $dtb_name. Otherwise, we will just load the dtb with $dtb_name. For sama5d3xek, we will detect cpu type and make up $dtb_name in runtime. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21arm: at91: add support for mini-box picosam9g45 boardErik van Luijk
Bootlog: U-Boot SPL 2015.10-rc1-00452-g96a7ed1 (Aug 17 2015 - 10:32:21) mci: setting clock 258000 Hz, block size 512 mci: setting clock 258000 Hz, block size 512 mci: setting clock 258000 Hz, block size 512 mci: setting clock 33024000 Hz, block size 512 reading u-boot.img reading u-boot.img U-Boot 2015.10-rc1-00452-g96a7ed1 (Aug 17 2015 - 10:32:21 +0000) CPU: AT91SAM9G45 Crystal frequency: 12 MHz CPU clock : 400 MHz Master clock : 133.333 MHz Watchdog enabled DRAM: 256 MiB WARNING: Caches not enabled MMC: mci: 0 mci: setting clock 260416 Hz, block size 512 mci: setting clock 260416 Hz, block size 512 mci: setting clock 260416 Hz, block size 512 mci: setting clock 33333333 Hz, block size 512 reading uboot.env In: serial Out: serial Err: serial Net: macb0 Error: macb0 address not set. Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [add 'picosam9g45_defconfig' to MAINTAINERS] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-21arm: at91: pmc: replace the constant with a define in at91_pmc.hErik van Luijk
To enable the clocks on the at91 boards a constant (0x4) is used. This is replaced with a define in at91_pmc.h (1 << 2). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-21arm: at91: at91sam9m10g45ek/corvus remove useless chip select 1 initErik van Luijk
On these boards the DDR is connected to a dedicated controller and not to chip select 1 of the EBI. Signed-off-by: Erik van Luijk <evanluijk@interact.nl> Tested-by: Erik van Luijk <evanluijk@interact.nl>
2015-08-21arm: at91: mpddr: allow multiple DDR controllersErik van Luijk
The mpddr.c depends on ATMEL_BASE_MPDDRC for the base address to configure the controller. This cannot be used when there is more than one controller (i.e. AT91SAM9G45, AT91SAM9M10). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [remove 'new blank line at EOF'] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-20ARM: davinci: remove support for cam_enc_4xxMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2015-08-19zynqmp: usb: Add usb dwc3 driver support for zynqmpSiva Durga Prasad Paladugu
Added usb dwc3 driver support for zynqmp this also supports the DFU and LTHOR to download the linux images on to RAM and cen be booted from those linux images. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19board: Xilinx: zynqmp: Define checkboard() functionSiva Durga Prasad Paladugu
Define checkboard() function for zynqMP Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-18spl: move SPL driver entries to driver/MakefileMasahiro Yamada
Just preparing for upcoming cleaning. The board-specific linker script board/vpac270/u-boot-spl.lds has been touched to avoid build error. It does not change the size of spl/u-boot-spl.bin for this board, so it should be OK. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-17arm: mvebu: db-88f6820-gp: Enable PCI supportStefan Roese
This patch enabled the MVEBU PCIe support on the db-88f6820-gp A38x eval board. It also enabled the Intel E1000 driver support and adds the initialization of PCIe network controllers to the board code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <eibach@gdsys.de>
2015-08-17arm: mvebu: db-mv784mp-gp: Enable PCI supportStefan Roese
This patch enabled the MVEBU PCIe support on the db-mv784mp-gp AXP eval board. It also enabled the Intel E1000 driver support and adds the initialization of PCIe network controllers to the board code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: Enable NAND controller on MVEBU SoC'sStefan Roese
This patch enables the NAND controller on the Armada XP/38x and provides a new function that returns the NAND controller input clock. This function will be used by the MVEBU NAND driver. As part of this patch, the multiple BIT macro definitions are moved to a common place in soc.h. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Peter Morrow <peter@senient.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-14Merge git://git.denx.de/u-boot-x86Tom Rini
2015-08-14powerpc: ipek01: convert to generic boardAnatolij Gustschin
Also update maintainer info. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2015-08-14powerpc: inka4x0: convert to generic boardAnatolij Gustschin
2015-08-14x86: Convert minnowmax to use CONFIG_DM_NETSimon Glass
Move to driver model for networking on minnowmax. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14cm5200: fix FAT function prototypesStephen Warren
Remove FAT function prototypes from the cm5200 firmware update code, and include the relevant headers instead. This exposes the fact that the custom prototyoe for do_fat_read() in this file was incorrect. Rather than simply fixing the call-site, replace do_fat_read() with fat_exists(). This removes the only use of do_fat_read() outside of the FAT code. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-08-14sunxi: Display: Add support for eDP panels connected via an anx9804 bridgeHans de Goede
Add support for 4 1.62G lane eDP panels connected via an anx9804 bridge, such as found on the Colombus devkit. While at it also fix the wrong indentation of the SSD2828 Kconfig help text in board/sunxi/Kconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-14sunxi: Add support for the Auxtek-T003 HDMI stickHans de Goede
The Auxtek-T003 HDMI stick is an A10s based HDMI stick with USB wifi, and composite video out support. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-13colibri_t20: fix reset out pinMarcel Ziswiler
Make sure SODIMM pin 87 nRESET_OUT is released properly by explicitly setting its pin mux function to GMI. This solves some issues with e.g. USB not being fully operational on carrier boards with USB hubs connected to reset if U-Boot got loaded via recovery mode aka rcm. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13apalis/colibri_t20/30: clean-upMarcel Ziswiler
Various clean-ups either in comments, order or spacing without any functional impact: - Add some comments in the device trees resp. reorder some parameters for consistency across all our modules. - Sort some include files alphabetically (while leaving common.h on top of course). - Streamline some comments in the configuration files and fix the spacing from using spaces to tabs. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13colibri_t20: disable PMIC sleep mode on low supply voltageMarcel Ziswiler
The Colibri T20's PMIC enters a sleep mode on low supply voltage < 3.0V ±2.5% (2.92...3.08V). Rising the main supply voltage again does not bring it back to regular operation. Not even a full reset does bring the module back. A full power cycle was required to reboot the system. A long positive pulse on the PMICs resume pin also reboots the system but this pin is only accessible as a test point on the module. This patch configures the PMIC through I2C to not enter this sleep mode plus force it to normal state upon sleep request exit should this ever happen. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13colibri_t20: add lcd display supportMarcel Ziswiler
Add LCD display support defaulting to VESA VGA resolution. Different resolutions configurable via device tree. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13apalis/colibri_t20/t30: integrate recovery mode detectionMarcel Ziswiler
Allow detecting whether or not U-Boot was launched through the recovery mode of the resp. NVIDIA SoC. Make use of a board specific arch_misc_init() and enable the same via CONFIG_ARCH_MISC_INIT configuration option. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-12dra7xx: Move CONS_INDEX to Kconfig and enable CONFIG_SPL_STACK_ADDRTom Rini
- Move the CONS_INDEX selection out of CONFIG_SYS_EXTRA_OPTIONS and into Kconfig proper. - While in here, enable CONFIG_SPL_STACK_ADDR Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12arm: am437x: Introduce new board cm-t43Nikita Kiryanov
Add initial support for CM-T43, an AM437x based SoM. This support includes: serial, MMC/eMMC, NAND, USB, ETH, I2C, GPIO, DRAM detection. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-08-12ARM64: hikey: Add a README for this board.Peter Griffin
To help others with compiling and flashing ATF and u-boot add a README for this board. Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
2015-08-12ARM64: hikey: hi6220: Add u-boot support for the 96boards CE HiKey board.Peter Griffin
HiKey is the first 96boards consumer edition compliant board. It features a hi6220 SoC which has eight ARM A53 cpu's. This initial port adds support for: - 1) Serial 2) eMMC / SD card 3) USB 4) GPIO It has been tested with Arm Trusted Firmware running u-boot as the BL33 executable. Notes: eMMC has been tested with basic reading of eMMC partition into DDR. I have not tested writing / erasing. Due to lack of clock control it won't be running in the most performant high speed mode. SD card slot has been tested for reading and booting kernels into DDR. It is also currently configured to save the u-boot environment to the SD card. USB has been tested with ASIX networking adapter to tftpboot kernels into DDR. On v2015.07-rc2 dhcp now works, and also USB mass storage are correctly enumerated. GPIO has been tested using gpio toggle GPIO4_1-3 to flash the LEDs. Basic SoC datasheet can be found here: - https://github.com/96boards/documentation/blob/master/hikey/ Hi6220V100_Multi-Mode_Application_Processor_Function_Description.pdf Board schematic can be found here: - https://github.com/96boards/documentation/blob/master/hikey/ 96Boards-Hikey-Rev-A1.pdf Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
2015-08-12ARM: keystone2: Remove unsed external clocksLokesh Vutla
Remove unused external clocks and make a common definition for all keystone platforms. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Cleanup init_pll definitionLokesh Vutla
This is just a cosmetic change that makes the calling of pll init code looks much cleaner. Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Fix dev and arm speed detectionLokesh Vutla
Use common devspeed and armspeed definitions. Also fix reading efuse bootrom register. Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12ARM: keystone2: Cleanup PLL init codeLokesh Vutla
There are two types of PLL for all keystone platforms: Main PLL, Secondary PLL. Instead of duplicating the same definition for each secondary PLL, have a common function which does initialization for both PLLs. And also add proper register definitions. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12integrator: switch to DM serial portLinus Walleij
This switches the Integrator boards over to using the device model for its serial ports. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-12ARM: bcm283x: Allocate all mailbox buffers cacheline alignedAlexander Stein
The mailbox buffer is required to be at least 16 bytes aligned, but for cache invalidation and/or flush it needs to be cacheline aligned. Use ALLOC_CACHE_ALIGN_BUFFER for all mailbox buffer allocations. Signed-off-by: Alexander Stein <alexanders83@web.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org>
2015-08-12sniper: Keypad support, with recovery and fastboot key combinationsPaul Kocialkowski
Using the twl4030 keypad allows booting directly into some special boot modes, such as recovery or fastboot. the VOL+ key will trigger a boot to recovery while the VOL- key will trigger a boot to fastboot. The G (gesture) key remains unused at this point. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-12sniper: Power off when the power on reason is not a valid onePaul Kocialkowski
In most cases, userspace will attempt to power off the device with HALT instead of POWER_OFF, which triggers a reset instead of a proper power off from the TWL4030. Hence, it is up to the bootloader to actually turn the device off when there is no reason to turn it on. A reboot identified with the OMAP reboot mode bits set is acceptable, as well as a power on reason from either the power button, USB or charger plug. Other cases should trigger a power off. Note that for the U-Boot reset command to take effect, we have to fill-in the OMAP reboot bits. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-12sniper: Power button reset supportPaul Kocialkowski
This adds support for resetting the device on a long press on the power button. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-12sniper: Fastboot supportPaul Kocialkowski
This adds support for the fastboot USB gadget, including flashing to the internal MMC and reboot to bootloader or not. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Update to use Kconfig for MUSB] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12sniper: Pass serial number through ATAGPaul Kocialkowski
Now that the serial number is correctly defined, we can pass it to the kernel using the (legacy) ATAG method. It will be automatically passed via device-tree when enabled. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-12sniper: Serial number support, obtained from die IDPaul Kocialkowski
The OMAP3 has some die-specific ID bits that we can use to give the device a (more or less) unique serial number. This is particularly useful for e.g. USB. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
