The Command set API needed to be updated for NAND flash
Signed-off-by: Justin Waters <justin.waters@timesys.com>
include/configs/at91sam9261ek.h
This patch came from Atmel. It fixes a number of NAND issues, as well as the
9263 rev B SPI bug.
This patch adds support for the AT91SAM9G20-EK board. It comes from the patch
u-boot-1.1.5_atmel_1.6.diff, courtesy of linux4sam.org.
The CMD API has changed significantly since the patches were originally written. This fixes these problems and cleans up the code a little.
MAKEALL
board/at91rm9200dk/at45.c
common/cmd_flash.c
drivers/Makefile
drivers/at45.c
drivers/dataflash.c
drivers/dm9000x.c
drivers/nand/nand.c
drivers/nand/nand_base.c
drivers/nand/nand_ids.c
drivers/nand/nand_util.c
examples/Makefile
include/asm-arm/mach-types.h
This patch adds support for the following boards:
AT91RM9200-EK
AT91SAM9260-EK
AT91SAM9261-EK
AT91SAM9263-EK
AT91SAM9RL-EK
It was downloaded from http://www.linux4sam.org/twiki/pub/Linux4SAM/U-Boot/u-boot-1.1.5_atmel_1.5.diff.bz2
lowlevel_init.S: Assembler messages:
lowlevel_init.S:413: Warning: Pretending global symbol used as branch target is local.
Looking at codes, the `memtest' and `clearmem' are intentional mixed
use of `global symbols' and `label' for debugging purpose. To make it
build, just disable global-symbols-use for now. As a result `memtest'
still remains as unused, but leave it be...
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
gth2.c: In function 'misc_init_r':
gth2.c:434: warning: pointer targets in passing argument 2 of 'setenv' differ in signedness
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
rsdproto board support has wrong I2C frequency and wrong return value
handling.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
Apply Grant Likely's backout to MPC5121 code, too.
Pointed out by Rafal Jaworowski <raj@semihalf.com>
Ugh. I *hate* to back this change out, but these compiler flags don't
work for relocation on all versions of GCC. I've not been able to
reproduce the environment in my setup (and hence, not been able to
find a combination that *does* work), so I've got no choice but to go
back to the old gcc flags and linker script.
This patch has been sent on:
- 29 Sep 2007
Although mips_io_port_base is currently a part of IDE command, it is quite
fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move
it to MIPS general part, and introduce `set_io_port_base()' from Linux.
This patch is triggered by multiple definition of `mips_io_port_base' build
error on gth2 (and tb0229 also needs this fix.)
board/gth2/libgth2.a(gth2.o): In function `log_serial_char':
/home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base'
common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here
make: *** [u-boot] Error 1
Basically, refactor the CFG_PIXIS_VBOOT_MASK values
into the separate board config files.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
usb_cpu_init() configures GPS USB pins, clocks, etc. and
is required for proper operation of kernel USB subsystem.
This setup was previously done in the kernel by the fixup
code which is being removed, thus low level init must be
done by U-boot now.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
To get the IDS8247 board working following are done:
- FCC2 is deactivated
- FCC1 is activated
- I2C is activated
- CFI driver is activated
- Adapted for use with LIBFDT
Signed-off-by: Sergej Stepanov <Sergej.Stepanov@ids.de>
grafic controller
Some commands for the STK52xx base board try to access the SM501 grafic
controller. But the TQM5200S has no grafic controller (only the TQM5200
and the TQM5200B have). This patch deactivates the commands accessing
the SM501 for the TQM5200S.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
grafic controller
The pxa255_idp being an old unmaintained board showed several issues:
1. CONFIG_INIT_CRITICAL was still defined.
2. Neither CONFIG_MAC_PARTITION nor CONFIG_DOS_PARTITION was defined.
3. Symbol flash_addr was undeclared.
4. The boards lowlevel_init function was still called memsetup.
5. The TEXT_BASE was still 0xa3000000 rather than 0xa3080000.
6. Using -march=armv5 instead of -march=armv5te resulted in lots of
'target CPU does not support interworking' warnings on recent compilers.
7. The PXA's serial driver redefined FFUART, BTUART and STUART used as
indexes rather than the register definitions from the pxa-regs header
file. Renamed them to FFUART_INDEX, BTUART_INDEX and STUART_INDEX to
avoid any ambiguities.
8. There were several redefinition warnings concerning ICMR, OSMR3,
OSCR, OWER, OIER, RCSR and CCCR in the PXA's assembly start file.
9. The board configuration file was rather outdated.
10. The part header file defined the vendor, product and revision arrays
as unsigned chars instead of just chars in the block_dev_desc_t
structure.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Per AN3221 (MPC5200B SDRAM Initialization and Configuration), the SDelay
register must be written a value of 0x00000004 as the first step of the
SDRAM contorller configuration.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Ensure that __got_start points to top of the `.got', and __got_end points
to bottom as well, so that we never fail to count num_got_entries.
On the MPC85xx CDS we have two issues:
1. The device tree fixup code did not check to see if the property we are
trying to update is actually found. Its possible that it would update
random memory starting at 0.
2. Newer Linux kernel's have moved the location of the PCI nodes to be
sibilings of the soc node and not children. The explicit PATH to the PCI
node would not be found for these device trees. Add the ability to handle
both paths. In the future we shouldn't handle such fixups by explicit path.
Correct to val8 from val.
Signed-off-by: Tony Li <tony.li@freescale.com>
