After having registered the following proper machine type migrate to
actually using it.
http://www.arm.linux.org.uk/developer/machines/list.php?id=4493
While at it clean-out some obsolete Cardhu specific device-tree
nodes resp. properties and clean-up the mach-types header file as well.
This is a purely cosmetic clean-up of the common Toradex board file.
Add optional aka commented out 800x480@60 timing suitable for EDT
ET070080DH6.
Turns out our simplistic approach of just blindly enabling LAN_V_BUS
and releasing LAN_RESET_N does not prove very reliable.
Properly resetting the chip for 5 microseconds after VBUS is stable
just like we do on the Colibri T20 seems to fix the issue.
Include "colibri_" prefix in our board compatibility tables in
preparation to properly distinguish future e.g. Apalis modules.
While at it bring the device tree matching more in par with Linux
kernel 3.1.10 from NVIDIA's L4T R16-R2.
- board.c: changes required by different PMIC variant
Turns out we completely missed properly resetting the ASIX USB to FastEthernet chip which from time-to-time on certain modules caused severe Ethernet detection faults only a complete hardware reset or power-cycle could eliminate. Properly resetting the chip for 5 microseconds after VBUS is stable seems to fix the issue.
If the USR partition we usually mount as root file system could not be
found which is e.g. the case for Android make sure mtdparts does not
start with a spurious coma separator the kernel would interpret as an
empty partition entry.
arch/arm/cpu/armv7/tegra3/warmboot_avp.c
arch/arm/include/asm/arch-tegra/clk_rst.h
Fix build issues introduced with NVIDIA partition table parsing
integration.
If booting from SD card BCT contains information specific to SD card
partition layout which is bogus if used for NAND partition parsing.
Simply fall back to default offset just like in recovery BCT case.
Note: in the future we could parse SD partition table as well to more
generically support SD booting from various card densities.
Rather than relying on hard-coded offsets actually make use of
partition table parsing implementation.
NVIDIA's NAND layout includes a partition table that can be used to
generically construct the mtdparts kernel boot argument. As an added
benefit this is completely independent of the underlying NAND part
used which differs with various module versions. It further allows our
customer easy adoption to their own custom partition layout.
Initial partition table parsing courtesy of Mitja Špes from LXNAV.
Activate BL_ON backlight GPIO PT4 on SODIMM pin 71.
While at it add commented out XGA 1024x768 display timing values as well.
Change tegra2's entry address to its default address 0x108000.
BUG=none
TEST=flashed with local built u-boot. Kernel boots up fine.
Change-Id: I6ff4ed1f2901df73b21d033fbd191550108e96b5
Signed-off-by: Jimmy Zhang <jimmzhang@nvidia.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/22171
This change allows to build a customized u-boot image, which includes
networking capabilities, provides diagnostic commands and supports
command line editing. These features are necessary to facilitate the
factory flow.
This image needs to be clearly distinguishable by ChromeOS. This is
achieved by modifying the value presented by the BINF.3 ACPI object.
To build this modified image one needs to add BUILD_FACTORY_IMAGE=1 to
the make invocation line.
BUG=chrome-os-partner:7952
TEST=manual
. build the new firmware image as follows:
USE='pcserial factory-mode' emerge-link chromeos-u-boot \
chromeos-coreboot chromeos-bootimage
. program the new image on the Link target with ChromeOS installed
on the SSD and restart it
. observe the target stop at u-boot command prompt (boot >)
. connect the target to an Ethernet network with a DHCP server
using a USB Ethernet dongle
. run the following commands at the u-boot prompt
boot > usb start
(Re)start USB...
USB: Register 203007 NbrPorts 7
USB EHCI 1.00
Register 20400b NbrPorts 11
USB EHCI 1.00
8 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
scanning bus for ethernet devices... 1 Ethernet Device(s) found
boot > dhcp
Waiting for Ethernet connection... done.
BOOTP broadcast 1
BOOTP broadcast 2
[a few warnings of unsupported DHCP options]
DHCP client bound to address 172.22.75.25
Using asx0 device
TFTP from server 172.16.255.7; our IP address is 172.22.75.25; sending through gateway 172.22.75.254
Filename 'pxelinux.0'.
Load address: 0x100000
Loading: ##
done
Bytes transferred = 15840 (3de0 hex)
boot >
. start ChromeOS on the target by issuing
vboot_twostop
. once ChromeOS boots check the mainfw_type crossystem reported value
localhost ~ # echo $(crossystem mainfw_type)
netboot
localhost ~ #
Change-Id: I1c50517754b6b5f773e432b9adec4b290f303e6f
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/21071
Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
Link's MRC produces significantly more training data than
the one used on Stumpy/Lumpy.
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
BUG=none
TEST=boot tested on Link
Change-Id: I9310c3bcc77fb4318db0635b97b115ab0eb7e5ec
Reviewed-on: https://gerrit.chromium.org/gerrit/18748
Tested-by: Stefan Reinauer <reinauer@chromium.org>
BUG=none
TEST=check fmap on generated binary for unique names
Change-Id: Id1ac5cf223ec6a333fc8f4c587e972afd087f90d
Signed-off-by: Duncan Laurie <dlaurie@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/18435
Reviewed-by: Stefan Reinauer <reinauer@google.com>
This saves 500ms in the RW BIOS path and still leaves 130K
overhead from the current U-boot size (372K) which should be
more than enough for any future updates on stumpy/lumpy.
This should be re-visited if/when vboot is smart enough to
just read+validate the actual binary within the section.
BUG=chrome-os-partner:8518
TEST=boot lumpy/stumpy through RW BIOS path and gather
timestamps to see 500ms improvement.
Change-Id: Ia714b4b95245f02f6e781247f820ca915bb403f5
Reviewed-on: https://gerrit.chromium.org/gerrit/18372
For some still unknown reason writes to localtion 0xcf9 do not cause
the Link to reboot, they cause it to shut down instead. While this
will have to be investigated and fixed, this change modifies the code
to use the keyboard controller (implemented by the EC on Link) to
restart the system.
Once the 0xcf9 problem is resolved, this change could be reverted.
BUG=chrome-os-partner:8397
TEST=manual
. when u-boot tires restarting the system it now reboots. before
this change it would just shut down.
Change-Id: I8076f897304f705e20ec8f2e30cce17d7fdd31c4
Reviewed-on: https://gerrit.chromium.org/gerrit/18332
Reviewed-by: Hung-Te Lin <hungte@chromium.org>
BUG=chromium-os:23496
TEST=build on Waluigi, Seaboard, Cardhu
Change-Id: I9ccd3085fb551e9887815592e9b518b6944beda7
Reviewed-on: https://gerrit.chromium.org/gerrit/14474
BUG=chrome-os-partner:8180
TEST=Built u-boot for emeraldlake2.
Change-Id: Iae62f047ddc102fbf530e1f8f9af34939971a6a3
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/18057
Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
This uses a format which is not supported by the upstream dtc, so
remove this.
BUG=chromium-os:23249
TEST=emerge-tegra2_kaen chromeos-u-boot with new dtc
Change-Id: I18b9420dbee20c2d115cc5ff1b13425faffe2a3e
Reviewed-on: https://gerrit.chromium.org/gerrit/17630
cold_reboot() should wait until the reset kicks in, instead of
returning and continuing in an undefined code path. Without this
patch, vboot_twostop will return, and secure_boot() will start
printing an error message, which results in a sporadic # on
the screen when pressing space or ESC on the dev screen in order
to go to recovery mode.
BUG=chrome-os-partner:7683
TEST=boot to dev screen on lumpy, press ESC or space. Observe
there is no # character printed before going to recovery
mode.
Signed-off-by: Stefan Reinauer <reinauer@google.com>
Change-Id: Ic2ee570032686e48603f0fb3b1ec9cbfae9451bc
Reviewed-on: https://gerrit.chromium.org/gerrit/17007
Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
This will trigger setting gbb.flags to 1 in cros_bundle_firmware so the
factory time is reduced.
GBB.flags will be changed in the factory process.
Also needs https://gerrit.chromium.org/gerrit/#change,16845
BUG=chrome-os-partner:7671
TEST=manual
emerge-stumpy chromeos-bootimage
gbb_utility -g --flags /build/stumpy/firmware/image.bin
Should report "flags: 0x00000001"
Change-Id: Ie05433ad737005bd5dcca2f88232b0a5bbd00df9
Reviewed-on: https://gerrit.chromium.org/gerrit/16113
split the LP0 code for tegra2 into common
LP0 code and chip specific warm boot code
TEST=build for Seaboard
Change-Id: Ie04bf9ac17482a37afd0f4515dc3aafeb4f48ae7
Reviewed-on: https://gerrit.chromium.org/gerrit/15883
This reverts commit 4c7502242627f64d91432cb4958be5f93f65fbff
Don't think this is the cause of http://code.google.com/p/chromium-os/issues/detail?id=26116, but it was in the same batch so I'm reverting in the process.
Change-Id: Icc013ced6c22e29d569ee4ca8ef73522154ec1a8
Reviewed-on: https://gerrit.chromium.org/gerrit/15561
Reviewed-by: Brian Harring <ferringb@chromium.org>
Tested-by: Brian Harring <ferringb@chromium.org>
Change-Id: Id9756c08f61502affa8beee636d883d01468e6ec
Reviewed-on: https://gerrit.chromium.org/gerrit/13799
For Waluigi, existing frame buffer address does not fall
under external memory map.
Setting it to the location set as per the default initialization.
TEST=Build ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi.
Change-Id: I2284d43c11f4d6622344429508b1f99e30929f19
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/14698
Enables common LCD support for Tegra2 and Tegra3
TEST=Built ok for Cardhu, Waluigi and Seaboard.
Change-Id: I938824045440cc4964c2ac6bf727a90ee5f129b4
Reviewed-on: https://gerrit.chromium.org/gerrit/14692
Add Waluigi keyboard map in Waluigi fdt
TEST=Build and tested on Waluigi.
Change-Id: Iaf39dabc2bef2f12c2f0b875cc3c397386dbb446
Reviewed-on: https://gerrit.chromium.org/gerrit/13929
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Add Keyboard controller option in tegra30 fdt.
TEST=Build ok for Waluigi, Seaboard and Cardhu.
Change-Id: I20fe7feed42a96edea138dc32c532e0d1d535226
Reviewed-on: https://gerrit.chromium.org/gerrit/14546
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Rename CONFIG_TEGRA2_KEYBOARD to common CONFIG_TEGRA_KEYBOARD
TEST=Build OK for Waluigi, Cardhu and Seaboard.
Change-Id: Ice2741622fe6434ba25ece8fe7fbe2ca989c44ef
Reviewed-on: https://gerrit.chromium.org/gerrit/13930
Expand existing 4x6 keyboard support to 16x8 keyboard.
Add Tegra2 specific changes under Tegra2 config "CONFIG_TEGRA2".
TEST=Tested on Waluigi.key press echoes the key on console.
Built ok for Cardhu and Seaboard.
Change-Id: Iab291a636d41b721d914014a5fe9ecc8775bf260
Reviewed-on: https://gerrit.chromium.org/gerrit/13928
BUG=none
TEST=manual
In dev-mode, press "Ctrl-U" with no USB stick inserted.
If "crossystem dev_boot_usb" is 0, you'll hear two 400Hz beeps.
If "crossystem dev_boot_usb" is 1, you'll hear one 200Hz beep.
Signed-off-by: Bill Richardson <wfrichar@google.com>
Change-Id: Ifd45a067ec8b922863331f13f3f4525ef40f7346
Reviewed-on: https://gerrit.chromium.org/gerrit/14529
Tested-by: Bill Richardson <wfrichar@chromium.org>
Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
Commit-Ready: Bill Richardson <wfrichar@chromium.org>
This is to match a change made in coreboot to align both
the header and the data to 16 bytes.
BUG=none
TEST=several cold boots to ensure that the MRC
data cache is not written out on every boot.
Change-Id: I6c9a01933264d6bd65958ddb93e8944c35e853c6
Reviewed-on: https://gerrit.chromium.org/gerrit/14096
dev_cfg is used by vboot_reference, hence we can't store our
u-boot environment there anymore. So create a section rw-environment
for that purpose.
BUG=chrome-os-partner:7264
TEST=boot tested on Stumpy
Change-Id: I15479f0f1a2aa111b742d2792052f48d660d122c
Reviewed-on: https://gerrit.chromium.org/gerrit/13022
We need to make sure that the LCD is ready before we complete booting, so
put this code into board_late_init().
BUG=chromium-os:22938
TEST=build and boot on Kaen
Change-Id: I97bd1fce6ac93d0639dd8fdb17bf83e8a78d2645
Reviewed-on: https://gerrit.chromium.org/gerrit/13213
Commit-Ready: Simon Glass <sjg@chromium.org>
The LCD init takes place over five stages. We want to hide this init
behind other operations, so turn it into a state machine which we can
call at any time.
For now, call it in lcd_enable().
Change-Id: Ia0b50ec74108ac4e015de12b7a9628426ea17656
Reviewed-on: https://gerrit.chromium.org/gerrit/13211
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
This will write magic value to APMC command port which
will trigger an SMI and cause coreboot to lock down
the ME, chipset, and CPU.
BUG=chrome-os-partner:6609
TEST=boot on stumpy+celeron and lumpy+i5 and ensure
the system still boots and that registers are locked
Change-Id: Ib30ea83044f5123205531a5e8ee88ee37de2dd86
Reviewed-on: https://gerrit.chromium.org/gerrit/13604
- Depends on related Coreboot changes
- There is a 64k region allocated so use it all
- Write each data blob in a 4K aligned container
- Find the last entry in the region to compare against coreboot copy
- Detect a full region and erase it all and start over at zero
BUG=chrome-os-partner:6962
TEST=manual
I started writing an autotest for this, but it was taking more time
than just doing a thorough manual test. I will finish the autotest
but for now I relied on manual testing and using /sys/firmware/log
to tell what happened in Coreboot/U-boot on each boot.
TEST CASE 1 - newly flashed image:
1) Install the new bios with flashrom and reboot
2) Check that no MRC data was found by Coreboot in firmware log:
"prepare_mrc_cache: invalid MRC data"
3) Check that U-boot wrote training data in firmware log:
"handle_mrc_cache: cached storage mismatch (-1/2895)"
"firmware_storage_spi: before adjustment"
"firmware_storage_spi: offset: 0x1ec000"
"firmware_storage_spi: length: 0xb58"
"firmware_storage_spi: after adjustment"
"firmware_storage_spi: length: 0x1000"
"firmware_storage_spi: offset: 0x001ec000"
"firmware_storage_spi: adjusted offset: 0x001ec000"
4) Check the flash to see if it has data in first slot
> flashrom -r /tmp/bios.now
> hexdump -Cv -s $((0x1ec000)) -n $((0x10000)) /tmp/bios.now
TEST CASE 2 - ensure that it uses the saved training data:
1) Reboot
2) Check that Coreboot used the training data in firmware log:
"prepare_mrc_cache: at ff9ec009, entry 0 size b4f checksum 9c"
3) Check that U-boot did not have to update the data in firmware log:
"handle_mrc_cache: cached storage match"
4) Check the flash to see if it still only has data in first slot:
TEST CASE 3 - ensure that it fills the next slot with new data:
1) Corrupt the seed checksum in CMOS:
> io_write8 0x70 0x78
> io_write8 0x71 0x00
2) Reboot
3) Check that Coreboot did not use cached data in firmware log:
"prepare_mrc_cache: invalid seed checksum"
4) Check that U-boot wrote new training data at new offset in firmware log:
"handle_mrc_cache: cached storage mismatch (2895/2895)"
"firmware_storage_spi: offset: 0x1ed000"
"firmware_storage_spi: offset: 0x001ed000"
"firmware_storage_spi: adjusted offset: 0x001ed000"
Change-Id: Ifffce29c5f9324f110c047a44a3f66d2e21cd6a4
Reviewed-on: https://gerrit.chromium.org/gerrit/13589
Reviewed-by: Ronald G. Minnich <rminnich@chromium.org>
Coreboot was always using MTRR 7 for the write-protect
cache entry that covers the ROM and U-boot was removing it.
However with 4GB configs we need more MTRRs for the BIOS
and so the WP MTRR needs to move. Instead coreboot will
always use the last available MTRR that is normally set
aside for OS use and U-boot can clear it before the OS.
BUG=chrome-os-partner:7350
TEST=boot 4GB stumpy with coreboot MTRR fixes and verify
that U-boot does not clear MTRR 7 but does clear MTRR 9.
Change-Id: Id6927325131b0b88043daa320a17847764626c0d
Reviewed-on: https://gerrit.chromium.org/gerrit/13477
Add plumbing to support this option to delay console init until
after relocation.
Change-Id: Iee3be9e2d0b51e6cf2f45a4408bfdde494c97d8b
Reviewed-on: https://gerrit.chromium.org/gerrit/13210
Move the serial init code into its own function to collect this all
in one place.
Change-Id: I70162d836fddfabedd9cfbc07d8f0dc920602af8
Reviewed-on: https://gerrit.chromium.org/gerrit/13204
We can support 8-bit eMMC and it is faster, so turn it on.
Change-Id: I1509594832d317a086fa066d1a37c78a1a52c7c3
Reviewed-on: https://gerrit.chromium.org/gerrit/13201
The Tegra2 can support this faster interface, so use it. It can reduce
data transfer time by about 40%.
Change-Id: I656773c83083cd53d3ee52433e324e73fbcdc999
Reviewed-on: https://gerrit.chromium.org/gerrit/13200
Reviewed-by: Tom Warren <twarren@nvidia.com>
This allows NAND to be disabled from the fdt easily.
Signed-off-by: Fred
Signed-off-by: John
Change-Id: Ibf9259f8621e73fcf943f54a20327513288fef06
Reviewed-on: https://gerrit.chromium.org/gerrit/12913
Implement the VbExBeep function so that the DEV screen can beep.
Much of this code was coppied from coreboot.
BUG=chrome-os-partner:7114
TEST=manual, check that Stumpy beeps on DEV screen timeout and when
booting from USB with dev_boot_usb=0.
Change-Id: Icd4eabb0b10cc3d226db71e6a2b52d3ed7eb25ef
Signed-off-by: Dylan Reid <dgreid@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/13110
