path: root/board
2012-10-23km83xx: add common support for km8309 boardsGerlando Falauto
Add support for Keymile boards based on mpc8309 (it would be only kmvect1 for now) Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> [#elseif -> #if to allow kmcoge5ne and kmeter1 to build successfully] Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-22Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxTom Rini
2012-10-22Merge branch 'master' of git://www.denx.de/git/u-boot-mmcTom Rini
2012-10-22powerpc/t4qds: Add T4QDS boardYork Sun
The T4240QDS is a high-performance computing evaluation, development and test platform supporting the T4240 QorIQ Power Architecture™ processor. SERDES Connections 32 lanes grouped into four 8-lane banks Two “front side” banks dedicated to Ethernet Two “back side” banks dedicated to other protocols DDR Controllers Three independant 64-bit DDR3 controllers Supports rates up to 2133 MHz data-rate Supports two DDR3/DDR3LP UDIMM/RDIMMs per controller QIXIS System Logic FPGA Each DDR controller has two DIMM slots. The first slot of each controller has up to 4 chip selects to support single-, dual- and quad-rank DIMMs. The second slot has only 2 chip selects to support single- and dual-rank DIMMs. At any given time, up to total 4 chip selects can be used. Detail information can be found in doc/README.t4qds Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22board/freescale/common: VSC3316/VSC3308 initialization codeShaveta Leekha
Add code for configuring VSC3316/3308 crosspoint switches Add README to understand the APIs - VSC 3316/3308 is a low-power, low-cost asynchronous crosspoint switch capable of data rates upto 11.5Gbps. VSC3316 has 16 input and 16 output ports whereas VSC3308 has 8 input and 8 output ports. Programming of these devices are performed by two-wire or four-wire serial interface. Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/board: add present2 register definition for QIXISShengzhou Liu
According to new QIXIS system definition, update QIXIS registers set to add present2 register instead of obsolete ctl_sys2. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22omap2424:Rename CONFIG_DRIVER_LAN91C96 to CONFIG_LAN91C96 as ↵Ashok
CONFIG_DRIVER_LAN91C96 is obsolete. Rename CONFIG_DRIVER_LAN91C96 to CONFIG_LAN91C9 as CONFIG_DRIVER_LAN91C96 is obsolete. Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22board/freescale/common:QIXIS:Fix magic number usagePrabhakar Kushwaha
QIXIS FPGA layout defines the address of registers but The actual register bit implementation is board-specific, So avoid use of magic numbers as it may vary across different boards's QIXIS FPGA implementation. Also, Avoid board specific defines in common/qixis.h Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22mmc: pxa: Flip over the remaining boards to pxa_mmc_genericMarek Vasut
Some of the boards still used the old PXA_MMC driver instead of the new generic one. Use the new one instead so the old can be removed and the generic MMC framework can be properly used. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andy Fleming <afleming@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-19Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: drivers/serial/serial_lh7a40x.c Signed-off-by: Tom Rini <trini@ti.com>
2012-10-19ColdFire: Fix the build error for Freescale m5282evb board.Jason Jin
Clean up the lds file and fix the environment build error. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-10-19ColdFire: Fix build error for astro mcf53731 board.Jason Jin
Fix the build error by clean up the lds file. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-10-18actux[123]: Update linker script for ELDK 4.2Tom Rini
With ELDK4.2 libserial.o is too large to fit in the area before the environment. Swap in libinput instead which is a little smaller. Cc: Michael Schwingen <michael@schwingen.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-17powerpc: delete Wind River SBC8560/8540 supportPaul Gortmaker
The sbc8548/60 (both similar, just variations in UART hardware) support has been removed from the linux kernel as of v3.6-rc1~132 so lets also now remove it from the u-boot tree as well. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-10-17Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2012-10-17Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2012-10-17split PCS440EP specific code from cmd_ide.cPavel Herrmann
Move specific ide_input_data and friends to board-specific file. Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17move CPC45 ide_led to the same file as other IDE hooksPavel Herrmann
Keep all IDE-related hooks and overrides in a single file, to avoid confusion Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17split CPC45 board-specific IDE functions from cmd_ide.cPavel Herrmann
Move input_data() and friends to board/cpc45/ide.c, as overrides for weak aliases in cmd_ide.c note: checkpatch emits warnings about using volatile Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17change all versions of input_data() and output_data() to global weak aliasesPavel Herrmann
This changes input_data() and friends from static function to global symbols under weak alias, to enable board specific overrides (and therefore get rid of board-specific code in cmd_ide.c) Also declare ide_bus_offset in the header file, so other files can use ATA_CURR_BASE as well. Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17split IVM power hooks from cmd_ide.cPavel Herrmann
Move power control code from ide_reset() into IVM-specific IDE reset code. Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17serial: Use default_serial_puts() in driversMarek Vasut
Replace the in-place ad-hoc implementation of serial_puts() within the drivers with default_serial_puts() call. This cuts down on the code duplication quite a bit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-17mpc82xx: Remove BMW board portStefan Roese
As the board seems to be unmaintained for some time, lets remove the support in mainline completely. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: James F. Dougherty <jfd@broadcom.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-10-17ARM: at91sam9x5: enable MCI0 support for 9x5ek board.Wu, Josh
Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-10-16MIPS: add board qemu-mips64 supportZhi-zhou Zhang
Both big-endian and little-endian are tested with below commands: Rom version: (Default, Now we config it as rom version) qemu-system-mips64el -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic qemu-system-mips64 -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic Ram version: qemu-system-mips64el -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic qemu-system-mips64 -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic Signed-off-by: Zhizhou Zhang <etou.zh@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2012-10-16MIPS: qemu_mips: move CONFIG_SYS_TEXT_BASE to qemu-mips.hZhi-zhou Zhang
We define CONFIG_SYS_TEXT_BASE in board's specified header file. So config.mk is useless, then remove it. Signed-off-by: Zhizhou Zhang <etou.zh@gmail.com>
2012-10-16i.MX6: mx6qsabrelite: Add splash screen supportEric Nelson
Adds support for HDMI, two LVDS panels and one RGB panel to the SABRE-Lite board. Displays supported: HDMI - 1024 x 768 for maximum compatibility Hannstar-XGA - 1024 x 768 LVDS (Freescale part number MCIMX-LVDS1) wsvga-lvds - 1024 x 600 LVDS (Boundary p/n Nit6X_1024x600) wvga-rgb - 800 x 480 RGB (Boundary p/n Nit6X_800x480) Since the ipuv3_fb display driver currently supports only a single display, this code auto-detects panel by probing the HDMI Phy for Hot Plug Detect or the I2C touch controller of the LVDS and RGB displays in the priority listed above. Setting 'panel' environment variable to one of the names above will override auto-detection. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2012-10-16i.MX: ipufb: add const to fb_videomode declarationsEric Nelson
2012-10-16i.MX: declare iomux_v3_cfg_t arrays as constEric Nelson
2012-10-16mx6qsabreauto: Pass the board revision to the kernelFabio Estevam
The kernel from Freescale expects that the bootloader passes the board revision. Read the board revision and pass it via get_board_rev(). Without passing the board revision the kernel does not operate properly as the initialization of peripherals are different in revA versus revB boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-16mxc: Fix SDHC multi-instance clockBenoît Thébaudeau
On mxc, each SDHC instance has a dedicated clock, so gd->sdhc_clk is not suitable for the multi-instance use case (initialization made directly with fsl_esdhc_initialize()). This patch fixes this issue by adding a configuration field for the SDHC input clock frequency. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Eric Bénard <eric@eukrea.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Andy Fleming <afleming@gmail.com>
2012-10-16mx35: Clean up lowlevel_initBenoît Thébaudeau
Clean up mx35 lowlevel_init: - Indent with tabs. - Fix comments. - Use defined values instead of literal constants. - Use defined macros instead of duplicating code. - Use macro parameters with default values instead of #define'd configs. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-16h2200: Add support for iPAQ h2200 palmtopŁukasz Dałek
Add basic support for HP iPAQ h2200 palmtop. h2200 palmtop was targeted to general consumers. It has 64 MB of RAM, 32 MB flash. No intergrated Wi-Fi nor Ethernet. Based on Intel PXA255 processor. It was shipped with Windows CE 4.2 operating system. Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
2012-10-16arm: rmobile: kzm9g: enable I2C2Tetsuyuki Kobayashi
Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-10-16arm: rmobile: kzm9g: enable I2C1Tetsuyuki Kobayashi
Supply clock to I2C1 and release resetting. Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-10-15mx6qsabreauto: Add Ethernet supportFabio Estevam
mx6qsabreauto has a AR8031 Gigabit PHY. Add support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx25: Clean up lowlevel_initBenoît Thébaudeau
Clean up mx25 lowlevel_init: - Add comments. - Do not use write32 repeatedly with the same value in order not to increase code size. - Make register values configurable. - Use macro parameters with default values instead of literal constants. - Use defined macros instead of duplicating code. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: John Rigby <jcrigby@gmail.com> Cc: Matthias Weisser <weisserm@arcor.de>
2012-10-15mx31: Fix PDR0_CSI_PODFBenoît Thébaudeau
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0 register is actually composed of two bit-fields: one pre-divider and one post-divider. This patch fixes the CCM access macros and the code using them accordingly. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5/6: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx6q: Add basic support for mx6qsabreautoFabio Estevam
mx6qsabreauto is a board based on mx6q SoC with the following features: - 2GB of DDR3 - 2 USB ports - 1 HDMI output port - SPI NOR - 2 LVDS LCD ports - Gigabit Ethernet - Camera - eMMC and SD card slot - Multichannel Audio - CAN - SATA - NAND - PCIE - Video Input Add very basic support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx6qsabresd: Add 8-bit USDHC supportFabio Estevam
USDHC3 has 8 pins wired in mx6qsabresd. Configure the extra pins. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx6qsabresd: Add Ethernet supportFabio Estevam
mx6qsabresd has a AR8031 Gigabit PHY. Add support for it. Also increase CONFIG_SYS_MALLOC_LEN so that FEC buffer allocation does not fail. Tested on 1Gbp and 100Mbps networks. Suggested-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-15mx6: Add basic support for mx6qsabresd board.Fabio Estevam
mx6qsabresd is a board based on mx6q SoC with the following features: - 1GB of DDR3 - 1 USB OTG port - 1 HDMI output port - SPI NOR - LVDS panel - Gigabit Ethernet - Camera Connector - eMMC and SD card slot - Audio Add very basic support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx6q: Factor out common DDR3 init codeFabio Estevam
Factor out common DDR3 initialization code, allowing easier maintainance of such scripts. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15tegra: nand: add board pinmuxLucas Stach
Boards may require a different pinmux setup for NAND than the default one. Add a way to call into board specific code to set this up. Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra: clean up board include hellLucas Stach
The prototypes used in board files were all scattered out, which lead to code duplication between SPL and normal U-Boot and some prototypes not actually being used. Consolidate this in a common board header. Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra20: rework UART GPIO handlingLucas Stach
Rename board provided gpio_config_uart() to gpio_early_init_uart() as it does the same thing as the equally called function provided by the uart-switch code. This allows to simply call this function in early board init whether or not we are building with CONFIG_UART_SWITCH defined. Also provide a weak symbol for this function, to avoid the need to provide this function for boards that don't need any fixup. This patch supersedes the earlier posted "tegra: convert gpio_config_uart to weak symbol". Build tested with MAKEALL -s tegra20 Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15Tegra20: Move some include files to arch-tegra for sharing with Tegra30Tom Warren
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h. Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20' 'root' file. All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK. Signed-off-by: Tom Warren <twarren@nvidia.com>
