path: root/board
2022-01-20Merge https://source.denx.de/u-boot/custodians/u-boot-marvellTom Rini
- fdt_support: Add fdt_for_each_node_by_compatible() helper macro (Marek) - turris_omnia: Fixup SATA or PCIe nodes at runtime in DT blob (Pali) - pci_mvebu: Add support for Kirkwood PCIe controllers (Pali) - SPL: More verifications for kwbimage in SPL (Pali) - mvebu: Remove comphy_update_map() (Pali) - Minor misc stuff
2022-01-20Merge tag 'u-boot-amlogic-20220120' of ↵Tom Rini
https://source.denx.de/u-boot/custodians/u-boot-amlogic - Disable CONFIG_NET_RANDOM_ETHADDR for android configs - meson64_android: define raw parts for bootloader to permit flashing with fastboot - vim3: configure serial# from ethaddr to permit using fastboot like sei510/610
2022-01-20Merge tag 'doc-2022-04-rc1' of ↵Tom Rini
https://source.denx.de/u-boot/custodians/u-boot-efi Pull request doc-2022-04-rc1 Replace @return by Return: in code comments.
2022-01-20arm: mvebu: turris_mox: Convert comphy_update_map() to board_fix_fdt()Pali Rohár
Code in board_fix_fdt() already detects connected MOX modules so there is no need to have custom comphy_update_map() function for setting serdes speeds. This change sets phy-mode for MOX SFP module (when present) to sgmii. Comphy driver then sets sgmii serdes speed for this module to 1.25G. Signed-off-by: Pali Rohár <pali@kernel.org> Reviewed-by: Stefan Roese <sr@denx.de>
2022-01-20arm: mvebu: turris_omnia: Fixup SATA or PCIe nodes at runtime in DT blobPali Rohár
On of the MiniPCIe ports on Turris Omnia is also a mSATA port. Whether it works in SATA or PCIe mode is determined by a strapping pin, which value is read from the MCU. We already determine which type of card is connected when configuring SerDeses. But until now we left both SATA and PCIe port 0 nodes in device tree enabled, and so the SATA driver is probed in U-Boot / Linux even if we know there is no mSATA card, and similarly PCIe driver tries to link on port 0 even if we know there is mSATA card, not a PCIe card. Fixup device tree blob to disable SATA node if mSATA card is not present, and to disable PCIe port 0 node if mSATA card is present. Do this for U-Boot's DT blob before relocation and also for kernel DT blob before booting. This ensures that software does not try to use SATA or PCIe HW when corresponding PHY is not configured. Signed-off-by: Pali Rohár <pali@kernel.org> [ refactored and fixed some issues ] Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de>
2022-01-20fdt_support: Add fdt_for_each_node_by_compatible() helper macroMarek Behún
Add macro fdt_for_each_node_by_compatible() to allow iterating over fdt nodes by compatible string. Convert various usages of off = fdt_node_offset_by_compatible(fdt, start, compat); while (off > 0) { code(); off = fdt_node_offset_by_compatible(fdt, off, compat); } and similar, to fdt_for_each_node_by_compatible(off, fdt, start, compat) code(); Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-01-20board: amlogic: vim3: configure serial# from ethaddrMattijs Korpershoek
The Khadas VIM3 and VIM3L boards, which are supported in Android via Yukawa [1] need a serial number for usb/fastboot enumeration. Whenever the environment does not provide a serial#, use the eth mac address as serial#. [1] https://source.android.com/setup/build/devices#vim3_and_vim3l_boards Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com> Reviewed-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Link: https://lore.kernel.org/r/20220119142400.127342-1-mkorpershoek@baylibre.com
2022-01-19doc: replace @return by Return:Heinrich Schuchardt
Sphinx expects Return: and not @return to indicate a return value. find . -name '*.c' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; find . -name '*.h' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2022-01-19Merge tag 'xilinx-for-v2022.04-rc1' of ↵Tom Rini
https://source.denx.de/u-boot/custodians/u-boot-microblaze Xilinx changes for v2022.04-rc1 gpio: - Add modepin driver net: - Save random mac addresses to eth variable zynqmp gem: - Add support for mdio bus DT description - Add support for reset and SGMII phy configuration - Reduce timeout for MDIO accesses zynqmp clk: - Fix clock handling for gem and usb phy: - Add zynqmp phy/serdes driver serial: - Add one missing compatible string microblaze: - Symbol alignement - SPL fixups - Code cleanups zynqmp: - Various dt changes, DP pre-reloc, gem resets, gem clocks - Switch SOM to shared psu configuration - Move dcache handling to firmware driver - Workaround gmii2rgmii DT description issue - Enable broadcasts again - Change firmware enablement logic - Small adjustement in firmware driver versal: - Support new mmc@ DT nodes - Fix run time variable handling - Add missing I2C_PMC ID for power domain
2022-01-19Merge https://source.denx.de/u-boot/custodians/u-boot-samsungTom Rini
- Updates for a{3,7}y17lte platforms
2022-01-18common: board_r: move init_addr_map() to init.hOvidiu Panait
asm/mmu.h include is currently guarded by CONFIG_ADDR_MAP ifdef because the header is only present on arm and powerpc. In order to remove the dependency on this header and the associated ifdef, move init_addr_map() declaration to init.h, since it is only called during the common init sequence. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
2022-01-17Merge branch '2022-01-15-TI-platform-updates'Tom Rini
- Let am335x_evm use the CPSW or PRUSS ethernet. - Implement timer_get_boot_us in the omap timer driver - gpmc bitflip, QSPI clock calculation on am437x, da8xx_gpio bugfixes - Assorted K3 updates
2022-01-17Merge tag 'u-boot-at91-2022.04-b' of ↵Tom Rini
https://source.denx.de/u-boot/custodians/u-boot-at91 Second set of u-boot-at91 features for the 2022.04 cycle: This small feature set includes few changes for sama7g5 and sama7g5ek: turn blue led on at boot, changes required for the Rev4 of the board, better sync with the Linux DT with regards to the new DT nodes.
2022-01-16board: ti: am335x: Choose CPSW or PRUSS configuration based on jumper settingAmjad Ouled-Ameur
The am335x-ice-v2 board's Ethernet ports can be configured in 'MII' or 'RMII' mode to be connected to 'PRUSS' or 'CPSW' Ethernet subsystems. This patch sets the environment variable 'ice_mii' to 'mii' or 'rmii' accordingly. Based on that we choose the appropriate board devicetree i.e. 'am335x-ice-v2.dtb' or 'am335x-ice-v2-prueth.dtb'. Since there are 2 Ethernet ports with 2 modes, there can be 4 configurations but for now we consider both ports in different modes to be an invalid configuration and prevent boot in that case. Signed-off-by: Roger Quadros <rogerq@ti.com> [Amjad: use overlay instead of using new am335x-ice-v2-prueth.dtb] Signed-off-by: Amjad Ouled-Ameur <aouledameur@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Make prueth_is_mii be marked __maybe_unused] Signed-off-by: Tom Rini <trini@konsulko.com>
2022-01-15board: ti: am64x: Init DRAM size in R5/A53 SPLVignesh Raghavendra
Call dram_init_banksize() from spl_board_init() otherwise TFTP download fails due to lmb_get_free_size() not able to find unreserved region due to lack of DRAM size info. Required to support Ethernet boot on AM64x. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
2022-01-14board: gdsys: Drop Dirk Eibach from MAINTAINERSMarek Behún
I got an <dirk.eibach@gdsys.cc>: host mxlb.ispgateway.de[80.67.18.126] said: 554 Sorry, no mailbox here by that name. (in reply to RCPT TO command) when sending e-mail to dirk.eibach@gdsys.cc. Drop Dirk Eibach from MAINTAINERS of board/gdsys/a38x and board/gdsys/mpc8308. The latter would be left maintainerless, add Mario Six <mario.six@gdsys.cc> (he is also maintainer of the former board). Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de>
2022-01-14arm: kirkwood: iConnect : Update board maintainerTony Dinh
Add myself as maintainer. Signed-off-by: Tony Dinh <mibodhi@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2022-01-14arm: kirkwood: iConnect : Add PCIe late initTony Dinh
- Add board_late_init function to enable pci_init Signed-off-by: Tony Dinh <mibodhi@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2022-01-14board: gdsys: a38x: Enable PCIe link 2 in spl_board_init()Pali Rohár
A385 controlcenterdc board does not use PCI DM properly and touches some PCIe devices directly in its board code. This controlcenterdc spl_board_init() function expects that PCIe link is already initialized. Link itself is initialized in a38x serdes code but this will change in future and link initialization will be postponed from U-Boot SPL to proper U-Boot. So explicitly enable PCIe link 2 in spl_board_init() function via SoC Control Register 1 to not break this code by future changes. This board has PCIe link 2 just x1, so no additional initialization (except enabling PCIe port) is needed. Signed-off-by: Pali Rohár <pali@kernel.org>
2022-01-14arm: mvebu: Convert board_pex_config() to CONFIG_SPL_BOARD_INITPali Rohár
The only user of board_pex_config() weak function is A385 controlcenterdc board. It looks like that code in its board_pex_config() function needs to be executed after PCIe link is up. Therefore put this code into spl_board_init() function which is called after a38x serdes initialization, and therefore it is after the serdes hws_pex_config() function finishes (which is the state before this change). With this change completely remove board_pex_config() function as it is not used anymore. Signed-off-by: Pali Rohár <pali@kernel.org>
2022-01-13board: sama7g5ek: set blue led on at boot timeMihai Sain
Set blue led on at boot time in order to highlight that u-boot is loaded. Signed-off-by: Mihai Sain <mihai.sain@microchip.com>
2022-01-13board: samsung: fix menu entries for a{3,7}y17lteHenrik Grimler
a7y17lte is called SM-A720F, and a3y17lte SM-A320F. a3y17lte also should select PINCTRL_EXYNOS78x0, not the (non-existent) PINCTRL_EXYNOS7880, and it has an Exynos 7870 SoC and not 7880. Fixes: 3e2095e960b4 ("board: samsung: add support for Galaxy A series of 2017 (a5y17lte)") Signed-off-by: Henrik Grimler <henrik@grimler.se> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2022-01-12vexpress64: Remove unused macro XR3PCI_ECAM_OFFSETPali Rohár
Macro XR3PCI_ECAM_OFFSET is unused and in case it would be needed in future it can be replaced by standard PCIE_ECAM_OFFSET macro from pci.h file. Signed-off-by: Pali Rohár <pali@kernel.org>
2022-01-10Merge branch 'next'Tom Rini
2022-01-09Merge tag 'u-boot-amlogic-20220107' of ↵Tom Rini
https://source.denx.de/u-boot/custodians/u-boot-amlogic into next - disable CONFIG_NET_RANDOM_ETHADDR when unnecessary on amlogic based configs - meson64_android: add board specific env settings, in order to support VIM3/L for android - add changes to support VIM3/L android boot by using meson64_android.h config
2022-01-08udoo: Call gpio_request()Fabio Estevam
Calling gpio_request() prior to its usage is now mandatory. This fixes the following GPIO errors: U-Boot SPL 2022.01-rc3-00067-g7a5be871c0ec (Dec 18 2021 - 17:45:07 -0300) Trying to boot from MMC1 U-Boot 2022.01-rc3-00067-g7a5be871c0ec (Dec 18 2021 - 17:45:07 -0300) CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: WDOG Model: Udoo i.MX6 Quad Board Board: Udoo Quad DRAM: 1 GiB MMC: FSL_SDHC: 2 Loading Environment from MMC... OK In: serial Out: serial Err: serial gpio@20a0000: set_dir_flags: error: gpio GPIO2_31 not reserved gpio@20a4000: set_dir_flags: error: gpio GPIO3_23 not reserved gpio@20b0000: set_dir_flags: error: gpio GPIO6_24 not reserved gpio@20b0000: set_dir_flags: error: gpio GPIO6_25 not reserved gpio@20b0000: set_dir_flags: error: gpio GPIO6_27 not reserved gpio@20b0000: set_dir_flags: error: gpio GPIO6_28 not reserved gpio@20b0000: set_dir_flags: error: gpio GPIO6_29 not reserved gpio@20a4000: set_value: error: gpio GPIO3_23 not reserved Net: Could not get PHY for FEC0: addr -2 No ethernet found. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Peter Robinson <pbrobinson@gmail.com>
2022-01-08udoo_spl: Initialize the eSDHC controller in SPLFabio Estevam
Currently, imx6q udoo board fails to boot like this: U-Boot SPL 2022.01-rc3-00061-g95ca715adad3 (Dec 18 2021 - 18:04:40 -0300) Trying to boot from MMC1 The reason is that the eSDHC controller is not initialized in SPL. Initialize the eSDHC controller in SPL via C code as DM is not used in SPL. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Peter Robinson <pbrobinson@gmail.com>
2022-01-07imx8mm_venice: switch to use binman to pack imagesTim Harvey
Use binman to pack images. Note that imx8mm_venice supports several boards via multiple DTB's thus in the fit node we must use: - fit,fdt-list = "of-list" - fdt-SEQ - config-SEQ Signed-off-by: Tim Harvey <tharvey@gateworks.com> Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2022-01-07imx8mm-cl-iot-gate: fix imximage intermediate binary namingMarcel Ziswiler
This fixes the following build time issue: ... BINMAN all binman: Error 1 running 'mkimage -d ./mkimage.spl.mkimage -n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000 ./mkimage-out.spl.mkimage': mkimage.flash.mkimage: Can't open: No such file or directory make: *** [Makefile:1094: all] Error 1 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2022-01-07imx: imx8mq use common imximage.cfgPeng Fan
After all these board switch to binman, we could use common imximage.cfg Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Patrick Wildt <patrick@blueri.se>
2022-01-07imx: pico-imx8mq: switch to use binmanPeng Fan
Switch to use binman to pack images Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Patrick Wildt <patrick@blueri.se>
2022-01-07imx: imx8mq_phanbell: switch to binmanPeng Fan
Switch to binman to pack images Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Patrick Wildt <patrick@blueri.se>
2022-01-07imx: imx8mq_evk: switch to binmanPeng Fan
2022-01-07imx8mn_beacon: Fix booting hang and switch to binmanAdam Ford
Somewhere along the line, the board stopped being able to boot. Rather than just fixing the issue, let's fix the issue and migrate to binman to eliminate a warning when using custom imx tools for generating the binary. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2022-01-07imx8mm_beacon: Switch to binman for generating imageAdam Ford
To eliminate a warning when using custom imx tools for generating a binary, use binman to generate flash.bin. Signed-off-by: Adam Ford <aford173@gmail.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-01-07udoo: neo: Do not print the Model informationFabio Estevam
By default the Model information from DT is printed: CPU: Freescale i.MX6SX rev1.2 996 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) at 63C Reset cause: POR Model: UDOO Neo Basic Board: UDOO Neo FULL I2C: ready As the udoo basic DT is used, such output may be confusing. Improve it by only printing the Board model instead, which is read from the board identification GPIOs. Signed-off-by: Fabio Estevam <festevam@gmail.com> Acked-by: Tommaso Merciai <tomm.merciai@gmail.com> Tested-by: Tommaso Merciai <tomm.merciai@gmail.com>
2022-01-07udoo: neo: Fix the board model printingFabio Estevam
Currently, the board model is not printed correctly: Board: UDOO Neo UNDEFINED Read the model type in SPL and store it the internal OCRAM, so that U-Boot proper can retrieve it correctly. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2022-01-07udoo_neo: Fix ethernetPeter Robinson
The ethernet has a RMII not RGMII, also needs DM_MDIO and finally initialise it later in the process as it's not needed that early on and not everything is ready so it locks up the device. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2022-01-07udoo_neo: Fixes for booting from the mSD cardPeter Robinson
This fixes booting from the mSD card from both SPL and when using it for the OS booting. It also cleans up a few mmc booting bits that are no longer needed. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2022-01-07udoo_neo: Call gpio_request()Peter Robinson
Calling gpio_request() prior to its usage is now mandatory. This fixes the following GPIO errors: gpio@20a8000: set_dir_flags: error: gpio GPIO4_16 not reserved gpio@20a8000: set_dir_flags: error: gpio GPIO4_13 not reserved gpio@20a8000: set_dir_flags: error: gpio GPIO4_0 not reserved gpio@20a8000: get_value: error: gpio GPIO4_13 not reserved gpio@20a8000: get_value: error: gpio GPIO4_0 not reserved gpio@20a0000: set_dir_flags: error: gpio GPIO2_1 not reserved gpio@20a0000: set_value: error: gpio GPIO2_1 not reserved Fixes: 191840ae99 ("ARM: imx: udoo_neo: Enable OF_CONTROL and DM gpio/pin control") Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2022-01-07riscv: sifive: Fix OF_BOARD boot failureBin Meng
When using QEMU to have a quick test of booting U-Boot S-mode payload directly without the needs of preparing the SPI flash or SD card images for SiFive Unleashed board, as per the instructions [1], it currently does not boot any more. This was caused by the OF_PRIOR_STAGE removal, as gd->fdt_blob no longer points to a valid DTB. OF_BOARD is supposed to replace OF_PRIOR_STAGE, hence we need to add the OF_BOARD logic in board_fdt_blob_setup(). [1] https://qemu.readthedocs.io/en/latest/system/riscv/sifive_u.html#running-u-boot Fixes: 2e8d2f88439d ("riscv: Remove OF_PRIOR_STAGE from RISC-V boards") Fixes: d6f8ab30a2af ("treewide: Remove OF_PRIOR_STAGE") Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Ilias Apalodimas <ilias.apalodimas@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-01-07rockchip: puma/lion: update MAINTAINERS fileQuentin Schulz
Philipp does not work at Theobroma Systems anymore so let's swap Philipp's address with mine. Cc: Philipp Tomsich <philipp.tomsich@vrull.eu> Cc: Quentin Schulz <foss+u-boot@0leil.net> Signed-off-by: Quentin Schulz <quentin.schulz@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@vrull.eu>
2022-01-07configs: prepare khadas-vim3{l}_ab_android for AOSP supportMattijs Korpershoek
In AOSP, both VIM3 and VIM3L have 2 bootloader flavors, depending on A/B enablement. For example, for vim3l, the naming is: - u-boot_kvim3l_noab.bin : legacy support - u-boot_kvim3l_ab.bin : A/B support Prepare a defconfig to support u-boot_kvim3_ab.bin and u-boot_kvim3l_ab.bin. This is identical to khadas-vim3{l}_ab_android but will be updated in the next commit. Also update partitioning tables for A/B support. Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Link: https://lore.kernel.org/r/20211122152207.219023-4-mkorpershoek@baylibre.com
2022-01-07configs: add khadas-vim3{l}_android for AOSP supportMattijs Korpershoek
The Khadas VIM3 and VIM3L board are well supported in AOSP[1]. However, there is no mainline U-Boot support for it. The U-Boot used in AOSP is based on a vendor tree [2] Add all the necessary bits to flash and boot Android for both Khadas VIM3 and VIM3L boards. For Android instructions, refer to [1] [1] https://source.android.com/setup/build/devices#vim3_and_vim3l_boards [2] https://gitlab.com/baylibre/amlogic/atv/u-boot Signed-off-by: Guillaume La Roque <glaroque@baylibre.com> Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Link: https://lore.kernel.org/r/20211122152207.219023-3-mkorpershoek@baylibre.com
2022-01-05versal: Return ENVL_NOWHERE instead of ENVL_UNKNOWNT Karthik Reddy
The system fails to boot without any environment location, so return ENVL_NOWHERE when there's nowhere to store the environment instead of ENVL_UNKNOWN. The same change was also done by commit 50918d0df5cb ("xilinx: Return ENVL_NOWHERE instead of ENVL_UNKNOWN") for zynq and zynqmp. Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Link: https://lore.kernel.org/r/e4ed36408f10159677ed8060bfd5289f3e0691fa.1637752614.git.michal.simek@xilinx.com
2022-01-05xilinx: Kconfig: add XILINX_OF_BOARD_DTB_ADDR default value for microblazeOvidiu Panait
The xilinx board_fdt_blob_setup() implementation makes use of XILINX_OF_BOARD_DTB_ADDR, but no default value is currently defined for microblaze. Add one so that microblaze could also work with CONFIG_OF_SEPARATE. Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com> Link: https://lore.kernel.org/r/20211202195657.246723-1-ovidiu.panait@windriver.com Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2022-01-05microblaze: add Kconfig symbol for the vector base addressOvidiu Panait
MicroBlaze vector base address is configurable (hdl C_BASE_VECTORS configuration parameter). Current code assumes that the reset vector location is always 0x0. Add the XILINX_MICROBLAZE0_VECTOR_BASE_ADDR Kconfig option so the user can adjust the reset vector address. Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com> Link: https://lore.kernel.org/r/20211130163358.2531677-8-ovidiu.panait@windriver.com Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2022-01-05microblaze: migrate CONFIG_SYS_USR_EXCEP to KconfigOvidiu Panait
Migrate CONFIG_SYS_USR_EXCEP to Kconfig. Also, rename it to XILINX_MICROBLAZE0_USR_EXCEP in order to match the naming convention of microblaze-generic Kconfig options. Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com> Link: https://lore.kernel.org/r/20211130163358.2531677-7-ovidiu.panait@windriver.com Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2022-01-05xilinx: firmware: Move dcache handling directly to pmufw load configMichal Simek
Core function should make sure that data is stored properly that's why move cache operations directly to zynqmp_pmufw_load_config_object() to be able to call it from other functions. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Link: https://lore.kernel.org/r/8c92edd3650ce34a3cfd1c1e4e9103980830b1fa.1637236800.git.michal.simek@xilinx.com
2022-01-05arm64: zynqmp: Switch SOM to shared psu configurationMichal Simek
Previous psu init was targeting SOM + KV260 carrier card and also contain configurations for other devices on carrier card. This config is removing all expected configurations for CC and let U-Boot to handle all of it self. This configuration is designed for SOM itself (and I would bet without eMMC). Signed-off-by: Michal Simek <michal.simek@xilinx.com> Link: https://lore.kernel.org/r/5782131058dc372befd3fdb4dceabeea5ba56606.1637236693.git.michal.simek@xilinx.com
