Also, remove all calls to eth_init() in boards that use MACB
Fix following warnings:
$ ./MAKEALL EVB64260 P3G4 ZUMA
Configuring for EVB64260 board...
mpsc.c: In function 'mpsc_putchar_early':
mpsc.c:121: warning: dereferencing type-punned pointer will break strict-aliasing rules
mpsc.c:127: warning: dereferencing type-punned pointer will break strict-aliasing rules
- Also modified the code to use io accessors.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Use a slighly larger value of CLK_CTRL for DDR at 667MHz
which fixes random crashes while linux booting.
Applicable for both NAND and NOR boot.
Signed-off-by: Sandeep Gopalpet <sandeep.kumar@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
CONFLICT (rename/add): Rename
board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile
in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b.
board/ti/tnetv107xevm/Makefile added in HEAD
But files were identical, so no problem.
This patch adds support for the LaCie ED Mini V2 product
which is based on the Marvell Orion5x SoC.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
Acked-by: Tom <Tom@bumblecow.com>
This patch adds support for the Samsung Goni board (S5PC110 SoC)
Provides initial support for TI OMAP-L138/DA850 SoC devices on
a Logic PD EVM board.
Provides:
Initial boot and configuration.
Support for i2c.
UART support (console).
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Wolfgang Denk <wd@denx.de>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
DA850/OMAP-L138 is a new SoC from Texas Instruments
(http://focus.ti.com/docs/prod/folders/print/omap-l138.html).
This SoC is similar to DA830/OMAP-L137 in many aspects. Hence
rename the da830 specific files and folders to da8xx to
accommodate DA850/OMAP-L138.
TI's DA850/OMAP-L138 platform is similar to DA830/OMAP-L137
in many aspects. So instead of repeating the same code in
multiple files, move the common code to a different file
and call those functions from the respective da830/da850
files.
Acked-by: Nick Thompson <nick.thompson@ge.com>
Pandora has a capacitor connected as backup battery, which allows
retaining RTC for some time while main battery is removed. Enable backup
battery charge function to charge that capacitor.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
This patch adds basic support for the AM3517EVM.
It includes:
- Board files (.c and .h)
- Default configuration file
- Updates for Makefile
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Sanjeev Premi <premi@ti.com>
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a
bunch on on-chip integrated peripherals. This patch adds support for the
TNETV107X EVM board.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
It includes:
Add the new board PM9G45 from Ronetix GmbH.
* AT91SAM9G45 MCU at 400Mhz.
* 128MB DDR2 SDRAM
* 256MB NAND
* 10/100 MBits Ethernet DP83848
* Serial number chip DS2401
The board is made as SODIMM200 module.
For more info www.ronatix.at or info@ronetix.at.
Signed-off-by: Asen Dimov <dimov@ronetix.at>
The ngPIXIS is a board-specific FPGA, but the definition of the registers
is mostly consistent. On boards where it matter, register 9 is called
'brdcfg1' instead of 'dma', so rename the variable in the ngpixis_t
definition.
The nios-32 arch is obsolete and broken. So it is removed.
This patch adds gpio support of Altera PIO component to the
nios2-generic board. Though it drives only gpio_led at the
moment, it supports bidirectional port to control bit-banging
I2C, NAND flash busy status or button switches, etc.
Tested-by: Ian Abbott <abbotti@mev.co.uk>
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
Match style we use almost everywhere else
call to reset PHY chip.
Current PHY Software Reset operation in guruplug does not
poll reset bit in control register to go to 0(auto clearing)
for making sure reset was successful.This patch uses standard
miiphy call miiphy_reset to make sure proper PHY reset operation.
Signed-off-by: Mahavir Jain <mjain@marvell.com>
Commit 15351855 "fsl-diu: Using I/O accessor to CCSR space" caused a
number of "passing argument 2 of 'out_be32' makes integer from pointer
without a cast" warnings; fix these.
Cc: Dave Liu <daveliu@freescale.com>
Cc: Jerry Huang <Chang-Ming.Huang@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
This patch removes the checkboard function from the build of
the 4k bootstrap section for the SIMPC8313 as it is not needed
in the spl build. This will allow > 100 bytes of extra room
for other uses.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
Due to some overlapping sections it's time to update TEXT_BASE
for this board.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Fix MVBLM7 and MVSMR Makefiles for correct out-of-tree building
(create "bootscript.img" in build directory instead of source
directory) and cleanup (remove "bootscript.img" when cleaning up).
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
On the MPC85xx platform if we have SATA its connected on SERDES.
Determing if SATA is enabled via sata_initialize should not be board
specific and thus we move it out of the MPC8536DS board code.
Additionally, now that we have is_serdes_configured() we can determine
if the given SATA port is enabled and error out if its not in the
driver.
The new is_serdes_configured covers a broader range of devices than the
PCI specific code. Use it instead as we convert away from the
is_fsl_pci_cfg() code.
Additionally move to setting LAWs for PCI based on if its configured.
Also updated PCI FDT fixup code to remove PCI controllers from dtb if
they are configured.
Using PPC I/O accessor to DIU I/O space instead of directly
read/write. It will prevent the dozen of compiler order issue
and PPC hardware order issue for accessing I/O space.
Using the toolchain(tc-fsl-x86lnx-e500-dp-4.3.74-2.i386.rpm)
can show up the order issue of DIU driver.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Add USB commands.
Rename autoscript to bootscript.
Add automatic bootscript image generation to makefile.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Added UPM array table, upmconfig, and Local Bus configuration support for SIMPC8313
Only one file apparently defines this function, and it merely stubs
it out. So if no one is defining/calling it, punt it.
Add ECC support for DDR RAM for MV64360 on esd CPCI-CPU/750 board.
This patch also adds the "pldver" command to display the CPLD
revision.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
The eNET uses the sc520 software timers rather than the PC/AT clones
Set all interrupts and timers up to be PC/AT compatible
Add a parameter to the 32-bit entry to indicate if entry is from Real
Mode or not. If entry is from Real Mode, execute the destructive 'sizer'
routine to determine memory size as we are booting cold and running in
Flash. If not entering from Real Mode, we are executing a U-Boot image
from RAM and therefore the memory size is already known (and running
'sizer' will destroy the running image)
There are now two 32-bit entry points. The first is the 'in RAM' entry
point which exists at the start of the U-Boot binary image. As such,
you can load u-boot.bin in RAM and jump directly to the load address
without needing to calculate any offsets. The second entry point is
used by the real-to-protected mode switch
This patch also changes TEXT_BASE to 0x6000000 (in RAM). You can load
the resulting image at 0x6000000 and simple go 0x6000000 from the u-boot
prompt
Hopefully a later patch will completely elliminate any dependency on
TEXT_BASE like a relocatable linux kernel (perfect world)
Change sc520 MMCR Access to use memory accessor functions
The patch adds SPI devices to the mx51evk board.
The MC13892 chip (PMIC) is supported.
Add support for the PMIC (MC13783) controller
and enables charging of the RTC battery.
Changes reflect modifications in the fsl_esdhc driver
(the clk_enable field war removed in the configuration structure).
