path: root/board
2017-09-16x86: Support Intel Cherry Hill boardBin Meng
This adds support to Intel Cherry Hill board, a board based on Intel Braswell SoC. The following devices are validated: - serial port as the serial console - on-board Realtek 8169 ethernet controller - SATA AHCI controller - EMMC/SDHC controller - USB 3.0 xHCI controller - PCIe x1 slot with a graphics card - ICH SPI controller with an 8MB Macronix SPI flash - Integrated graphics device as the video console Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15blk: Remove various places that do flush cache after readBin Meng
All these places seem to inherit the codes from the MMC driver where a FIXME was put in the comment. However the correct operation after read should be cache invalidate, not flush. The underlying drivers should be responsible for the cache operation. Remove these codes completely. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: York Sun <york.sun@nxp.com>
2017-09-14GPT: create block device for sandbox testingAlison Chaiken
Provide a Python function that creates a small block device for the purpose of testing the cmd/gpt.c or cmd/part.c functions in the u-boot sandbox. Signed-off-by: Alison Chaiken <alison@peloton-tech.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14arm: am57xx: cl-som-am57x: Use new pinctrl macrosSuman Anna
Commit 6ae4c3efbd62 ("ARM: DRA7: Add pinctrl register definitions") has added new macros for pinmux configuration in line with the kernel definitions. Fixup the current pinctrl data for the CompuLab CL-SOM-AM57x board to use these new macros to facilitate the removal of the old macros. NOTE: The PEN and PDIS macro values used previously were actually defined inversely, a value of 1 in bit position 16 actually means that the internal pullup/pulldown is disabled and not enabled as inferred by PEN. So, previous pinmux config data such as (PDIS | PTU) is confusing as it actually was meant for enabling internal pullup. The data is fixed up only to be equivalent to the previous data. Signed-off-by: Suman Anna <s-anna@ti.com>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-14board: atmel: Add SAMA5D27 SOM1 EK boardWenyou Yang
The SAMA5D27-SiP (System in Package) integrates the SAMA5D2 with 1Gbit DDR2-SDRAM in a single package. The SAMA5D27 SOM1 embeds a 64Mbit QSPI flash, KSZ8081 Phy and Mac-address EEPROM. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14board: sama5d2_xplained: Make SPL work on spiflashWenyou Yang
Because before switching to a lower clock source, we must switch the clock source first instead of last. So before configuring the PMC_MCKR register, invoke at91_mck_init_down() first. As said in datasheet, the the size of SPL must not exceed the maximum size allowed(64Kbytes). Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14atmel: common: Add function to display via DM_VIDEO's APIWenyou Yang
Add a function to display the company's logo and board information via the API from DM_VIDEO. This function can be shared by other atmel boards, so locate it in board/atmel/common folder. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-13ARM: davinci: Update da8xxevm MaintainersAdam Ford
The e-mail addresses for DA8XXEVM BOARD and DA850_AM18XXEVM BOARD are invalid. Remove DA8XXEVM. Update DA850_AM18XXEVM to have me be the maintainer since I work for Logic PD and have access to OMAP-L138 and AM1808 EVM kits. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-13Convert CONFIG_MAC_ADDR_IN_SPIFLASH et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MAC_ADDR_IN_SPIFLASH CONFIG_MAC_ADDR_IN_EEPROM Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-13davinci: da850evm: Make EEPROM MAC code configurableAdam Ford
There was a check for CONFIG_MAC_ADDR_IN_EEPROM and a check for CONFIG_MAC_ADDR_IN_SPIFLASH, however some of the EEPROM related code wasn't encapsulated inside the #if defined statement so the EEPROM code could get executed even when it wasn't explicitly enabled or wanted. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-13omap3: omap3_logic: Finish enabling fastboot on MUSBAdam Ford
Either the USB and Fastboot were never finished, or somehow it got lost. This puts enough hooks back into omap3logic to enable fastboot and hopefully prepare it for Kconfig conversion. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-12ARM: DRA72x: Add support for detection of DRA71x SR 2.1Vishal Mahaveer
DRA71x processors are reduced pin and software compatible derivative of DRA72 processors. Add support for detection of SR2.1 version of DRA71x family of processors. Signed-off-by: Vishal Mahaveer <vishalm@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-12davinci: da850-evm: switch to using TI_COMMON_CMD_OPTIONSAdam Ford
Like the OMAP-L138 LCDK before it, let's move the da850-evm and the variations to TI_COMMON_CMD_OPTIONS to cut back one some of the defconfig entries. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-12omap3: am3517_evm: Enable TI_COMMON_CMD_OPTIONAdam Ford
Enable TI_COMMON_CMD_OPTIONS and remove similar options from the defconfig. Updated with savedefconfig. Signed-off-by: Adam Ford <aford173@gmail.com> Tested-by: Derald D. Woods <woods.technical@gmail.com>
2017-09-12ARM: k2g: Add FIT image handler for PMMC firmwareAndrew F. Davis
The PMMC firmware should be bundled into a FIT image on HS devices to allow authentication/decryption, add a handler to process this PMMC firmware. Signed-off-by: Andrew F. Davis <afd@ti.com>
2017-09-12Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-09-12Merge git://git.denx.de/u-boot-dmTom Rini
2017-09-11sandbox: Convert SANDBOX_BITS_PER_LONG to KconfigBin Meng
Convert SANDBOX_BITS_PER_LONG to Kconfig and assign it a correct number depending on which host we are going to build and run. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-11board: sama5d4_xplained: Set mac address from eepromWenyou Yang
Add the code to set the ethernet mac address from eeprom by using the common code from the common folder. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-11board: sama5d2_xplained: Replace code to set mac addressWenyou Yang
Replace the code to set the ethernet mac address with the code from the common folder. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-11board: atmel: Create board/$(VENDOR)/common folderWenyou Yang
Create board/$(VENDOR)/common folder to accommodate the common code shared by other atmel boards, now put the code to set ethernet mac address from eeprom, which uses the i2c eeprom driver. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-11board: ti: am57xx: Add dt support for BeagleBoard-X15 revCLokesh Vutla
Add support for selecting proper dtb for am57xx BeagleBoard X15 revC u-boot from FIT Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-11board: ti: am571x: Add 666MHz support for AM571x IDKSteve Kipisz
AM571x supports DDR running at 666MHz. Right now it is clocked at 532MHz which is lower than what is supported. In order to have maximum performance on AM571-IDK, switch DDR to 666MHz. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-11board: ti: dra76: Add dt supportLokesh Vutla
Add support for selecting proper dtb for dra76x u-boot from FIT. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-11board: ti: dra76-evm: Add support for powering on mmc ldoLokesh Vutla
ldo4 is used to poweron mmc on dra76-evm. Enable it. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-11board: ti: dra76-evm: Add the pinmux dataLokesh Vutla
Adding pinmux and IODELAY data for dra76-evm. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-11board: ti: dra76-evm: Add DDR dataLokesh Vutla
dra76-evm has the ddr parts connectedi running at 666MHz: EMIF1: MT41K512M16HA-125 AIT:A x 2 EMIF2: MT41K512M8RH-125-AAT:E x 4 Add support for configuring the above DDR parts. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-11board: ti: dra76-evm: Add the pmic dataKeerthy
dra76-evm uses lp8736 and tps65917 pmic for powering on various peripherals. Add data for these pmics and register for dra76-evm. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-11board: ti: dra76-evm: Add epprom supportLokesh Vutla
The dra76-evm is a board based on TI's DRA76 processor Add eeprom support Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-11palmas: Add support for powering different ldosLokesh Vutla
It is not necessary that ldo1 is used to power on mmc. So, add support for passing ldo registers for powering on mmc. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-11arm: omap5+: Add board specific ldo poweringLokesh Vutla
It is not necessary all omap5+ based uses the same PMIC to poweron mmc. So add support for enabling mmc based on board. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-09-11MAINTAINERS: board: qcom: db410c: Maintainer changedJorge Ramirez-Ortiz
Replacing original author Mateusz Kulikowski <mateusz.kulikowski@gmail.com> as db410c maintainer Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-09-11armv8: ls1088aqds: Add support of EC1 and EC2Prabhakar Kushwaha
EC1 and EC2 are RGMII interface on ls1088aqds platform. This patch add support of RGMII with PHY and MDIO Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Amrita Kumari <amrita.kumari@nxp.com> Signed-off-by: Ashish Kumar <ashish.kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-11armv8: fsl-layerscape: Support to add RGMII for ls1088aqdsAshish Kumar
This patch adds support for RGMII protocol NXP's LDPAA2 support RGMII protocol. LS1088A is the first Soc supporting both RGMII and SGMII. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Amrita Kumari <amrita.kumari@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-11armv8: ls1088aqds: Add support of LS1088AQDSAshish Kumar
This patch add support of LS1088AQDS platform. The LS1088A QorIQTM Development System (QDS) is a high-performance computing, evaluation, and development platform that supports the LS1088A QorIQ Architecture processor. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-11armv8: ls1088ardb: Add support for LS1088ARDB platformAshish Kumar
LS1088A is an ARMv8 implementation. The LS1088ARDB is an evaluatoin platform that supports the LS1088A family SoCs. This patch add basic support of the platform. Signed-off-by: Alison Wang <alison.wang@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Raghav Dogra <raghav.dogra@nxp.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> [YS: Disabled NAND in board header file] Reviewed-by: York Sun <york.sun@nxp.com> WIP: disable NAND for LS1088ARDB
2017-09-11armv8: LS2080ARDB: Add secure boot defconfig for QSPI boot.Udit Agarwal
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> [YS: dropped redundant commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-11LS2080ARDB: QSPI boot: Secure Boot image validationUdit Agarwal
Adds header address for PPA to be validated during ESBC phase for ARCH_LS2088 and QSPI_BOOT. Moves sec_init prior to ppa_init(). It must be initialized before the PPA. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> [YS: revised commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-11fsl-layerscape: Consolidate registers space defination for CCI-400 busAshish Kumar
CoreLink Cache Coherent Interconnect (CCI) provides full cache coherency between two clusters of multi-core CPUs and I/O coherency for devices and I/O masters. This patch add new config option SYS_FSL_HAS_CCI400 and moves existing register space definaton of CCI-400 bus to fsl_immap to be shared. CONFIG_SYS_CCI400_ADDR is replaced with SYS_CCI400_OFFSET in Kconfig. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> [YS: revised commit message, squashed patches for armv8 and armv7] Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-07ARM: rmobile: Fix SD divider settings on Gen3Marek Vasut
On RCar M3 and on RCar H3 newer than and not including ES1.0, the SD clock must be divided by 4 rather than 2 because a hardware workaround present only in the H3 ES1.0 has been removed from these chips. U-Boot currently only supports M3 and H3 ES 2.0 and newer, so configure the SD pre-divider to 4 to prevent SD instability. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-07armv8: ls1043/ls1046aqds: add support for RGMII_TXIDMadalin Bucur
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: York Sun <york.sun@nxp.com>
2017-09-05Merge git://git.denx.de/u-boot-rockchipTom Rini
2017-09-05rockchip: phycore: Read configuration EEPROM & set ethaddr in late initWadim Egorov
Read SoM information from EEPROM and set ethaddr in late init. Signed-off-by: Wadim Egorov <w.egorov@phytec.de> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-04Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2017-09-05ARM: rmobile: Drop board_mmc_initMarek Vasut
The board_mmc_init() is no longer invoked when DM is used, so move all the pinmux config into board_init() instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-05ARM: rmobile: Replace CONFIG_RAVB with CONFIG_RENESAS_RAVB in boardsMarek Vasut
The configuration option name is the later, so replace usage of CONFIG_RAVB in board files with CONFIG_RENESAS_RAVB , otherwise the RAVB pinmux is not set and ethernet does not work. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-03omap3: evm: Fixes for CONFIG_NAND, SPL_OS_BOOT, USB, and environmentDerald D. Woods
- Pass MTDPARTS kernel arguments to kernel - Use Kconfig CONFIG_NAND instead of CONFIG_SYS_EXTRA_OPTIONS="NAND" - Call 'usb_stop' on kernel start - Update Falcon mode setup to match other OMAP3 boards - Use "uEnv.txt" as boot script instead of "boot.scr"
2017-09-01Merge git://git.denx.de/u-boot-sunxiTom Rini
2017-09-01sunxi: Fix CONFIG_SUNXI_GMAC referencesDave Prue
SUNXI_GMAC was still used to configure the code where as the same has been renamed and moved to Kconfig in below commit "sunxi: Move SUNXI_GMAC to Kconfig" (sha1: 4d43d065db3262f9a9918ba72457bf36dfb8e0bb) Signed-off-by: Dave Prue <dave@prue.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Mark Kettenis <kettenis@openbsd.org> Tested-by: Mark Kettenis <kettenis@openbsd.org> [Tweek commit message, config_whitelist.txt, build-whitelist.sh] Signed-off-by: Jagan Teki <jagan@openedev.com>
