Add usb ohci host support for at91sam9n12ek board
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Add support for following features:
- nand boot, with PMECC 2bit ECC for 512 bytes sector
- SPI flash boot
- SD card boot
- LCD support
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Add at91sam9g20_2mmc nand boot support. on this board, there is no
dataflash, so disable it
change one commet for at91sam9g20ek board
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Acked-by: Bo Shen <voice.shen@atmel.com>
This patch fix following building warning
- implicit declaration of function 'at91_gmacb_hw_init'
- implicit declaration of function 'at91_lcd_hw_init'
- implicit declaration of function 'atmel_mci_init'
board name.
In this patch, we
1. change the soc file and board directory to correct name.
2. change the macro name from CONFIG_AT91SAMA5 to CONFIG_SAMA5D3.
3. change the defconfig name to sama5d3xek_xxx.
- update file header
- remove useless code
- align the code
There is a rework on dtb files at kernel side requiring some changes for ISI
node update.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Before booting the Linux kernel, dtb will be updated. The atmel,mb-rev is
added and the isi pinctrl is updated for rev B motherboard.
drivers/mtd/spi/atmel.c
Due to grown code sizes the TQM85xx boards don't build any more with
some older tool chains (like ELDK 4.2). As these boards have long
reached EOL it seems a waste of effort trying to fix them. The vendor
has agreed to drop support for them, too. So let's get rid of them.
Cc: Stefan Roese <sr@denx.de>
cc: Kim Phillips <kim.phillips@freescale.com>
The wrong value was set as value of column of DDR memory for ap_sh4a_4a.
10 is the right value. This fixed this problem.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Signed-off-by: Chin Liang See <clsee@altera.com>
Signed-off-by: Pavel Machek <pavel@denx.de>
Acked-by: Tom Trini <trini@ti.com>
Cc: Wolfgang Denx <wd@denx.de>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
v8: Remove no_return attribute for reset_cpu
Based on v2012.10-rc2
Without usb-serial cable plugged at this stage, some
garbage is seen in UART RX FIFO, which blocks autoboot
progress. The fix makes sure to empty the RX FIFO,
before we wait for user input to interrupt autoboot.
Signed-off-by: Ramesh Chandrasekaran <ramesh.chandrasekaran@stericsson.com>
Add support for Xilinx Zynq board.
CC: Joe Hershberger <joe.hershberger@gmail.com>
This patch adds support for the X600 SPEAr600 based board. Its also
the first SPEAr600 board that uses the newly introduced SPEAr600
SPL support. Xloader is not necessary any more. By using the new
"u-boot.spr" make target, one image will generated containing both,
U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and
the main U-Boot with mkimage header.
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
If while booting the power switch is in OFF position, turn off the fan,
too.
Signed-off-by: Michael Walle <michael@walle.cc>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
The kmnusa board uses a mv88e6352 switch that is connected to the main
eth interface of the kirkwood. Therefore the switch must be configured
so that the kirkwood's egiga eth inferface can be used.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Cc: Holger Brunck <holger.brunck@keymile.com>
Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
The hardware design of the IB-NAS62x0 causes the SATA activity
LEDs to be on when idle by default. Reverse the polarity of the
activity LEDs in early init.
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Cc: Luka Perkov <uboot@lukaperkov.net>
Acked-by: Luka Perkov <uboot@lukaperkov.net>
Some boards may differ only in the SDRAM size. This function allows to
fix the size accordingly and we can use the same u-boot binary for both
boards.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Add support for new board iConnect from Iomega.
More information about the device can be found here:
http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735
Signed-off-by: Luka Perkov <uboot@lukaperkov.net>
Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com>
Tested-by: Tim Fletcher <tim@night-shade.org.uk>
This patch adds support for the LaCie boards Network Space v2 (Lite and
Mini). This two boards are derived from the Network Space v2 and a lot
of hardware caracteristics are shared.
- CPU: Marvell 88F6192 800Mhz
- SDRAM memory: 128MB DDR2 200Mhz
- 1 SATA port: internal
- Gigabit ethernet: PHY Marvell 88E1318
- Flash memory: SPI NOR 512KB (Macronix MX25L4005A)
- i2c EEPROM: 512 bytes (24C04 type)
- 2 USB2 ports (Lite only): host and host/device
- 1 push button
- 1 SATA LED (bi-color, blue and red)
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Support of the MINI2440 board from FriendlyARM from
an old version of u-boot :
http://repo.or.cz/r/u-boot-openmoko/mini2440.git
Currently, supporting only boot from NOR.
Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
This initializes GPIO, without using PFC framework in
board_early_init_f function. It is because it cannot initialize
normally when PFC is used.
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM,
Ethernet, and more.
This patch supports the following functions:
- 512MB DDR3-SDRAM
- Serial console (SCIF)
- Ethernet MAC(MII) & PHY(SMSC)
Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com>
Do soft power on reset in U-Boot reset command.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Problem:
Linux kernel hangs up when it write a file to NFS mounted directory.
Solution:
Modify bus controller setting for CS4, which connected smsc9221 ethernet
controller.
Detail:
Modify CS4BCR bit[29:28] (IWW[1:0]) from 00 to 01.
Modify CS4BCR bit[20:19] (IWRRD[1:0]) from 00 to 01.
Modify CS4BCR bit[17:16] (IWRRS[1:0]) from 00 to 01.
Modify CS4WCR bit[27:26] (WSW[1:0]) from 10 to 11
Modify CS4WCR bit[25:24] (WHW[1:0]) from 01 to 10
Modify CS4WCR bit[18:16] (WW[2:0]) from 101 to 111
Modify CS4WCR bit[13:11] (SW[2:0]) from 010 to 011
Modify CS4WCR bit[10:7] (WR[3:0]) from 1000 to 1011
Adjust low level hardware setting in s_init.
The KZM-A9-GT board has Renesas R-Mobile SH73A0, 512MB DDR2-SDRAM,
USB, Ethernet, and more.
- 512MB DDR2-SDRAM
- 16MB NOR Flash memory
- Ethernet (SMSC)
- I2C
Some of the previous changes caused the code to grow, which causes
errors like
u-boot.lds:76 cannot move location counter backwards (from 4000828c to 40008000)
when building with some older tool chains (like ELDK 4.2).
Adjust the linker script to make fit again.
This patch adds support for networking in SPL. Some devices are
capable of loading SPL via network so it makes sense to load the
main U-Boot binary via network too. This patch tries to use
existing network code as much as possible. Unfortunately, it depends
on environment which in turn depends on other code so SPL size
is increased significantly. No effort was done to decouple network
code and environment so far.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
Do not allow to overwrite it when video is enabled.
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de>
CC: Tom Rini <trini@ti.com>
The AP1000 defines a 'get_device' function to determine what board
revision we are on. Inline that checking as it conflicts with the
get_device() in <part.h> and is only used once.
This file documents when to build for da850evm and when to build for
da850_am18xxevm. It also documents how to write the u-boot.ais file to
persistent storage (such as SPI), in some cases as well as how to write
a recovery image.
Acked-by: Christian Riesch <christian.riesch@omicron.at>
Acked-by: Prabhakar Lad <prabhakar.lad@ti.com>
Only omap4/5 currently have a meaningful set of display text and overo
had been adding a function to display nothing. Change how this works to
be opt-in and only turned on for omap4/5 now.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
