The Empire Electronix D709 tablet is a fairly standard 7" A13 tablet,
featuring usb-wifi, a micro-sd slot, micro-usb otg and headphone jack.
Empire Electronix is written on the back of the tablet, the D709 model
info can be found in the about tablet menu in android.
The PCB has no markings to speak of.
This dts file is identical to the one submitted to the upstream kernel.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Drop all the common board code, since it is not completely useless.
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
This patch adds the necessary OF alias for the UDC node, which let's
the code locate the DWC2 UDC base address in OF instead of hard-coding
it into the U-Boot binary. The code is adjusted to use the address from
OF instead of the hard-coded one. Finally, the hard-coded address is
removed and USB DM support is enabled.
Cc: Lukasz Majewski <l.majewski@majess.pl>
Cc: Lukasz Majewski <l.majewski@samsung.com>
The Micrel PHY configuration is now done from OF, so hard-coding
the configuration into the board file is no longer necessary.
watchdog and gpio are not validated for SPL that's why do not use them.
LL_TEMAC is available at big endian MB and it is not properly tested
that's why the patch removes it.
Add ps7_init_gpl.c/h for the ZYBO board. This instance of the ps7_init
is generated by the Vivado 2015.3 tools using the system configuration
provided by Digilent located on their website.
Update the kconfig so that the defconfig is not overrided to use the
custom init ps7_init_gpl target by default.
Signed-off-by: Nathan Rossi <nathan@nathanrossi.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: "Sören Brinkmann" <soren.brinkmann@xilinx.com>
The driver is actually for the Designware DWC2 controller.
This patch renames the global s3c_udc.h header to dwc2_udc.h.
The rename is done automatically:
$ sed -i "s/s3c_udc\.h/dwc2_udc.h/g" \
`git grep "s3c_udc\.h" | cut -d : -f 1`
This patch is the second and final to rename global symbol,
the s3c_udc_probe() function.
$ sed -i "s/s3c_udc_probe/dwc2_udc_probe/g" \
`git grep s3c_udc_probe | cut -d : -f 1`
This patch is the first to rename global symbol, the struct
s3c_plat_otg_data.
$ sed -i "s/s3c_plat_otg_data/dwc2_plat_otg_data/g" \
`git grep s3c_plat_otg_data | cut -d : -f 1`
Change RCW for SD boot and NAND boot.
Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
LS1043ARDB Secure Boot Target from NOR has been added.
- Configs defined to enable esbc_validate.
- ESBC Address in header is made 64 bit.
- SMMU is re-configured in Bypass mode.
Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com>
MC and debug server are not board-specific. Move reserving memory to SoC
file, using the new board_reserve_ram_top function. Reduce debug server
memory by 2MB to make room for secure memory.
In the system with MC and debug server, the top of u-boot memory
is not the end of memory. PRAM is not used for this reservation.
Signed-off-by: York Sun <yorksun@freescale.com>
DDR has been set as secure in MMU tables. Non-secure master such
as SDHC DMA cannot access data correctly. Mixing secure and non-
secure MMU entries requirs the MMU tables themselves in secure
memory. This patch moves MMU tables into a secure DDR area.
Early MMU tables are changed to set DDR as non-secure. A new
table is added into final MMU tables so secure memory can have
2MB granuality.
gd->secure_ram tracks the location of this secure memory. For
ARMv8 SoCs, the RAM base is not zero and RAM is divided into several
banks. gd->secure_ram needs to be maintained before using. This
maintenance is board-specific, depending on the SoC and memory
bank of the secure memory falls into.
kylin board use rk3036 SOC, 512M sdram, 8G emmc.
This add some basic files required to allow the board
to output serial message and can run command(mmc info etc).
Signed-off-by: Lin Huang <hl@rock-chips.com>
Create a soc.c file to put the code for soc special settings.
Signed-off-by: Yuan Yao <yao.yuan@freescale.com>
This patch also expose the complete DDR region(s) to Linux.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
When creating phy-handle property, an unsigned int value is created by
fdt_create_phandle, and memcpy is used to get the value, since DTS is
big endian, the value cannot be used directly on little endian SoCs,
it should be converted by cpu_to_fdt32.
When 4 chip-selects are used, vref should use range 1 and CDT uses 80 ohm,
and 2T timing is enabled.
Signed-off-by: Samuel Egli <samuel.egli@siemens.com>
Cc: Roger Meier <r.meier@siemens.com>
Signed-off-by: Kamil Lulko <kamil.lulko@gmail.com>
Support qspi flashes for mx7dsabresd
1. introduce pin mux settings
2. enable qspi clock
3. introduce related macro definitions
Default QSPI is not enabled, since we need hardware rework to use QSPI,
see SPF-28590, page 9:
QSPI signals are muxed with EPDC_D[7:0]
When using QSPI: de-populate R388-R391, R396-R399
populate R392-R395, R299, R300
After hardware rework, define CONFIG_FSL_QSPI in mx7dsabresd.h. qspi
flashes can be deteced and read/erase/write. Log info:
=> sf probe
SF: Detected MX25L51235F with page size 256 Bytes, erase size 64 KiB, total 64 MiB
=> sf read 0x80000000 0 0x4000000
device 0 whole chip
SF: 67108864 bytes @ 0x0 Read: OK
=> sf erase 0 0x4000000
SF: 67108864 bytes @ 0x0 Erased: OK
=> sf write 0x80000000 0 0x4000000
device 0 whole chip
SF: 67108864 bytes @ 0x0 Written: OK
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Adrian Alonso <aalonso@freescale.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Reviewed-by: Jagan Teki <jteki@openedev.com>
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Add dts and defconfig for h8homletv2 board.
H8Homlet Proto v2.0 Board is A83T Dev Board by Allwinner.
It has UART, ethernet, USB, HDMI, etc ports on it.
A83T patches are tested on this board.
Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Enabled support for AXP818 in SPL and u-boot.
DCDC1, DCDC2, DCDC3 and DCSC5 are enabled.
Allwinner A83T is octa-core cortex-a7 SOC.
This enables support for A83T.
SMP is not yet supported.
These are currently dead codes. Until we have complete ACPI support,
we don't know if it works or not. Remove to avoid confusion.
This Kconfig option name indicates it has something to do with cpu
socket, however it is actually not the case. Remove it and move
options inside it to NORTHBRIDGE_INTEL_IVYBRIDGE.
There are some options which are never used, and also some options
which are selected by others but have never been a Kconfg option.
Clean these up.
Move driver to DM
- Enable DM_ETH by default for Zynq and ZynqMP
- Remove board_eth_init code
- Change miiphy_read function to return value instead of error code
based on DM requirement
- Do not enable EMIO DT support by default
The SR1500 board is a CycloneV based board, similar to the EBV
SoCrates, equipped with the following devices:
- SPI NOR
- eMMC
- Ethernet
Cc: Pavel Machek <pavel@denx.de>
Acked-by: Pavel Machek <pavel@denx.de>
For U-Boot's purposes, at present all we care about is ensuring there's
a model table entry.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
The RPi has two different schemes for encoding board revision values.
When adding RPi 2 support, I thought that the conflicting type field
values were to be interpreted based on bcm2835-vs-bcm2836. In fact, the
scheme bit determines the encoding. The RPi Zero uses the bcm2835 yet
uses the new encoding scheme. Fix the code to cater for this correctly.
