path: root/board
2003-12-07* Patch by Xue Ligong (Joe), 13 Nov 2003:wdenk
add Realtek 8019 ethernet driver * Patch by Yuli Barcohen, 13 Nov 2003: MPC826xADS/PQ2FADS cleanup * Patch by Anders Larsen, 12 Nov 2003: Update README to mark the PORTIO commands non-standard
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-12-06Accelerate booting on TRAB board: read and check autoupdate imageLABEL_2003_12_06_1550wdenk
headers first instead of always reading the whole images.
2003-11-25Add support for BMS2003 boardwdenk
(featuring a NEC NL6448BC33-54. 10.4", 640x480 TFT display). Fix NEC display names (it's 6440 [for 640x480], not 6640).
2003-11-17Fix flash driver for TRAB board (must use Unlock Bypass Reset commandLABEL_2003_11_26_MKRwdenk
to exit Unlock Bypass Mode); adjust timings for flash, SRAM and CPLD
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-11-07* Patch by Bernhard Kuhn, 28 Oct 2003:wdenk
Add low boot support for MPC5200 * Fix problem with dual PCMCIA support (NSCU) * Fix MPC5200 I2C initialization function
2003-10-30* Fix parameter passing to standalone images with bootm commandU-Boot-1_0_0wdenk
* Patch by Kyle Harris, 30 Oct 2003: Fix build errors for ixdp425 board * Patch by David M. Horn, 29 Oct 2003: Fixes to build under CYGWIN * Get IceCube MGT5100 working (again)
2003-10-29* Prepare for releasewdenk
* Fix problems in memory test on some boards (which was not non-destructive as intended) * Patch by Gary Jennejohn, 28 Oct 2003: Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack to prevent stack overflow on ARM systems
2003-10-26* Patch by Xiao Xianghua, 23 Oct 2003:wdenk
small patch for mpc85xx * Fix small problem in MPC5200 I2C driver * Fix FCC3 support on ATC board
2003-10-22Fix PCI problems on PPChameleon boardwdenk
2003-10-19* Fix PCI problems on PPChameleonEVBLABEL_2003_10_20_0025wdenk
* TRAB auto-update: image type patch by Martin Krause, 17 Oct 2003
2003-10-16TRAB auto-update: Base decision if we have to strip the imagewdenk
header on image type as encoded in the header
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
2003-10-09* Patch by Steven Scholz, 10 Oct 2003LABEL_2003_10_09_2320wdenk
- Add support for Altera FPGA ACEX1K * Patches by Thomas Lange, 09 Oct 2003: - Endian swap ATA identity for all big endian CPUs, not just PPC - MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize args to linux - add support for dbau1x00 board (MIPS32)
2003-10-09* Patches by Thomas Lange, 09 Oct 2003:wdenk
- fix cmd_ide.c for non ppc boards (read/write functions did not add ATA base address) - fix for shannon board - #ifdef CONFIG_IDE_8xx_DIRECT some otherwise unused code * Patch by Sangmoon Kim, 07 Oct 2003: add support for debris board
2003-10-09* Patch by Martin Krause, 09 Oct 2003:LABEL_2003_10_09_1515wdenk
Fixes for TRAB board - /board/trab/rs485.c: correct baudrate - /board/trab/cmd_trab.c: bug fix for problem with timer overflow in udelay(); fix some timing problems with adc controller - /board/trab/trab_fkt.c: add new commands: gain, eeprom and power; modify commands: touch and buzzer * Disable CONFIG_SUPPORT_VFAT when used with CONFIG_AUTO_UPDATE (quick & dirty workaround for rogue pointer problem in get_vfatname()); Use direct function calls for auto_update instead of hush commands
2003-10-08* Patch by Scott McNutt, 04 Oct 2003:wdenk
- add support for Altera Nios-32 CPU - add support for Nios Cyclone Development Kit (DK-1C20) * Patch by Steven Scholz, 29 Sep 2003: - A second parameter for bootm overwrites the load address for "Standalone Application" images. - bootm sets environment variable "filesize" to the resulting (uncompressed) data length for "Standalone Application" images when autostart is set to "no". Now you can do something like if bootm $fpgadata $some_free_ram ; then fpga load 0 $some_free_ram $filesize fi * Patch by Denis Peter, 25 Sept 2003: add support for the MIP405 Rev. C board
2003-10-08* Patch by Yuli Barcohen, 25 Sep 2003:wdenk
add support for Zephyr Engineering ZPC.1900 board * Patch by Anders Larsen, 23 Sep 2003: add CMD_PORTIO to CFG_CMD_NONSTD (commands in question are only implemented for the x86 architecture)
2003-10-07Use IH_TYPE_FILESYSTEM for TRAB "disk" images.wdenk
2003-10-06* Update TRAB auto update codeLABEL_2003_10_06_2355wdenk
* Make fatload set filesize environment variable fix potential buffer overlow problem * enable basic / medium / high-end configurations for PPChameleonEVB board; fix NAND code * enable TFTP client code to specify to the server the desired timeout value (see RFC-2349)
2003-09-30Improve SDRAM setup for TRAB boardLABEL_2003_10_01_1830dzu
2003-09-29* Adapt TRAB configuration and auto_update to new memory layoutdzu
2003-09-19"start" may be legitimately 0x0000wdenk
2003-09-18Work on TRAB's auto_update feature.LABEL_2003_09_18_2045wdenk
Cleanup for submitted patches.
2003-09-18* Patch by Rune Torgersen, 17 Sep 2003:wdenk
- Fixes for MPC8266 default config - Allow eth_loopback_test() on 8260 to use a subset of the FCC's
2003-09-18* Patches by Anders Larsen, 17 Sep 2003:wdenk
- fix spelling errors - set GD_FLG_DEVINIT flag only after device function pointers are valid - Allow CFG_ALT_MEMTEST on systems where address zero isn't writeable - enable 3.rd UART (ST-UART) on PXA(XScale) CPUs - trigger watchdog while waiting in serial driver
2003-09-17Support new configuration of TRAB board with more memorywdenk
Minor cleanup of comments
2003-09-17Add auto-update code for TRAB board using USB memory stickswdenk
2003-09-16Code cleanupLABEL_2003_09_16_2310wdenk
2003-09-15* Patches by Jon Diekema, 15 Sep 2003:wdenk
- add description for missing CFG_CMD_* entries in the README file - sacsng tweaks: include/configs/sacsng.h: + Support extra bootp options like: 2nd DNS and send hostname + Enabling ping and irq command + Adding defines for a bunch of misc configrabled options (patches for these options will be coming) + Adding watchdog support, but it isn't enabled yet. board/sacsng/sacsng.c: + Suppressing unneeded output when the quiet environment is non-zero. + show_boot_progress() now accepts any negative number as a failure code. + show_boot_progress() flashes the error code 5 times, and then resets the board to retry the boot from the top * Patch by Gleb Natapov, 14 Sep 2003: enable watchdog support for all MPC824x boards that have a watchdog
2003-09-13* Patch by David Müller, 13 Sep 2003:LABEL_2003_09_13_2100wdenk
various changes to VCMA9 board specific files * Add I2C support for MGT5100 / MPC5200
2003-09-12* Patch by Rune Torgersen, 11 Sep 2003:wdenk
Changed default memory option on MPC8266ADS to NOT be Page Based Interleave, since this doesn't work very well with the standard 16MB DIMM * Patch by George G. Davis, 12 Sep 2003: fix Makefile settings for sk98 driver
2003-09-12Move TRAB burn-in tests to TRAB board directoryLABEL_2003_09_12_1745wdenk
2003-09-12PMC405 update.stroese
2003-09-12PCI405 update.stroese
2003-09-12CPCI405(AB) update.stroese
2003-09-12ASH405 update.stroese
2003-09-12Xilinx jtag tool added.stroese
2003-09-12Board VOH405 added.stroese
2003-09-12Board PLU405 added.stroese
2003-09-12Board HUB405 added.stroese
2003-09-12Board DP405 added.stroese
2003-09-11* Patch by Martin Krause, 11 Sep 2003:LABEL_2003_09_12_0110wdenk
add burn-in tests for TRAB board * Enable instruction cache on MPC5200 board
2003-09-11* Patch by Gary Jennejohn, 11 Sep 2003:wdenk
- allow for longer timeouts for USB mass storage devices * Patch by Denis Peter, 11 Sep 2003: - fix USB data pointer assignment for bulk only transfer. - prevent to display erased directories in FAT filesystem. * Change output format for NAND flash - make it look like for other memory, too
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
2003-09-05* Add support for SK98xx driverLABEL_2003_09_06_0055wdenk
* Add PCI support for SL8245 board * Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB) or 1 x AM29LV652 (two LV065 in one chip = 16 MB); Run IPB at 133 Mhz; adjust the MII clock frequency accordingly * Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz) to allow for more accurate baudrate settings (error now 0.7% at 115 kbps, instead of 3.5% before) * Patch by Andreas Mohr, 4 Sep 2003: Fix a lot of spelling errors
2003-09-03Adjustments / cleanup for PPChameleon EVB boardwdenk
