path: root/board/zylonite
2006-12-21Added support for the TQM8272 board from TQHeiko Schocher
2006-04-25NAND support for zylonite board + some minor cleanup.Markus Klotzbuecher
2006-03-06Merge with /home/wd/git/u-boot/masterWolfgang Denk
Code cleanup.
2006-02-09basic u-boot is working, boots into the command shell.Markus Klotzbücher
2006-02-08Changes:Markus Klotzbücher
* lots of bugfixes in the assembler code * reverted hardware.h back to original * enabled hardware DRAM calibration * GCC-4 fix: modified GLOBAL_DATA_POINTER macro
2006-02-07Forgot to add files to zylonite branch.Markus Klotzbücher
