path: root/board/zylonite
2009-07-17Remove legacy NAND and disk on chip references from boards.Scott Wood
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-27{delta,zylonite}/lowlevel_init.S: fix typoWolfgang Denk
Commit 9d803d8c mistakenly changed some constants from 0x300 into 300 - this patch fixes it. Pointed out by Tom Evans <tom@ceos.com.au>, see http://article.gmane.org/gmane.comp.boot-loaders.u-boot/51992 for details. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-11-02Consolidate MAX/MIN definitionsAndy Fleming
There were several, now there is one (two if you count the lower-case versions). Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-09-13Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2008-09-10delta, zylonite: Update nand_oobinfo to nand_ecclayout.Scott Wood
This is part of the switch to newer upstream MTD code. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2007-07-09board/[q-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-12-21Added support for the TQM8272 board from TQHeiko Schocher
2006-04-25NAND support for zylonite board + some minor cleanup.Markus Klotzbuecher
2006-03-06Merge with /home/wd/git/u-boot/masterWolfgang Denk
Code cleanup.
2006-02-09basic u-boot is working, boots into the command shell.Markus Klotzbücher
2006-02-08Changes:Markus Klotzbücher
* lots of bugfixes in the assembler code * reverted hardware.h back to original * enabled hardware DRAM calibration * GCC-4 fix: modified GLOBAL_DATA_POINTER macro
2006-02-07Forgot to add files to zylonite branch.Markus Klotzbücher
