path: root/board/zpc1900
2007-07-04Consolidate mpc8260 linker scriptsGrant Likely
2006-03-12Memory configuration changes for ZPC.1900 boardWolfgang Denk
- Fix SDRAM timing on both local bus and 60x bus - Add support for second flash bank (SIMM) - Change boot flash base Patch by Yuli Barcohen, 05 Jun 2005
2004-10-09Patch by Yuli Barcohen, 22 Aug 2004:wdenk
- remove ZPC.1900 board-specific flash driver; switch the port to generic CFI driver; - port clean-up
2003-10-08* Patch by Yuli Barcohen, 25 Sep 2003:wdenk
add support for Zephyr Engineering ZPC.1900 board * Patch by Anders Larsen, 23 Sep 2003: add CMD_PORTIO to CFG_CMD_NONSTD (commands in question are only implemented for the x86 architecture)
