path: root/board/zipitz2
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-10-19PXA: Fix ZipitZ2 for RelocMarek Vasut
2010-10-19PXA: pxa-regs.h cleanupMarek Vasut
2010-07-14PXA: ZipitZ2 supportMarek Vasut
This patch adds support for Aeronix Zipit Z2 handheld. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
