path: root/board/zipitz2/zipitz2.c
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop setup_dram_config() wrapperSimon Glass
By making dram_init_banksize() return an error code we can drop the wrapper. Adjust this and clean up all implementations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-03-27zipitz2: enable cachesVasily Khoruzhick
It speeds up loading kernel from SD or USB a lot. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2016-03-27zipitz2: enable USB host supportVasily Khoruzhick
2016-03-27zipitz2: restore board supportVasily Khoruzhick
zipitz2 was dropped in 49d8899ba9c26335e4a12e01c18028fc5e40c796 Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
2015-09-11arm: Remove pxa255_idp, zipitz2 boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15serial: pxa: Make use of default_serial_console in serial_pxaMarek Vasut
Make use of the newly implemented weak default_serial_console in the serial_pxa driver. This removes all reimplementations of this function from board files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-03-26PXA: Fix warning in zipitz2Marek Vasut
Configuring for zipitz2 board... zipitz2.c: In function ‘board_mmc_init’: zipitz2.c:85:2: warning: implicit declaration of function ‘pxa_mmc_register’ [-Wimplicit-function-declaration] Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2012-03-26zipitz2: use pxa_mmc_gen as MMC driverVasily Khoruzhick
2011-12-06PXA: Rename pxa_dram_init to pxa2xx_dram_initMarek Vasut
2011-12-06PXA: Squash extern pxa_dram_init()Marek Vasut
2010-10-19PXA: Fix ZipitZ2 for RelocMarek Vasut
2010-10-19PXA: pxa-regs.h cleanupMarek Vasut
2010-07-14PXA: ZipitZ2 supportMarek Vasut
This patch adds support for Aeronix Zipit Z2 handheld. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
