path: root/board/xsengine
2008-02-07xsengine: rename board_post_init to board_late_initJean-Christophe PLAGNIOL-VILLARD
missing migration from "Cleanup of some init functions" in c837dcb1a316745092567bfe4fb266d0941884ff Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-10-24xsengine: Fix no partition type specified, use DOS as defaultJean-Christophe PLAGNIOL-VILLARD
2005-10-05Add support for S29GL064M-R3 flash chip on xsengine boardWolfgang Denk
Patch by Kurt Stremerch, 18 Apr 2005
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-07-01* Code cleanup (ARM mostly)wdenk
* Patch by Curt Brune, 17 May 2004: - Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC) - Add support for ESPD-Inc. EVB4510 Board
2004-06-09Patch by Kurt Stremerch, 28 May 2004:wdenk
Add support for Exys XSEngine board Some code cleanup.
