path: root/board/xsengine/Makefile
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-06-09Patch by Kurt Stremerch, 28 May 2004:wdenk
Add support for Exys XSEngine board Some code cleanup.
