path: root/board/xpedite1k/flash.c
2009-07-24xpedite1k: Use standard CFI flash driverPeter Tyser
Using the CFI flash driver will allow write access to the 16MB Intel StrataFlash present on the XPedite1000. The 512KB socketed (non CFI-compliant flash) will no longer be writable. The mapping of the 16MB Strata flash was moved to 0xff000000 and the 512KB AMD socketed flash was moved to 0xfe000000. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2004-02-06Patch by Travis Sawyer, 30 Dec 2003:wdenk
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices, select MDI port based on enabled EMAC device. Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX base PrPMC board.
