path: root/board/xilinx
2013-09-03Merge 'u-boot-microblaze/zynq' into (u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/include/asm/arch-zynq/hardware.h The conflict above was trivial and solved during merge.
2013-08-12zynq: Enable axi ethernet and emaclite driver initializationMichal Simek
Zynq can have axi ethernet and emaclite IPs in programmable logic. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-08-12zynq: Add new ddrc driver for ECC supportMichal Simek
The first 1MB is not initialized by first stage bootloader. Check if memory is setup to 16bit mode and ECC is enabled. If it is, clear the first 1MB. Also u-boot should report only the half size of memory. Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-08-12fpga: zynqpl: Add support for zc7100 device.Michal Simek
- Add support for zc7100 device. - FPGA programming on few of the SOC(zc7100) takes more than 1sec, hence increased the program time by 4sec to sync' all soc's. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-08-02xilinx: move microblaze-generic .dts to standard locationStephen Warren
Aside from microblaze, all other SoCs/boards/vendors store their DT files in board/$vendor/dts/$soc-$board.dts. Move microblaze-generic.dts to this location for consistency. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Michal Simek <monstr@monstr.eu>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-11Merge branch 'u-boot-pxa/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-05-09gpio: Add support for microblaze xilinx GPIOMichal Simek
Microblaze uses gpio which is connected to the system reset. Currently gpio subsystem wasn't used for it. Add gpio driver and change Microblaze reset logic to be done via gpio subsystem. There are various configurations which Microblaze can have that's why gpio_alloc/gpio_alloc_dual(for dual channel) function has been introduced and gpio can be allocated dynamically. Adding several gpios IP is also possible and supported. For listing gpio configuration please use "gpio status" command This patch also remove one compilation warning: microblaze-generic.c: In function 'do_reset': microblaze-generic.c:38:47: warning: operation on '*1073741824u' may be undefined [-Wsequence-point] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-06fpga: zynq: Add support for loading bitstreamMichal Simek
Devcfg device requires to load bitstream in binary format. But u-boot also has an option for loading bitstream in bit format. Let's handle both cases by zynqpl driver. Also add suport for loading partial bitstreams. The first driver version was done by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30mmc: Add support for Xilinx Zynq sdhci controllerMichal Simek
Add support for SD, MMC and eMMC card on Xilinx Zynq. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30net: gem: Preserve clk on emio interfaceDavid Andrey
Avoid overwriting GEMx_RCLK_CTRL and GEMx_CLK_CTRL if the Ethernet interface is connect on EMIO Do not enable emio for this standard board configuration for now. Signed-off-by: David Andrey <david.andrey@netmodule.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30net: gem: Pass phy address to initDavid Andrey
Pass the PHY address to the driver init to allow parallel use of both interfaces Signed-off-by: David Andrey <david.andrey@netmodule.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30zynq: Move macros to hardware.hMichal Simek
Add all fixed addresses to hardware.h and change petalinux configuration to support this. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30watchdog: Add support for Xilinx Microblaze watchdogMichal Simek
Watchdog can be used on Microblaze, PPC and Zynq hw designs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30microblaze: Disable all cpu features before resetMichal Simek
Fix microblaze soft reset function and disable all cpu features. Especially disable caches because IRQs were off by disable_interrupts(). Reported-by: John Williams <john.williams@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-04-30microblaze: Fix reset functionMichal Simek
Remove CONFIG_SYS_RESET_ADDRESS macro. It was there from historical point of view when soft reset was just jump to u-boot text start (not used right now). Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-04microblaze: Remove FSL support from generic boardMichal Simek
This code was targetting one specific Microblaze platform configuration which is obsolete and fsl bus isn't used in this way. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-04board: xilinx: Remove common folderMichal Simek
All these files was used for ancient xilinx drivers which are finally gone. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Rommel Custodio <sessyargc@gmail.com>
2013-02-04board: xilinx: Remove unused ancient i2c driverMichal Simek
There is new driver in the driver folder. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Rommel Custodio <sessyargc@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2012-10-04xilinx: Add new Zynq boardMichal Simek
Add support for Xilinx Zynq board. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> CC: Joe Hershberger <joe.hershberger@gmail.com>
2012-09-11microblaze: Clean microblaze initializationMichal Simek
Move board specific function to board_init function in board/ folder Remove externs from generic board.c Use board_init_f function in board.c file. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net>
2012-07-10microblaze: Wire up dts configurationStephan Linz
- enable OF control and embedded OF - set default device tree file name to 'microblaze' - add CPP to dtc proxy: board/xilinx/dts/microblaze.dts - add an empty but processable dts for microblaze-generic Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-07-09microblaze: Move individual board linker scripts to common script in cpu tree.Michal Simek
Unification for all microblaze boards. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-04-04microblaze: Wire up LL_TEMAC driver initializationStephan Linz
Initialize ll_temac driver. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-04-04microblaze: Add faked LL_TEMAC driver configurationStephan Linz
Expand the specific configuration for the microblaze-generic board in xparameters.h with a faked setup to enable the LL_TEMAC driver. Note: From now the microblaze-generic board is no longer a valid board configuration for a real piece of hardware. Rather than, we use the file config.mk and xparameters.h as a faked board configuration to force the compilation of all potential driver code for Microblaze systems. Signed-off-by: Stephan Linz <linz@li-pro.net>
2011-10-24microblaze: Wire up axi_ethernet driver initializationMichal Simek
Initialize axi_ethernet driver. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-23net: xilinx_enet: drop unused !NET_MULTI driverMike Frysinger
This driver doesn't support the NET_MULTI framework, and I can't find any boards/configs/files that reference this subdir, so punt it all. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23net: emaclite: Move RX/TX ping pong initialization toMichal Simek
Init RX/TX ping pong directly from board not in the driver. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-01-11xilinx-ppc4xx-generic: Fix Makefile to work with MAKEALLRicardo Ribalda Delgado
config.mk only mkdirs $(obj), but we have objects shared with other boards located on other dirs. This patch mkdirs the needed dirs for the xlnx-generic boards. Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-17xilinx-ppc4xx-generic: Use common u-boot.ldsRicardo Ribalda Delgado
Use common ppc4xx linker script for xilinx ppc440 and ppc405 related boards. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-12microblaze: Add support for NET_MULTI apiMichal Simek
Microblaze hasn't supported NET_MULTI support. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-24Merge branch 'master' of git://git.denx.de/u-boot-microblazeWolfgang Denk
2010-04-16microblaze: Move FSL initialization to board.cMichal Simek
Move FSL out of interrupt controller. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-13microblaze: Move cpu/microblaze/* to arch/microblaze/cpu/*Peter Tyser
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-03-28ml300: remove support for broken, orphaned boardWolfgang Denk
The ml300 board has a number of issues, but nobody cares about this long-orphaned board any more. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Michal Simek <monstr@monstr.eu>
2009-11-02ppc4xx: Add custom linker script to board/*/config.mkStefan Roese
These boards have special linker scripts right now. We can't use the common 4xx linker script here. So overrride the linker script (LDSCRIPT) in board/*/config.mk and choose the board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-14microblaze: Add sbss, scommon and COMMON symbols for clearingMichal Simek
2009-07-23unify HOST_CFLAGS and HOSTCFLAGSMike Frysinger
The top build system sets up HOSTCFLAGS a bit and exports it, but other places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the values stay in sync. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
