path: root/board/xilinx
2014-11-11zynq: Use GPLed files for SPLSoren Brinkmann
The latest Xilinx tools generate ps7_init files that are explicitly available under GPL. Change the makefile to allow drop in of those files for building the SPL. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Acked-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Reviewed-and-tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-08-30zynq: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Zynq board select menu to zynq/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="zynq"). Refactor board/xilinx/zynq/MAINTAINERS too. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Michal Simek <michal.simek@xilinx.com>
2014-07-23zynq: disable -Wstrict-prototypes option for ps7_init.cMasahiro Yamada
The files ps7_init.c and ps7_init.h are supposed to be generated by hw projects such as Vivado, PlanAhead and then to be copied into board/xilinx/zynq directory. But some prototypes in them cause annoying warning messages: CC spl/board/xilinx/zynq/ps7_init.o In file included from board/xilinx/zynq/ps7_init.c:50:0: board/xilinx/zynq/ps7_init.h:137:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.h:138:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.h:139:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.h:145:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12602:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12723:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12742:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12761:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12854:6: warning: function declaration isn't a prototype [-Wstrict-prototypes] The prototypes should be int ps7_init(void); int ps7_post_config(void); int ps7_debug(void); rather than int ps7_init(); int ps7_post_config(); int ps7_debug(); We do not want to be bothered because of automatically generated files. But we cannot touch the external projects for now. What we can do is to disable -Wstrict-prototypes for ps7_init.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-14zynq: treat ps7_init.c/h as external files to ignore themMasahiro Yamada
ps7_init.c and ps7_init.h are supposed to be exported by hw project and copied to board/xilinx/zynq/ directory. We want them to be ignored by git. So what we should do is to always treat them as external files rather than replacing ps7_init.c This commit does: - Move a weak function ps7_init() to arch/arm/cpu/armv7/zynq/spl.c and delete board/xilinx/zynq/ps7_init.c - Compile board/xilinx/zynq/ps7_init.c only when it exists - Add .gitignore to ignore ps7_init.c/h Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-14zynq: add empty xil_io.h to avoid compile errorMasahiro Yamada
ps7_init.c exported by hw project has #include "xil_io.h" line but U-Boot does not have "xil_io.h". So we get an error on SPL build: ps7_init.c:12581:20: fatal error: xil_io.h: No such file or directory We can delete the include directive in ps7_init.c to avoid this error. But it is painful to do this every time we export ps7_init.c file. Instead, we can put an empty xil_io.h in the same directory so we can directly copy ps7_init.c as is. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-14ARM: zynq: Fix building SPL without FPGA supportMichal Simek
When CONFIG_FPGA is defined but CONFIG_SPL_FPGA is not, the build fails: board.c: In function 'board_init': board.c:41:3: error: 'fpga' undeclared (first use in this function) fpga = fpga010; Fix this by expanding the "#if.." around this block to match the other FPGA checks and don't compile this block when buildign for SPL without FPGA support. Tested a bootloader that had CONFIG_FPGA defined without CONFIG_SPL_FPGA, this now compiles without errors and loading FPGA from u-boot works. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-14ARM: zynq: Remove sparse warningsMichal Simek
Warnings: board/xilinx/zynq/board.c:17:13: warning: symbol 'fpga' was not declared. Should it be static? board/xilinx/zynq/board.c:20:13: warning: symbol 'fpga010' was not declared. Should it be static? board/xilinx/zynq/board.c:21:13: warning: symbol 'fpga015' was not declared. Should it be static? board/xilinx/zynq/board.c:22:13: warning: symbol 'fpga020' was not declared. Should it be static? board/xilinx/zynq/board.c:23:13: warning: symbol 'fpga030' was not declared. Should it be static? board/xilinx/zynq/board.c:24:13: warning: symbol 'fpga045' was not declared. Should it be static? board/xilinx/zynq/board.c:25:13: warning: symbol 'fpga100' was not declared. Should it be static? board/xilinx/zynq/board.c:120:5: warning: symbol 'board_mmc_init' was not declared. Should it be static? Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Avoid CamelCase for in Xilinx_descMichal Simek
No functional changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-03-12kbuild: rename SRCTREE to srctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used for instead. This commit renames SRCTREE to srctree and deletes the defition of SRCTREE. Note that SRCTREE in scripts/kernel-doc, scripts/docproc.c, doc/DocBook/Makefile should be keep. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07xilinx: delete meaningless .gitignore filesMasahiro Yamada
config.tmp is never generated Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-03-04zynq: Add OF ram initialization supportMichal Simek
Read ram size directly from DTB. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-20Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: Makefile drivers/net/npe/Makefile These two conflicts arise from commit 0b2d3f20 ("ARM: NET: Remove the IXP NPE ethernet driver") and are resolved by deleting the drivers/net/npe/Makefile file and removing the CONFIG_IXP4XX_NPE line from Makefile.
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19zynq: Add support for U-BOOT SPLMichal Simek
SPL is using ps7_init.c/h files which are generated from design tools which have to be copied to boards/xilinx/zynq folder before compilation. BSS section is moved to SDRAM because fat support requires more space than SRAM size. Added: - MMC and QSPI support - Boot OS directly from SPL - Enable SPL command Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-02-19zynq: Move bootmode to headersMichal Simek
These numbers will be reused by SPL. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: Use board_eth_init if CMD_NET is not enabledMichal Simek
board_eth_init can be also called in cases where CMD_NET is not enabled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: Do not explicitely enable icacheMichal Simek
icache is already enabled by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-06fpga: zynqpl: Add support for zc7015 deviceMichal Simek
Just extend tables with this new device. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-01-10dts: zynq: Add more zynq dts filesJagannadha Sutradharudu Teki
This patch adds initial dts support for supported zynq boards. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10dts: zynq: Add basic fdt supportJagannadha Sutradharudu Teki
This patch provides a basic fdt support for zynq u-boot. zynq-7000.dtsi-> initial arch dts file zynq-zed.dts -> initial zed board dts file more devices should be added in subsequent patches. u-boot build: once configuring of a board done for building dtb with zynq-zed.dts as an input zynq-uboot> make DEVICE_TREE=zynq-zed Enabled CONFIG_OF_SEPARATE for building dtb separately. There is a new binary called u-boot-dtb.bin which is a u-boot with devicetree supported. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add support to find bootmodeJagannadha Sutradharudu Teki
Added support to find the bootmodes by reading slcr bootmode register. this can be helpful to autoboot the configurations w.r.t a specified bootmode. Added this functionality on board_late_init as it's not needed for normal initializtion part. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-11-01Makefile: convert makefiles to Kbuild style and delete grep switchMasahiro Yamada
We have converted all makefiles needed to build $(LIBS). Until this commit we used to grep switch so that U-Boot style and Kbuild style makefiles coexist. But we do not need any more. Goint forward, use always Kbuild style Makefile when adding a new Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-31microblaze: convert makefiles to Kbuild styleMasahiro Yamada
2013-09-03Merge 'u-boot-microblaze/zynq' into (u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/include/asm/arch-zynq/hardware.h The conflict above was trivial and solved during merge.
2013-08-12zynq: Enable axi ethernet and emaclite driver initializationMichal Simek
Zynq can have axi ethernet and emaclite IPs in programmable logic. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-08-12zynq: Add new ddrc driver for ECC supportMichal Simek
The first 1MB is not initialized by first stage bootloader. Check if memory is setup to 16bit mode and ECC is enabled. If it is, clear the first 1MB. Also u-boot should report only the half size of memory. Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-08-12fpga: zynqpl: Add support for zc7100 device.Michal Simek
- Add support for zc7100 device. - FPGA programming on few of the SOC(zc7100) takes more than 1sec, hence increased the program time by 4sec to sync' all soc's. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-08-02xilinx: move microblaze-generic .dts to standard locationStephen Warren
Aside from microblaze, all other SoCs/boards/vendors store their DT files in board/$vendor/dts/$soc-$board.dts. Move microblaze-generic.dts to this location for consistency. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Michal Simek <monstr@monstr.eu>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-11Merge branch 'u-boot-pxa/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-05-09gpio: Add support for microblaze xilinx GPIOMichal Simek
Microblaze uses gpio which is connected to the system reset. Currently gpio subsystem wasn't used for it. Add gpio driver and change Microblaze reset logic to be done via gpio subsystem. There are various configurations which Microblaze can have that's why gpio_alloc/gpio_alloc_dual(for dual channel) function has been introduced and gpio can be allocated dynamically. Adding several gpios IP is also possible and supported. For listing gpio configuration please use "gpio status" command This patch also remove one compilation warning: microblaze-generic.c: In function 'do_reset': microblaze-generic.c:38:47: warning: operation on '*1073741824u' may be undefined [-Wsequence-point] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-06fpga: zynq: Add support for loading bitstreamMichal Simek
Devcfg device requires to load bitstream in binary format. But u-boot also has an option for loading bitstream in bit format. Let's handle both cases by zynqpl driver. Also add suport for loading partial bitstreams. The first driver version was done by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30mmc: Add support for Xilinx Zynq sdhci controllerMichal Simek
Add support for SD, MMC and eMMC card on Xilinx Zynq. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30net: gem: Preserve clk on emio interfaceDavid Andrey
Avoid overwriting GEMx_RCLK_CTRL and GEMx_CLK_CTRL if the Ethernet interface is connect on EMIO Do not enable emio for this standard board configuration for now. Signed-off-by: David Andrey <david.andrey@netmodule.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30net: gem: Pass phy address to initDavid Andrey
Pass the PHY address to the driver init to allow parallel use of both interfaces Signed-off-by: David Andrey <david.andrey@netmodule.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30zynq: Move macros to hardware.hMichal Simek
Add all fixed addresses to hardware.h and change petalinux configuration to support this. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30watchdog: Add support for Xilinx Microblaze watchdogMichal Simek
Watchdog can be used on Microblaze, PPC and Zynq hw designs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30microblaze: Disable all cpu features before resetMichal Simek
Fix microblaze soft reset function and disable all cpu features. Especially disable caches because IRQs were off by disable_interrupts(). Reported-by: John Williams <john.williams@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-04-30microblaze: Fix reset functionMichal Simek
Remove CONFIG_SYS_RESET_ADDRESS macro. It was there from historical point of view when soft reset was just jump to u-boot text start (not used right now). Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-04microblaze: Remove FSL support from generic boardMichal Simek
This code was targetting one specific Microblaze platform configuration which is obsolete and fsl bus isn't used in this way. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-04board: xilinx: Remove common folderMichal Simek
All these files was used for ancient xilinx drivers which are finally gone. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Rommel Custodio <sessyargc@gmail.com>
2013-02-04board: xilinx: Remove unused ancient i2c driverMichal Simek
There is new driver in the driver folder. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Rommel Custodio <sessyargc@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2012-10-04xilinx: Add new Zynq boardMichal Simek
Add support for Xilinx Zynq board. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> CC: Joe Hershberger <joe.hershberger@gmail.com>
