Most armv8 systems have PSCI support enabled in EL3, either through
ARM Trusted Firmware or other firmware.
On these systems, we do not need to implement system reset manually,
but can instead rely on higher level firmware to deal with it.
The exclude list seems excessive right now, but NXP is working on
providing an in-tree PSCI implementation, so that all NXP systems
can eventually use PSCI as well.
[agraf: fix meson]
All systems that are running on armv8 are running bare metal with firmware
that implements PSCI running in EL3. That means we don't really need to expose
the hypercall variants of them.
This patch leaves the code in, but makes the code explicit enough to have the
compiler optimize it out. With this we don't need to worry about hvc vs smc
calling convention when calling psci helper functions.
Chip ID needs to be known for loading bitstream because
U-Boot checks ID from bitstream header in BIT format.
BIN format is completely unchecked.
The chipid is get from ATF via SMC.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
SPL needs to have bigger stack size because of USB.
Simple malloc needs to be disabled because dfu code requires different
allocation functions. There is no space in OCM that's why random place
in DDR is used.
BOOTD must be disabled because it is causing compilation error.
All variables are disabled and used only variables valid for DFU because
they are simple huge. Including automatic variables added by
CONFIG_ENV_VARS_UBOOT_CONFIG.
Hardcode addresses for u-boot, atf, kernel and dtb
just for SPL DFU code.
Enable SPL DFU for zcu100.
Create new usb_dfu_spl variable just to run Linux kernel loaded in SPL.
Function is defined in g_dnl.h and have different parameter
then it is used. This patch fixes it.
The second USB wasn't enabled. This patch fixes it.
Using PSCI to reset the system.
Nand and QSPI are not defined now but this will be extended.
Based on selected bootmode boot_targets are rewritten.
Patch also contains detection if variables are saved. If yes don't
rewrite boot_targets variable.
Also move variable setup to the end of file because SCSI needs to be
defined before others macros are using it.
Reviewed-by: Alexander Graf <agraf@suse.de>
Support RAM and MMC boot mode in SPL also with SPL_FIT images.
In MMC boot mode two boot options are available:
1) Boot flow with ATF(EL3) and full U-Boot(EL2):
aarch64-linux-gnu-objcopy -O binary bl31.elf bl31.bin
mkimage -A arm64 -O linux -T kernel -C none -a 0xfffe5000 -e 0xfffe5000
-d bl31.bin atf.ub
cp spl/boot.bin <sdcard fat partition>
cp atf.ub <sdcard fat partition>
cp u-boot.bin <sdcard fat partition>
2) Boot flow with full U-Boot(EL3):
cp spl/boot.bin <sdcard>
cp u-boot*.img <sdcard>
3) emmc boot mode
dd if=/dev/zero of=sd.img bs=1024 count=1024
parted sd.img mktable msdos
parted sd.img mkpart p fat32 0% 100%
kpartx -a sd.img
mkfs.vfat /dev/mapper/loop0p1
mount /dev/mapper/loop0p1 /mnt/
cp spl/boot.bin /mnt
cp u-boot.img /mnt
cp u-boot.bin /mnt
cp atf.ub /mnt
umount /dev/mapper/loop0p1
kpartx -d sd.img
cp sd.img /tftpboot/
and program it via u-boot
tftpb 10000 sd.img
mmcinfo
mmc write 10000 0 $filesize
mmc rescan
mmc part
ls mmc 0
psu_init() function contains low level SoC setup generated for every HW
design by Xilinx design tools. xil_io.h is only supporting file to fix
all dependencies from tools. The same solution was used on Xilinx Zynq.
The patch also change CONFIG_SYS_INIT_SP_ADDR to the end of OCM which
stays at the same location all the time.
Bootrom expects starting address to be at 0xfffc0000 that's why this
address is SPL_TEXT_BASE.
Add support for on board eeprom with programmed MAC for using in u-boot
to have uniq address for every board.
Most of the time uniq MAC address is on a label on the board.
If address is not programmed use these command to program it.
On zcu102:
ZynqMP> mm.b 0
00000000: 00 ? 00
00000001: a0 ? 0a
00000002: 35 ? 35
00000003: 02 ? 02
00000004: 00 ? ef
00000005: 00 ? 67
00000006: 00 ? q
i2c dev 5
i2c write 0 54 20 6
i2c md 54 20
Including netdev.h is causing compilation warning:
+ int fecmxc_register_mii_postcall(struct eth_device *dev, int
(*cb)(int));
w+In file included from ../board/xilinx/zynqmp/zynqmp.c:9:0:
w+../include/netdev.h:204:41: warning: ‘struct eth_device’ declared
inside parameter list [enabled by default]
w+../include/netdev.h:204:41: warning: its scope is only this definition
or declaration, which is probably not what you want [enabled by default]
This patch removes it.
Define u64 types to be usable on 32bit system because of 64bit address
and size cells and 32bit shifts in the code.
Initial Ceva Sata init code.
Handle all Xilinx ZynqMP boards with one fragment.
Read information about memory from DT. This patch simplify life with
synchronization between DT and board files.
dram_init() only needs maximum RAM size below 4GB that's why please sort
banks in memory node.
dram_init_banksize() copies memory setup to bi_dram[].
This will avoid reading information from DT twice.
Memory test start/end were changed to DDR location to let memtest still
compiled.
Use space instead of tab in checkboard print to aligned
it with others boards.
Reported-by: David Glessner <david.glessner@rockwellcollins.com>
Reviewed-by: Moritz Fischer <moritz.fischer@ettus.com>
Empty weak function is used instead.
When only sdhci1 IP is enabled and SD_MODE1 bootmode is selected
U-Boot using sdboot1 variable which refers to mmc dev 1.
But this device doesn't exist because only one controller is available.
This patch fix logic around sdboot mode with using sdbootdev internal
variable.
Reported-by: Chris Kohn <ckohn@xilinx.com>
Acked-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Show also EMMC bootmode if selected. There is difference compare to SD
bootmode. Use the same bootcommand till better boot command is created.
Reported-by: Sai Pavan Boddu <saipava@xilinx.com>
Showing information about bootmode is very useful to make sure
that correct bootmode is selected.
SD1 boot mode is using different bootmode values.
Add support for this mode used on DC1.
Modify the SD bootmode value to 0x3 as per latest
spec. Also add new boot mode QSPI 32 bit boot mode
Remove SECURE_IOU option which is not needed. U-Boot itself can detect
which EL level it is on and based on that use do platform setup.
It also simplify usage because one Kconfig entry is gone.
Move driver to DM
- Enable DM_ETH by default for Zynq and ZynqMP
- Remove board_eth_init code
- Change miiphy_read function to return value instead of error code
based on DM requirement
- Do not enable EMIO DT support by default
Reviewed-by: Jagan Teki <jteki@openedev.com>
Added usb dwc3 driver support for zynqmp
this also supports the DFU and LTHOR to download
the linux images on to RAM and cen be booted from
those linux images.
Define checkboard() function for zynqMP
Add one more print to make clear which EL level U-Boot runs.
Enable SATA for the ZynqMP targets.
Wire up ethernet controllers and enable MII and BOOTP options.
Define a new config "zynqmp_ep" for ZynqMP instead
of xilinx_zynqmp. This defconfig supports all emulation
platforms of ZynqMP. Also renamed TARGET_XILINX_ZYNQMP
to ARCH_ZYNQMP.
Move the zynqmp Kconfig from board to arch
as there may be different boards under same
architecture.
Add support for EMMC bootmode.
Add support for Veloce - zynqmp emulation platform.
Platform doesn't support SDHCI.
Add basic Xilinx ZynqMP arm64 support.
Serial and SD is supported.
It supports emulation platfrom ep108 and QEMU.
