path: root/board/xilinx/xilinx_enet
2009-03-20boards: get mac address from environmentMike Frysinger
The boards that get converted here to use the environment for the mac address rather than global data: debris mgcoge mgsuvd muas3001 netstal pn62 sixnet vcma9 xilinx (the ones that use xilinx_enet) Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Sangmoon Kim <dogoil@etinsys.com> CC: Heiko Schocher <hs@denx.de> CC: David Mueller <d.mueller@elsoft.ch> CC: Niklaus Giger <niklaus.giger@netstal.com> CC: Wolfgang Grandegger <wg@denx.de> CC: Dave Ellis <DGE@sixnetio.com> CC: Ricardo Ribalda <ricardo.ribalda@uam.es>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2007-04-04Minor coding style cleanup.Wolfgang Denk
2007-03-26Support for XUPV2P boardMichal Simek
Reset support BSP autoconfig support
2007-03-11[Microblaze][PATCH] part 2Michal Simek
timer support interrupt controller support flash support ethernet support cache support board information support env support booting image support adding support for Xilinx ML401
2007-02-20[PATCH 2_4] Use config.h, not xparameters.h, for xilinx targetsGrant Likely
Change the xilinx device drivers and board code to include config.h instead of xparameters.h directly. config.h always includes the correct xparameters file. This change reduces the posibility of including the wrong file when adding a new xilinx board port Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2006-03-12Remove board specific configuration includes from the common xilinxWolfgang Denk
ethernet and iic adapter code. Patch by Michael Libeskind, 12 Jul 2005
2006-01-18Fix various compiler warnings on ppc4xx builds (ELDK 4.0)Stefan Roese
Patch by Stefan Roese, 18 Jan 2006
2004-09-29* Patch by Sean Chang, 9 Aug 2004:wdenk
- Added I2C support for ML300. - Added support for ML300 to read out its environment information stored on the EEPROM. - Added support to use board specific parameters as part of U-Boot's environment information. - Updated MLD files to support configuration for new features above. * Patches by Travis Sawyer, 5 Aug 2004: - Remove incorrect bridge settings for eth group 6 - Add call to setup bridge in ppc_440x_eth_initialize - Fix ppc_440x_eth_init to reset the phy only if its the first time through, otherwise, just check the phy for the autonegotiated speed/duplex. This allows the use of netconsole - only print the speed/duplex the first time the phy is reset.
2004-02-23* Patch by Peter Ryser, 20 Feb 2004:wdenk
Add support for the Xilinx ML300 platform * Patch by Stephan Linz, 17 Feb 2004: Fix watchdog support for NIOS * Patch by Josh Fryman, 16 Feb 2004: Fix byte-swapping for cfi_flash.c for different bus widths * Patch by Jon Diekema, 14 Jeb 2004: Remove duplicate "FPGA Support" notes from the README file
