path: root/board/xilinx/versal
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-27xilinx: Move bootmode detection to separate functionMichal Simek
Create special function for reading bootmode on Versal and ZynqMP. Zynq is using specific function (without mask) already. Future patches will be calling this function from different location too. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-04-27xilinx: Move initrd_high setup to common locationMichal Simek
Moving to common location initrd_high is also setup for Zynq which hasn't done in run time code. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-04-27xilinx: Introduce board_late_init_xilinx()Michal Simek
This function should keep common shared late configurations for Xilinx SoCs. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-14board: xilinx: Add support for user configurable boot script offsetT Karthik Reddy
Currently "script_offset_f" env variable is hardcoded, this variable specifies from which offset of the flash boot.scr should be read/write. As flashes are of different sizes having a fixed offset makes it difficult to load other images into the flash which may overwrite the boot script or cannot utilize the full memory. This current fix creates a new config "CONFIG_BOOT_SCRIPT_OFFSET" which holds the offset address, overwrites the "script_offset_f" variable. Also removed existing variable with default values, as the default values are held by CONFIG_BOOT_SCRIPT_OFFSET Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm64: versal: Fix emmc boot mode boot_target issueT Karthik Reddy
Emmc boot devcie is mounted to sdhci@f1050000 controller on versal, while in emmc boot mode, boot tragets are set to mmc0. So removed mmc0 and using the dev seq number from the sdhci@f1050000 controller. Dev seq number is setup based on DT aliases that's why needs to be setup at run time. Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move get_ticks() function out of common.hSimon Glass
This function belongs in time.h so move it over and add a comment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-08arm64: versal: Move common board dtb searchIbai Erkiaga
Move the exisiting function of getting board dtb from versal to a common Xilinx folder. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08arm64: versal: Add new dfu usb distro boot commandT Karthik Reddy
This patch adds new dfu usb distro boot command to look for bootscript from dfu-util and runs it. Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com>
2019-10-08arm64: versal: Add new jtag distro boot commandSiva Durga Prasad Paladugu
This patch adds new jtag distro boot command to look for bootscript file in DDR and execute it first incase of jtag bootmode. This patch also updates scriptaddr to 512MB as there is high of script corruption incase of bigger kernel image. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08arm64: versal: Enable memory mapping via DTMichal Simek
Code reads DT and setup MMU table based on memory node. This will ensure that only DT needs to be changed. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08arm64: versal: Set initrd_high to as high as possibleSiva Durga Prasad Paladugu
This patch is setting up the initrd_high to as high as possible by leaving max stack size for u-boot so that bigger rootfs can also be loaded by u-boot for booting kernel. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08arm64: versal: fpga: Add PL bit stream load supportSiva Durga Prasad Paladugu
This patch adds PL bitstream load support for Versal platform. The PL bitstream is loaded by making an SMC to ATF which in turn communicates with platform firmware which configures and loads PL bitstream on to PL. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08arm64: versal: Define board_late_init for versalSiva Durga Prasad Paladugu
Define board_late_init which performs bootmode detection and prepares corresponding distro boot commaand sequence. Also disable it for mini platforms because simply there is no need to have it enabled. But also disable it for virtual platform because Qemu is not modelling this register space that's why travis testing would fail. This configuration should be reverted when mainline Qemu is updated. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-02-14arm64: versal: Move IOU_SWITCH_DIVISOR0 to KconfigMichal Simek
Move hardcoded IOU_SWITCH_DIVISOR0 to Kconfig to be able to set it up for different platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-02-14arm64: versal: Remove one level of indentation in board_early_init_r()Michal Simek
Simplify code indentation. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-10-16arm64: versal: Add support for new Xilinx Versal ACAPsMichal Simek
Xilinx is introducing Versal, an adaptive compute acceleration platform (ACAP), built on 7nm FinFET process technology. Versal ACAPs combine Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent Engines with leading-edge memory and interfacing technologies to deliver powerful heterogeneous acceleration for any application. The Versal AI Core series has five devices, offering 128 to 400 AI Engines. The series includes dual-core Arm Cortex™-A72 application processors, dual-core Arm Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more than 1,900 DSP engines optimized for high-precision floating point with low latency. The patch is adding necessary infrastructure in place without enabling platform which is done in separate patch. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
