path: root/board/xilinx/microblaze-generic
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-08microblaze: Remove additional headersMichal Simek
There were several changes in past in this file without removing headers (watchdog cleanup, soft reset, etc). That's why remove additional useless headers. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08microblaze: Setup initrd_high and fdt_high at run timeMichal Simek
Setup initrd_high and fdt_high to be placed in lowmem space for kernel to be able to reach it. Values are setup at run time to ensure that the same setting can be used on different memory setup. Do this setting only when variables are not Similar run time detection was done for Zynqmp and Versal. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08microblaze: Remove unused variable ram_baseMichal Simek
This variable is completely unused that's why remove it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-04-26watchdog: Implement generic watchdog_reset() versionStefan Roese
This patch tries to implement a generic watchdog_reset() function that can be used by all boards that want to service the watchdog device in U-Boot. This watchdog servicing is enabled via CONFIG_WATCHDOG. Without this approach, new boards or platforms needed to implement a board specific version of this functionality, mostly copy'ing the same code over and over again into their board or platforms code base. With this new generic function, the scattered other functions are now removed to be replaced by the generic one. The new version also enables the configuration of the watchdog timeout via the DT "timeout-sec" property (if enabled via CONFIG_OF_CONTROL). This patch also adds a new flag to the GD flags, to flag that the watchdog is ready to use and adds the pointer to the watchdog device to the GD. This enables us to remove the global "watchdog_dev" variable, which was prone to cause problems because of its potentially very early use in watchdog_reset(), even before the BSS is cleared. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: "Marek Behún" <marek.behun@nic.cz> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Maxim Sloyko <maxims@google.com> Cc: Erik van Luijk <evanluijk@interact.nl> Cc: Ryder Lee <ryder.lee@mediatek.com> Cc: Weijie Gao <weijie.gao@mediatek.com> Cc: Simon Glass <sjg@chromium.org> Cc: "Álvaro Fernández Rojas" <noltari@gmail.com> Cc: Philippe Reynes <philippe.reynes@softathome.com> Cc: Christophe Leroy <christophe.leroy@c-s.fr> Reviewed-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Michal Simek <michal.simek@xilinx.com> (on zcu100)
2019-04-08watchdog: Move watchdog_dev to data section (BSS may not be cleared)Stefan Roese
This patch moves all instances of static "watchdog_dev" declarations to the "data" section. This may be needed, as the BSS may not be cleared in the early U-Boot phase, where watchdog_reset() is already beeing called. This may result in incorrect pointer access, as the check to "!watchdog_dev" in watchdog_reset() may not be true and the function may continue to run. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: "Marek Behún" <marek.behun@nic.cz> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-by: Michal Simek <michal.simek@xilinx.com> (on zcu100) Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2018-11-26microblaze: Use standard functions for memory decodingMichal Simek
The standard function is less error prone than custom one. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-08-06microblaze: Add missing quotes around XILINX_MICROBLAZE0_HW_VERMichal Simek
This issue is reported by kconfiglib: warning: style: quotes recommended around default value for string symbol XILINX_MICROBLAZE0_HW_VER (defined at board/xilinx/microblaze-generic/Kconfig:37) Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19microblaze: Convert generic platform to DM gpioMichal Simek
Converting GPIO to DM requires to do changes in reset subsystem that's why support for Microblaze soft reset via sysreset and GPIO sysreset support was added. These two patches enables enabling GPIO DM. Microblaze soft reset is bind at last reset method. GPIO reset is handled via sysreset with adding this fragment to DT. gpio-restart { compatible = "gpio-restart"; gpios = <&reset_gpio 0 0 0>; /* 3rd cell ACTIVE_HIGH = 0, ACTIVE_LOW = 1 */ }; hard-reset-gpio property is not documented and also handled. Conversion is required. Unfortunately do_reset is required for SPL that's why use only soft microblaze reset for now. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19microblaze: Support for watchdog_reset in initShreenidhi Shedi
We should support watchdog reset so that WATCHDOG_RESET will function properly. Signed-off-by: Shreenidhi Shedi <yesshedi@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19microblaze: Delete Xilinx watchdog related macrosShreenidhi Shedi
These macros are not required anymore. These will be taken from configuration file. Signed-off-by: Shreenidhi Shedi <yesshedi@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19microblaze: Cosmetic changes in Microblaze related filesShreenidhi Shedi
2018-07-19microblaze: Remove unused XILINX_BOARD_NAME macroMichal Simek
This macro is not used anywhere that's why remove it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19microblaze: Guard do_reset by CONFIG_SYSRESETMichal Simek
sysreset uclass have own do_reset function which should be used instead of board/platform specific. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-04-05board_f: Drop setup_dram_config() wrapperSimon Glass
By making dram_init_banksize() return an error code we can drop the wrapper. Adjust this and clean up all implementations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-01-10microblaze: Make the board configuration name user definableSai Pavan Boddu
Add a prompt for editing in menuconfig Signed-off-by: Sai Pavan Boddu <saipava@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Move MSR instruction selection to KconfigMichal Simek
Select MSR instructions via Kconfig instead of xparameters.h. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Add option to pass cpu version numberMichal Simek
Toolchain can use some flags by default based on cpu version. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Select compilation flags via KconfigMichal Simek
Remove autogenerated config.mk and select CPU options via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04microblaze: Remove !OF_CONTROL code for timer and interruptMichal Simek
OF_CONTROL is enabled by default that's why this is dead code. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Fix board_init calling sequenceMichal Simek
board_init() is in final elf file but it is not called at all. Use board_init_late() instead and call gpio_init() from it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Read information about RAM from DTMichal Simek
Do not setup ram start/size in board file. Read it from DT instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Remove systemace from board fileMichal Simek
Systemace is ancient IP which is not tested. Remove it from default configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: emaclite: Move emaclite to KconfigMichal Simek
Add PHYLIB and MII dependencies and enable it by default for Microblaze. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: emaclite: Move driver to DMMichal Simek
Move driver to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Move driver to DMMichal Simek
2016-01-27microblaze: Remove unused I2C macrosMichal Simek
There is no i2c driver in the current u-boot. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27serial: uartlite: Add uartlite to KconfigMichal Simek
- Move config option out of board file. - Remove uartlite address from config file Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-20microblaze: move CONFIG_SYS_TEXT_BASE to defconfigMasahiro Yamada
This is how CONFIG options are defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18microblaze: Do not handle watchdog and gpio in SPLMichal Simek
watchdog and gpio are not validated for SPL that's why do not use them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18microblaze: Remove support for LL_TEMACMichal Simek
LL_TEMAC is available at big endian MB and it is not properly tested that's why the patch removes it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-04-29microblaze: Fix EMAC Lite initializationNathan Rossi
It is possible for CONFIG_XILINX_EMACLITE to be defined without XILINX_EMACLITE_BASEADDR being defined as the EMAC Lite driver support OF init. Check that the driver is enabled and the base address is available before initializing with a static base address. Signed-off-by: Nathan Rossi <nathan.rossi@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-02-09microblaze: Move architecture to use generic board initMichal Simek
Compile code with -fPIC to get GOT. Do not build SPL with fPIC because it increasing SPL size for nothing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-10-31microblaze: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com>
2013-08-02xilinx: move microblaze-generic .dts to standard locationStephen Warren
Aside from microblaze, all other SoCs/boards/vendors store their DT files in board/$vendor/dts/$soc-$board.dts. Move microblaze-generic.dts to this location for consistency. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Michal Simek <monstr@monstr.eu>
2013-05-09gpio: Add support for microblaze xilinx GPIOMichal Simek
Microblaze uses gpio which is connected to the system reset. Currently gpio subsystem wasn't used for it. Add gpio driver and change Microblaze reset logic to be done via gpio subsystem. There are various configurations which Microblaze can have that's why gpio_alloc/gpio_alloc_dual(for dual channel) function has been introduced and gpio can be allocated dynamically. Adding several gpios IP is also possible and supported. For listing gpio configuration please use "gpio status" command This patch also remove one compilation warning: microblaze-generic.c: In function 'do_reset': microblaze-generic.c:38:47: warning: operation on '*1073741824u' may be undefined [-Wsequence-point] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-04-30watchdog: Add support for Xilinx Microblaze watchdogMichal Simek
Watchdog can be used on Microblaze, PPC and Zynq hw designs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30microblaze: Disable all cpu features before resetMichal Simek
Fix microblaze soft reset function and disable all cpu features. Especially disable caches because IRQs were off by disable_interrupts(). Reported-by: John Williams <john.williams@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-04-30microblaze: Fix reset functionMichal Simek
Remove CONFIG_SYS_RESET_ADDRESS macro. It was there from historical point of view when soft reset was just jump to u-boot text start (not used right now). Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-04microblaze: Remove FSL support from generic boardMichal Simek
This code was targetting one specific Microblaze platform configuration which is obsolete and fsl bus isn't used in this way. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2012-09-11microblaze: Clean microblaze initializationMichal Simek
Move board specific function to board_init function in board/ folder Remove externs from generic board.c Use board_init_f function in board.c file. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net>
