path: root/board/xes
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-07-11powerpc/mpc85xx: Display a warning for unsupported DDR data ratesYork Sun
If DDR initialziation uses a speed table and the speed is not matched, print a warning message instead of silently ignoring. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Replace fsl_ddr_get_mem_data_rate with get_ddr_freq()Kumar Gala
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq() and every 86xx board uses get_bus_freq(). If implement get_ddr_freq() as a static inline to call get_bus_freq() we can remove fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq() directly. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc: Move cpu specific lmb reserve to arch_lmb_reserveKumar Gala
We've been utilizing board_lmb_reserve to reserve the boot page for MP systems. We can just move this into arch_lmb_reserve for 85xx & 86xx systems rather than duplicating in each board port. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-01-19Replace "FLASH" strings with "Flash" or "flash"Peter Tyser
There's no compelling reason to have the output on bootup or the "flinfo" command print "flash" in uppercase, so use the proper case where appropriate. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2011-01-14powerpc/8xxx: Rework XES boards pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in MPC8xxx XES boards and utilize the common fsl_pcie_init_board(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> CC: Peter Tyser <ptyser@xes-inc.com>
2011-01-14mpc85xx boards: initdram() cleanup/bugfixBecky Bruce
Correct initdram to use phys_size_t to represent the size of dram; instead of changing this all over the place, and correcting all the other random errors I've noticed, create a common initdram that is used by all non-corenet 85xx parts. Most of the initdram() functions were identical, with 2 common differences: 1) DDR tlbs for the fixed_sdram case were set up in initdram() on some boards, and were part of the tlb_table on others. I have changed them all over to the initdram() method - we shouldn't be accessing dram before this point so they don't need to be done sooner, and this seems cleaner. 2) Parts that require the DDR11 erratum workaround had different implementations - I have adopted the version from the Freescale errata document. It also looks like some of the versions were buggy, and, depending on timing, could have resulted in the DDR controller being disabled. This seems bad. The xpedite boards had a common/fsl_8xxx_ddr.c; with this change only the 517 board uses this so I have moved the ddr code into that board's directory in xpedite517x.c Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/8xxx: Replace is_fsl_pci_cfg with is_serdes_configuredKumar Gala
Now that we have serdes support for all 85xx/86xx/Pxxx chips we can replace the is_fsl_pci_cfg() code with the is_serdes_configured(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-14fsl: Clean up printing of PCI boot infoPeter Tyser
Previously boards used a variety of indentations, newline styles, and colon styles for the PCI information that is printed on bootup. This patch unifies the style to look like: ... NAND: 1024 MiB PCIE1: connected as Root Complex Scanning PCI bus 01 04 01 8086 1010 0200 00 04 01 8086 1010 0200 00 03 00 10b5 8112 0604 00 02 01 10b5 8518 0604 00 02 02 10b5 8518 0604 00 08 00 1957 0040 0b20 00 07 00 10b5 8518 0604 00 09 00 10b5 8112 0604 00 07 01 10b5 8518 0604 00 07 02 10b5 8518 0604 00 06 00 10b5 8518 0604 00 02 03 10b5 8518 0604 00 01 00 10b5 8518 0604 00 PCIE1: Bus 00 - 0b PCIE2: connected as Root Complex Scanning PCI bus 0d 0d 00 1957 0040 0b20 00 PCIE2: Bus 0c - 0d In: serial ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: wd@denx.de CC: sr@denx.de CC: galak@kernel.crashing.org
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-22XPedite5500 board supportJohn Schmoller
Initial support for Extreme Engineering Solutions XPedite5500 - a P2020-based PMC/XMC single board computer. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Make X-ES board names more genericPeter Tyser
Some U-Boot images for X-ES boards support multiple products in the same family. For example, the XPedite5370, XPedite5371, and XPedite5372 are similar enough that one U-Boot image can work on all 3 cards. To make it clear that a U-Boot image can work on boards of the same family, rename the boards with the least significant digit of 'x'. While we're at it, change the board config file and make targets to be lowercase. Also change the default uImage and fdt filenames to "board.uImage" and "board.dtb" to be more generic. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Add board_flash_wp_on()John Schmoller
Add board_flash_wp_on() to check a pca9557 gpio pin to see if non-volatile memory write protection is enabled. Previously, write protected NOR flashes would fail initialization which resulted in a bootup error such as: ... DTT: 53 C local / 64 C remote (adt7461@4c) DTT: 54 C local (ds1621@48) FLASH: Executed from FLASH1 POST memory PASSED FLASH: ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB ## Unknown FLASH on Bank 2 - Size = 0x00000000 = 0 MB *** failed *** ### ERROR ### Please RESET the board ### With this patch, NOR flash initialization is skipped: ... DTT: 53 C local / 64 C remote (adt7461@4c) DTT: 54 C local (ds1621@48) FLASH: Executed from FLASH1 POST memory PASSED FLASH: Uninitialized - Write Protect On L2: 1024 KB enabled NAND: 1024 MiB ... Note that flash related commands such as flinfo and saveenv will error out when flash write protection is enabled. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Consolidate checkboard()John Schmoller
Create a common checkboard() function to support all X-ES's Freescale boards. Also, add a get_board_derivative() function which reads hardware strapping resistors to determine what model a board is. This allows one U-Boot image to support multiple boards. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Use common PCI initialization codePeter Tyser
Common Freescale code for PCI initialization now exists, so migrate X-ES boards to use it. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-2086xx: Create common linker scriptKumar Gala
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-07-20powerpc/85xx & 86xx: Rework ft_fsl_pci_setup to not require aliasesKumar Gala
Previously we used an alias the pci node to determine which node to fixup or delete. Now we use the new fdt_node_offset_by_compat_reg to find the node to update. Additionally, we replace the code in each board with a single macro call that makes assumes uniform naming and reduces duplication in this area. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-24Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-04-19ppc4xx: TLB init file cleanupStefan Roese
This patch adds new macros, with frequently used combinations of the 4xx TLB access control and storage attibutes. Additionally the 4xx init.S files are updated to make use of these new macros. Resulting in easier to read TLB definitions. Additionally some init.S files are updated to use the mmu header for the TLB defines, instead of defining their own macros. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17PCIe, USB: Replace 'end point' references with 'endpoint'Peter Tyser
When referring to PCIe and USB 'endpoint' is the standard naming convention. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Remy Bohmer <linux@bohmer.net>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-27xpedite5370: Enable multi-core supportPeter Tyser
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-28xes: Use proper IO access functionsPeter Tyser
Also fix some minor whitespace oddities while we're cleaning up Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Move to a common linker scriptKumar Gala
There are really no differences between all the 85xx linker scripts so we can just move to a single common one. Board code is still able to override the common one if need be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2886xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_MPC86xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8641=1 However these are all captured in the config.h and thus redudant. Also moved common 86xx flags into cpu/mpc86xx/config.mk. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_E500=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8548=1 However these are all captured in the config.h and thus redudant. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
