path: root/board/xes
2010-07-20powerpc/85xx & 86xx: Rework ft_fsl_pci_setup to not require aliasesKumar Gala
Previously we used an alias the pci node to determine which node to fixup or delete. Now we use the new fdt_node_offset_by_compat_reg to find the node to update. Additionally, we replace the code in each board with a single macro call that makes assumes uniform naming and reduces duplication in this area. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-24Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-04-19ppc4xx: TLB init file cleanupStefan Roese
This patch adds new macros, with frequently used combinations of the 4xx TLB access control and storage attibutes. Additionally the 4xx init.S files are updated to make use of these new macros. Resulting in easier to read TLB definitions. Additionally some init.S files are updated to use the mmu header for the TLB defines, instead of defining their own macros. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17PCIe, USB: Replace 'end point' references with 'endpoint'Peter Tyser
When referring to PCIe and USB 'endpoint' is the standard naming convention. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Remy Bohmer <linux@bohmer.net>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-27xpedite5370: Enable multi-core supportPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-28xes: Use proper IO access functionsPeter Tyser
Also fix some minor whitespace oddities while we're cleaning up Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Move to a common linker scriptKumar Gala
There are really no differences between all the 85xx linker scripts so we can just move to a single common one. Board code is still able to override the common one if need be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2886xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_MPC86xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8641=1 However these are all captured in the config.h and thus redudant. Also moved common 86xx flags into cpu/mpc86xx/config.mk. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_E500=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8548=1 However these are all captured in the config.h and thus redudant. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold fsl_pci_setup_inbound_windows into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls fsl_pci_setup_inbound_windows before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold pci_setup_indirect into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls pci_setup_indirect before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-24xpedite1k: Move to X-ES vendor directoryPeter Tyser
The XPedite1000 is an X-ES product thus it can be put in board/xes along with other X-ES boards. Along with the move, the board was renamed to XPedite1000 from XPedite1K to fit X-ES's standard naming convention. Maintainership was also transfered to Peter Tyser. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-22xpedite5370: Fix I2C GPIO initialization typoPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher<hs@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-22xes: Remove 8xxx board_add_ram_info() functionPeter Tyser
This is in preparation for adding one common 8xxx board_add_ram_info() fuction for all 8xxx boards Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-0186xx: XPedite5170 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5170 - a MPC8640-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-12xes: Update Freescale clock code to work with 86xx processorsPeter Tyser
2009-06-12xes: Update Freescale DDR code to work with 86xx processorsPeter Tyser
2009-06-12xes: Update Freescale PCI code to work with 86xx processorsPeter Tyser
2009-04-04fsl_pci: Move prototypes into fsl_pci.h and remove explicit externsKumar Gala
2009-04-04fsl_pci: Renamed immap_fsl_pci.h to fsl_pci.hKumar Gala
Rename the pci header for FSL HW so we can move some prototypes in there and stop doing explicit externs Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-2985xx: Enable inbound PCI config cycles for X-ES boards cleanupPeter Tyser
2008-12-29XPedite5200 board support cleanupPeter Tyser
2008-12-19XPedite5200 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5200 - a MPC8548-based PMC single board computer. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-1985xx: Enable inbound PCI config cycles for X-ES boardsPeter Tyser
Update X-ES Freescale boards to allow inbound PCI configuration cycles when configured as agent/endpoint. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-19XPedite5370 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5370 - a MPC8572-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
