These boards have not been converted to CONFIG_DM_PCI by the deadline and is
also missing conversion to CONFIG_DM. Remove them. As this includes
the last ARCH_MPC8572 platform, remove that as well.
Cc: Peter Tyser <ptyser@xes-inc.com>
Acked-by: Peter Tyser <ptyser@xes-inc.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs.
The similar DDR controllers will be used for ARM-based SoCs.
Signed-off-by: York Sun <yorksun@freescale.com>
Some DDR related structures present in fsl_ddr_dimm_params.h, fsl_ddr_sdram.h, ddr_spd.h
has various parameters with embedded acronyms capitalized that trigger the CamelCase
warning in checkpatch.pl
Convert those variable names to smallcase naming convention and modify all files
which are using these structures with modified structures.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
[trini: Fixup common/cmd_io.c]
If DDR initialziation uses a speed table and the speed is not matched,
print a warning message instead of silently ignoring.
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards
pretty much do the same thing. The only variations are in how many
controllers or DIMMs per controller exist. To make this work we
standardize on the names of the SPD_EEPROM_ADDRESS defines based on the
use case of the board.
We allow boards to override get_spd to either do board specific fixups
to the SPD data or deal with any unique behavior of how the SPD eeproms
are wired up.
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq()
and every 86xx board uses get_bus_freq(). If implement get_ddr_freq()
as a static inline to call get_bus_freq() we can remove
fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq()
directly.
Initial support for Extreme Engineering Solutions XPedite5500 -
a P2020-based PMC/XMC single board computer.
Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
