path: root/board/xes/xpedite550x/ddr.c
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-10-16powerpc: Fix CamelCase warnings in DDR related codePriyanka Jain
Some DDR related structures present in fsl_ddr_dimm_params.h, fsl_ddr_sdram.h, ddr_spd.h has various parameters with embedded acronyms capitalized that trigger the CamelCase warning in checkpatch.pl Convert those variable names to smallcase naming convention and modify all files which are using these structures with modified structures. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2011-07-11powerpc/mpc85xx: Display a warning for unsupported DDR data ratesYork Sun
If DDR initialziation uses a speed table and the speed is not matched, print a warning message instead of silently ignoring. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Replace fsl_ddr_get_mem_data_rate with get_ddr_freq()Kumar Gala
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq() and every 86xx board uses get_bus_freq(). If implement get_ddr_freq() as a static inline to call get_bus_freq() we can remove fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq() directly. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-22XPedite5500 board supportJohn Schmoller
Initial support for Extreme Engineering Solutions XPedite5500 - a P2020-based PMC/XMC single board computer. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
