path: root/board/xaeniax
2011-12-06PXA: Rename pxa_dram_init to pxa2xx_dram_initMarek Vasut
2011-12-06PXA: Squash extern pxa_dram_init()Marek Vasut
2011-11-23board/xaeniax/flash.c: Fix GCC 4.6 warningsAnatolij Gustschin
Fix: flash.c: In function 'flash_erase': flash.c:223:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] flash.c: In function 'write_data': flash.c:392:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-07-16Timer: Fix misuse of ARM *timer_masked() functions outside arch/armGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-10-22PXA: xaeniax: Fix for relocMarek Vasut
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-09-28Patch by Vincent Dubey, 24 Sep 2004:wdenk
Add support for xaeniax board
