path: root/board/xaeniax/flash.c
2011-11-23board/xaeniax/flash.c: Fix GCC 4.6 warningsAnatolij Gustschin
Fix: flash.c: In function 'flash_erase': flash.c:223:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] flash.c: In function 'write_data': flash.c:392:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-07-16Timer: Fix misuse of ARM *timer_masked() functions outside arch/armGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2004-09-28Patch by Vincent Dubey, 24 Sep 2004:wdenk
Add support for xaeniax board
