path: root/board/work-microwave/work_92105/Makefile
2016-03-16lpc32xx: work_92105: Rework MakefileTom Rini
When we switch to including all linker lists in SPL it is important to not include commands as that may lead to link errors due to other things we have already discarded. In this case change things so that we only build the right objects for SPL or non-SPL Cc: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-04-10lpc32xx: add support for board work_92105Albert ARIBAUD \(3ADEV\)
Work_92105 from Work Microwave is an LPC3250- based board with the following features: - 64MB or 128MB SDR DRAM - 1 GB SLC NAND, managed through MLC controller. - Ethernet - Ethernet + PHY SMSC8710 - I2C: - EEPROM (24M01-compatible) - RTC (DS1374-compatible) - Temperature sensor (DS620) - DACs (2 x MAX518) - SPI (through SSP interface) - Port expander MAX6957 - LCD display (HD44780-compatible), controlled through the port expander and DACs This board has SPL support, and uses the LPC32XX boot image format. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
