Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
The '#' used as comments in the files cause the preprocessor
trouble, so change to /* */.
The mkimage command which uses this preprocessor output
was moved to arch/arm/imx-common/Makefile
.gitignore was updated to ignore .cfgtmp files.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Set Write Protection GPIO as input.
Set the gpio value in gpio_direction_output() instead of an extra gpio_set_value
call.
drivers/power/power_fsl.c
include/configs/mx35pdk.h
include/configs/mx53loco.h
include/configs/woodburn_common.h
board/woodburn/woodburn.c
These boards still use the old old PMIC framework, so they
do not merge properly after the power framework was merged into
mainline.
Fix all conflicts and update woodburn to use Power Framework.
The woodburn board is based on the MX35 SOC.
Support for both external (NOR) and internal
(SD Card) boot mode are added. It uses the
generic SPL framework to implement the internal boot
mode.
The following peripherals are supported:
- Ethernet (FEC)
- SD Card
- NAND (512 MB)
- NOR Flash
In the internal boot mode, a simple imximage header
is generated to set the address in internal RAM
where the SOC must copy the SPL code. The initial setup
is then demanded to the SPL itself.
