path: root/board/woodburn/woodburn.c
2015-01-20imx: woodburn: Remove reference to gdataSimon Glass
The global_data pointer (gd) has already been set before board_init_f() is called. We should not assign it again. We should also not use gdata since it is going away. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stefano Babic <sbabic@denx.de>
2013-05-05imx: woodburn: Convert to iomux-v3Benoît Thébaudeau
There is no change of behavior. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-01-21woodburn: Set Write Protection GPIO as inputFabio Estevam
Set Write Protection GPIO as input. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-11woodburn: Set gpio value in gpio_direction_output()Fabio Estevam
Set the gpio value in gpio_direction_output() instead of an extra gpio_set_value call. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-12-08Merge branch 'master' of git://git.denx.de/u-boot into masterStefano Babic
Conflicts: drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/woodburn_common.h board/woodburn/woodburn.c These boards still use the old old PMIC framework, so they do not merge properly after the power framework was merged into mainline. Fix all conflicts and update woodburn to use Power Framework. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-26MX35: add support for woodburn boardStefano Babic
The woodburn board is based on the MX35 SOC. Support for both external (NOR) and internal (SD Card) boot mode are added. It uses the generic SPL framework to implement the internal boot mode. The following peripherals are supported: - Ethernet (FEC) - SD Card - NAND (512 MB) - NOR Flash In the internal boot mode, a simple imximage header is generated to set the address in internal RAM where the SOC must copy the SPL code. The initial setup is then demanded to the SPL itself. Signed-off-by: Stefano Babic <sbabic@denx.de>
