path: root/board/westel
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2002-08-26Initial revisionwdenk
2001-09-06Initial revisionwdenk
