path: root/board/wandboard
2019-07-04wandboard: README: Adjust the U-Boot proper binary nameFabio Estevam
After the conversion to DM the U-Boot proper binary name is 'u-boot-dtb.img', so adjust it accordingly. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04wandboard: Add FIT image supportFabio Estevam
After the transition to DM, only the mx6dl/solo wandboard is supported. Add FIT image support so that all the wandboard variants can be supported, like it was prior to the DM conversion. Successfully booted Linux on mx6q/solo/qp wandboards. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-06-11wandboard: Rework Makefile to prevent spl.o from being builtEzequiel Garcia
The spl.c source was entirely conditioned by CONFIG_SPL_BUILD. Change this moving CONFIG_SPL_BUILD to be used in the Makefile, which is slightly cleaner and more readable. Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com>
2019-05-17wandboard: Don't use I2C speed Kconfig settings with DM_I2CTrent Piepho
When using DM_I2C the speed value supplied to setup_i2c() is not used, so this code required CONFIG_SYS_MXC_I2C[12]_SPEED to be defined to compile, but did not actually use them. Change this so we no longer need to define an unused macro to compile in DM_I2C mode. Also make it more clear that they do not control the bus speed. Otherwise it is quite easy to mistakenly believe they are used to set the bus speed. Cc: Heiko Schocher <hs@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Trent Piepho <tpiepho@impinj.com>
2019-04-13imx6: wandboard: convert to DM_MMCAnatolij Gustschin
Move SDHC init to SPL code since it is not required with DM_MMC. Enable DM_MMC support. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2019-04-13imx6: wandboard: convert to DM_I2CAnatolij Gustschin
Allow building with DM_I2C enabled. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2019-04-13imx6: wandboard: convert to DM_PMICAnatolij Gustschin
Enable DM_PMIC_PFUZE100 driver and add PMIC description to DTS. Rework power_init_board() code. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2019-04-13imx6: wandboard: convert to DM_GPIO and enable pinctrl driverAnatolij Gustschin
Enable DM_GPIO and pinctrl in defconfig and add gpio_request() calls where required. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2019-04-13imx6: wandboard: add device treeAnatolij Gustschin
Add device trees from Linux in preparation for driver model conversions. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2018-09-14wandboard: README: Include the mx6qp variant in the listFabio Estevam
The mx6qp Wandboard variant is also supported, so add it to the list. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-29wandboard: remove superfluous includeHeinrich Schuchardt
No definition provided by input.h is used in the board file. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-11-20Revert "wandboard: Remove unnecessary delay"Fabio Estevam
This reverts commit b8b9790e23a7d6eec08d66192853ecb61bcae095. Some wandboard variants no longer boot after this commit, so keep the original delay to avoid the boot regression. Reported-by: Varga Zsolt <vazso@vazso.hu> Tested-by: Varga Zsolt <vazso@vazso.hu> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-31wandboard: Remove cpu type check prior to setup_sata()Fabio Estevam
Inside setup_sata() there is a cpu type check, so there is no need to do this check in the board file. This also brings the benefit to allowing setup_sata() to be called for the mx6qp wandboard variant. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-10-31wandboard: Add support for the MX6QP variantFabio Estevam
Add support for the latest MX6QP wandboard variant. Based on Richard Hu's work from Technexion's U-Boot tree. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-12wandboard: Add support for the latest revd1 revisionFabio Estevam
Latest wandboard hardware revision is revd1, which brings the following new features: - PFUZE100 PMIC - AR8035 Ethernet PHY - Upgrade Wifi/BT chip to BCM4339/BCM43430. The detection mechanism is to probe the PMIC and when it is found, then the revision of the board is revd1. As the detection is done via PMIC, we need to print the board version at a later stage via CONFIG_DISPLAY_BOARDINFO_LATE and also need to disable CONFIG_DISPLAY_BOARDINFO, which is done much earlier. Make the necessary adjustments for the AR8035 PHY to work on revd1. Based on Richard Hu's work from Technexion's U-Boot tree. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-12wandboard: Avoid calling setup_display() from SPL codeFabio Estevam
There is no need call setup_display() from SPL code, so move it to board_init(), which executes only in U-Boot proper. Reported-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2017-09-18imx6: drop duplicated bss memset and board_init_r() callAnatolij Gustschin
bss section is cleared in crt0.S. board_init_r() is also entered from crt0 code. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <lukma@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-08-28imx: imx6: Move gpr_init() function to soc.cBreno Lima
Since the gpr_init() function is common for boards using MX6S, MX6DL, MX6D, MX6Q and MX6QP processors move it to the soc.c file. Signed-off-by: Breno Lima <breno.lima@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-12wandboard: Remove unnecessary delayFabio Estevam
There is no need to add a 100us delay after the DDR initialization. Other imx6 boards do not have such delay either, so simply remove it. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-11-29arm: imx: wandboard: fix compile error if CONFIG_VIDEO is deactivatedSven Ebenfeld
When I tried to deactivate VIDEO support for the Wandboard, it still tried to initialize the Framebuffer and so on. That is the reason for the added ifdefs. CONFIG_VIDEO is enabled in the configuration as default and therefore nothing changes for the default user. The structs mx6dl_i2c2_pad_info and mx6q_i2c2_pad_info are only available when CONFIG_IPUV3 are set and should not be tried to access, when that define is not defined. Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com>
2016-11-06wandboard: Make Ethernet functional againFabio Estevam
Since commit ce412b79e7255770 ("drivers: net: phy: atheros: add separate config for AR8031") ethernet does not work on mx6sabresd. This commit correctly assigns ar8031_config() as the configuration function for AR8031 in the same way as done in the Linux kernel. However, on wandboard design we need some additional configuration, such as enabling the 125 MHz AR8031 output that needs to be done in the board file. This also aligns with the same method that the kernel performs the AR8031 fixup in arch/arm/mach-imx/mach-imx6q.c. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-10-04wandboard: Fix hang when going into low frequencyFabio Estevam
A kernel hang is observed when running wandboard 3.14 kernel and going to the lowest operational point of cpufreq: # ifconfig eth0 down # echo 1 > /sys/class/graphics/fb0/blank The problem is caused by incorrect setting of the REFR field of register MDREF. Setting it to 4 refresh commands per refresh cycle fixes the hang. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06mx6: ddr: Allow changing REFSEL and REFR fieldsFabio Estevam
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and REFR fields of the MDREF register as 1 and 7, respectively for DDR3 and 0 and 3 for LPDDR2. Looking at the MDREF initialization done via DCD we see that boards do need to initialize these fields differently: $ git grep 0x021b0020 board/ board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800 board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800 board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800 So introduce a mechanism for users to be able to configure REFSEL and REFR fields as needed. Keep all the mx6 SPL users in their current REF_SEL and REFR values, so no functional changes for the existing users. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-07-28wandboard: Replace is_cpu_type() for macroBreno Lima
It's not necessary to use the is_cpu_type function, there is a macro in sys_proto.h already implemented. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-28mx6: wandboard: fix warning due to missing prototypeStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-12wandboard: enable SATA with imx6qGilles Chanteperdrix
Signed-off-by: Gilles Chanteperdrix <gilles.chanteperdrix@xenomai.org>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-11MAINTAINERS/mailmap: Update my email addressFabio Estevam
Update my email address to the NXP account. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-01-07wandboard: Simplify the Ethernet PHY configurationFabio Estevam
As per the AR8031 datasheet: "For a reliable power on reset, suggest to keep asserting the reset low long enough (10ms) to ensure the clock is stable and clock-to-reset 1ms requirement is satisfied." So do as suggested and also add a 100us delay after deasserting the reset line to guarantee that the PHY ID can be read correctly and the Atheros 8031 PHY driver can be loaded automatically. This results in a simpler code. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric Bénard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-06-08wandboard: Add board revision detection supportFabio Estevam
There are two revisions of wandboard: version B1 and C1. Add the revision detection support, so that the correct dtb file can be automatically loaded. Based on the patch from Richard Hu <hakahu@gmail.com>. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
2015-05-21wandboard: Switch to SPL supportFabio Estevam
Currently we need to build one U-boot image for each of the wandboard variants: quad, dual-lite and solo. By switching to SPL we can support all these variants with a single binary, which is very convenient. Based on the work from Richard Hu. Tested kernel booting on the three boards. Signed-off-by: Richard Hu <hakahu@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Stefano Babic <sbabic@denx.de>
2014-11-20wandboard: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-09wandboard: add Future Eletronics 7" WVGA LCD extension boardOtavio Salvador
This adds support for the 7" WVGA produced by Future Eletronics and make it dynamically detect if it is connected or not based on the touchscreen controller. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2014-03-13Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-03-05wandboard: Include <input.h>Fabio Estevam
Include <input.h> in order to fix the following sparse warning: wandboard.c:278:5: warning: symbol 'overwrite_console' was not declared. Should it be static? Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-03-05wandboard: Fix sparse warningFabio Estevam
Add a prototype for board_phy_config() to fix the following sparse warning: wandboard.c:200:5: warning: symbol 'board_phy_config' was not declared. Should it be static? Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-03-05wandboard: Staticize usdhc1_padsFabio Estevam
Fix the following sparse warning: wandboard.c:58:22: warning: symbol 'usdhc1_pads' was not declared. Should it be static? Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2014-01-13wandboard: Return from cpu_eth_init() directlyFabio Estevam
There is no need to print an error message when cpu_eth_init() fails because net/eth.c already prints it. In order to simplify the code, just return the value from cpu_eth_init(bis) directly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
