path: root/board/wandboard
2014-01-13wandboard: Return from cpu_eth_init() directlyFabio Estevam
There is no need to print an error message when cpu_eth_init() fails because net/eth.c already prints it. In order to simplify the code, just return the value from cpu_eth_init(bis) directly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-13i.MX6DQ/DLS: replace pad names with their Linux kernel equivalentsEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-11-13wandboard: Return the error when cpu_eth_init() failsFabio Estevam
When cpu_eth_init() fails we should not return success. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-13wandboard: Return the error immediately when ipuv3_fb_init() failsFabio Estevam
If ipuv3_fb_init() fails, we should return the error immediately. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04wandboard: README: Include the quad versionFabio Estevam
Wandboard quad was not ported into U-boot at the time of writing the README. Add it to the list of Wandboard variants. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-31Merge git://git.denx.de/u-boot-armStefano Babic
Conflicts: board/freescale/mx6qsabrelite/Makefile board/freescale/mx6qsabrelite/mx6qsabrelite.c include/configs/mx6qsabrelite.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-27mx6: Factor out common HDMI setup codePardeep Kumar Singla
Instead of duplicating HDMI setup code for every mx6 board, factor out the common code Signed-off-by: Pardeep Kumar Singla <b45784@freescale.com> Acked-By: Eric Nelson <eric.nelson@boundarydevices.com>
2013-06-26Add support for Wandboard QuadTapani Utriainen
Add support for the Quad version of Wandboard; fix compile warning resulting from having 2G of memory. Signed-off-by: Tapani Utriainen <tapani@technexion.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2013-06-03wandboard: Enable HDMI splashscreenFabio Estevam
2013-05-16wandboard: fix typo in READMELuka Perkov
Fix typo in wandboard README file. Signed-off-by: Luka Perkov <luka@openwrt.org>
2013-04-28imx: iomux-v3: Include PKE and PUE to pad control pull definitionsBenoît Thébaudeau
PUE requires PKE to mean something, as do pull values with PUE, so do not compell users to explicitly use PKE and PUE everywhere. This is also what is done on Linux and what has already been done for i.MX51. By the way, remove some unused pad control definitions. There is no change of behavior. Note that SPI_PAD_CTRL was defined by several boards with a pull value, but without PKE or PUE, which means that no pull was actually enabled in the pad. This might be a bug in those boards, but this patch does not change the behavior, so it just removes the meaningless pull value from those definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-25wandboard: Add boot selection supportOtavio Salvador
Adds support for 'bmode' command which let user to choose where to boot from; this allows U-Boot to load system from another storage without messing with jumpers. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25wandboard: Add support for Carrier Board MicroSD cardOtavio Salvador
Allow use of the carrier board MicroSD card available in the Wandboard; this allow for loading alternative system from the other card for testing or upgrade proposes. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25wandboard: Add card detection for SOM MicroSD cardOtavio Salvador
This add support to identify if the card is connected or not; so it does not try to communicate with the controller if no card is available. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-03mx6: Fix get_board_rev() for the mx6 solo caseFabio Estevam
When booting a Freescale kernel 3.0.35 on a Wandboard solo, the get_board_rev() returns 0x62xxx, which is not a value understood by the VPU (Video Processing Unit) library in the kernel and causes the video playback to fail. The expected values for get_board_rev are: 0x63xxx: For mx6quad/dual 0x61xxx: For mx6dual-lite/solo So adjust get_board_rev() accordingly and make it as weak function, so that we do not need to define it in every mx6 board file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-04-03mmc: i.MX6: fsl_esdhc: Define maximum bus width supported by a boardAbbas Raza
Maximum bus width supported by some i.MX6 boards is not 8bit like others. In case where both host controller and card support 8bit transfers, they agree to communicate on 8bit interface while some boards support only 4bit interface. Due to this reason the mmc 8bit default mode fails on these boards. To rectify this, define maximum bus width supported by these boards (4bit). If max_bus_width is not defined, it is 0 by default and 8bit width support will be enabled in host capabilities otherwise host capabilities are modified accordingly. It is tested with a MMCplus card. Signed-off-by: Abbas Raza <Abbas_Raza@mentor.com> cc: stefano Babic <sbabic@denx.de> cc: Andy Fleming <afleming@gmail.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2013-03-20Add initial support for Wandboard dual lite and solo.Fabio Estevam
Wandboard is a development board that has two variants: one version based on mx6 dual lite and another one based on mx6 solo. For more details about Wandboard, please refer to: http://www.wandboard.org/ Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
