path: root/board/w7o
2013-09-20SPDX: fix IBM-pibs license identifierWolfgang Denk
The SPDX License List version 1.19 now contains an official entry for the IBM-pibs license. However, instead of our suggestion "ibm-pibs", the SPDX License List uses "IBM-pibs", with the following rationale: "The reason being that all other SPDX License List short identifiers tend towards using capital letters unless spelling a word. I'd prefer to be consistent to this end". Change the license IDs to use the official name. Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-08-19SPDX-License-Identifier: convert PIBS licensed filesWolfgang Denk
This commit adapts the files that were derived from PIBS (PowerPC Initialization and Boot Software) codeto using SPDX License Identifiers. So far, SPDX has not assigned an official License ID for the PIBS license yet, so this should be considered preliminary. Note that the following files contained incorrect license information: arch/powerpc/cpu/ppc4xx/4xx_uart.c arch/powerpc/cpu/ppc4xx/start.S arch/powerpc/include/asm/ppc440.h These files included, in addition to the GPL-2.0 / ibm-pibs dual license as inherited from PIBS, a GPL-2.0+ license header which was obviously incorrect. This has been removed. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Conflicts: Licenses/README Acked-by: Stefan Roese <sr@denx.de>
2013-04-02replace last __bss_end__ occurrences with __bss_endAlbert ARIBAUD
Simon Glass' commit 3929fb0a141530551b3fce15ee08629f80d5ef2a, which changed all occurrences of __bss__end__ into __bss_end, left behind some untouched __bss_end__ occurrences in all 33 u-boot.lds.debug files, in board/mousse/u-boot.lds.ram and in board/mousse/u-boot.lds.rom. These are replaced here. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-08board/w7o/vpd.c: Fix GCC 4.6 compile warningsWolfgang Denk
Fix: vpd.c: In function 'vpd_is_valid': vpd.c:168:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] vpd.c:169:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] vpd.c:178:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] vpd.c: In function 'vpd_get_data': vpd.c:281:6: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] vpd.c:291:6: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] vpd.c:297:6: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] vpd.c:302:6: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08board/w7o/vpd.c: make (mostly) checkpatch cleanWolfgang Denk
Accept 2 warnings "externs should be avoided". Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08board/w7o/flash.c: Fix GCC 4.6 compile warningWolfgang Denk
Fix: flash.c: In function 'flash_init': flash.c:47:25: warning: variable 'base_b1' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08board/w7o/flash.c: make (mostly) checkpatch cleanWolfgang Denk
No full cleanup was attempted. Warnings about "Use of volatile is usually wrong" were ignored. One line > 80 char was intentionally accepted. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08board/w7o/fpga.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: fpga.c: In function 'fpgaDownload': fpga.c:68:29: warning: variable 'val' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08board/w7o/fpga.c: make (mostly) checkpatch cleanWolfgang Denk
Just reformated the code. No attempts were made to clean up warnings about "Use of volatile is usually wrong" or "externs should be avoided". Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx SDRAM defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed some SDRAM defines. This patch now changes lower case UIC defines to upper case. Also some names are changed to match the naming in the IBM/AMCC users manuals (e.g. mem_mcopt1 -> SDRAM0_CFG). Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-09Dual-license IBM code contributionsJosh Boyer
It was brought to our attention that U-Boot contains code derived from the IBM OpenBIOS source code originally provided with some of the older PowerPC 4xx development boards. As a result, the original license of this code has been carried in the various files for a number of years in the U-Boot project. IBM is dual-licensing the IBM code contributions already present in U-Boot under either the terms of the GNU General Public License version 2, or the original code license already present. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-08-06Fix merge problemsStefan Roese
2008-06-03ppc4xx: Remove superfluous dram_init() call or replace it by initdram()Stefan Roese
Historically the 405 U-Boot port had a dram_init() call in early init stage. This function was still called from start.S and most of the time coded in assembler. This is not needed anymore (since a long time) and boards should implement the common initdram() function in C instead. This patch now removed the dram_init() call from start.S and removes the empty implementations that are scattered through most of the 405 board ports. Some older board ports really implement this dram_init() though. These are: csb272 csb472 ERIC EXBITGEN W7OLMC W7OLMG I changed those boards to call this assembler dram_init() function now from their board specific initdram() instead. This *should* work, but please test again on those platforms. And it is perhaps a good idea that those boards use some common 405 SDRAM initialization code from cpu/ppc4xx at some time. So further patches welcome here. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-04W7OLMC/W7OLMG: fix build problems (redundant #define)Wolfgang Denk
2007-07-09board/[q-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
