path: root/board/w7o/flash.c
2011-12-08board/w7o/flash.c: Fix GCC 4.6 compile warningWolfgang Denk
Fix: flash.c: In function 'flash_init': flash.c:47:25: warning: variable 'base_b1' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08board/w7o/flash.c: make (mostly) checkpatch cleanWolfgang Denk
No full cleanup was attempted. Warnings about "Use of volatile is usually wrong" were ignored. One line > 80 char was intentionally accepted. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
