path: root/board/vscom
2018-12-03arm: baltos: remove unused headerYegor Yefremov
OnRISC Baltos series uses SoM with tps65910 PMIC, so remove "power/tps65217.h" header inclusion. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-03arm: baltos: move the board to CONFIG_BLKYegor Yefremov
Use DM for both MMC and USB subsystems and use dedicated DTS for U-Boot configuration. Disable SPL support for GPIO and remove EVMSK leftover for DDR power control via GPIO. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-03-05spl: Kconfig: Rename SPL_USBETH_SUPPORT to SPL_USB_ETHER to match with the ↵Faiz Abbas
U-boot CONFIG Rename CONFIG_SPL_USBETH_SUPPORT to CONFIG_SPL_USB_ETHER. This enables users to block text using CONFIG_IS_ENABLED() instead of resorting to #if ladders with SPL and non-SPL cases. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-05arm: baltos: active mPCIe slotYegor Yefremov
Baltos devices provide a mPCIe slot, whose power is turned off by default. This patch activates mPCIe slot in U-Boot, so that for example GSM modem can be already available in user space. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-05arm: baltos: remove TI board leftoverYegor Yefremov
Remove unneeded pinmux configurations and TI EEPROM struct. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-14Fix GCC format-security errors and convert sprintfs.Ben Whitten
With format-security errors turned on, GCC picks up the use of sprintf with a format parameter not being a string literal. Simple uses of sprintf are also converted to use strcpy. Signed-off-by: Ben Whitten <ben.whitten@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-07-08arm: baltos: drop I2C speed to 1000 HzYegor Yefremov
This action is need to make I2C communication with PMIC stable for low temperature. Print current I2C speed in SPL for visual control. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2015-07-07board: baltos - add maintainer informationYegor Yefremov
2015-06-15board: add support for Vision System's Baltos Industrial PCYegor Yefremov
Vision Systems's Baltos is based on AM335x SoC from Texas Instruments. This patch adds support such Industrial PCs in mainline u-boot. [ balbi@ti.com: updated original patch to current u-boot ] Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
